Minolta cspro ep 1052 - Office Equipment & Supplies
  • 191 Answers
SOURCE: COPIER PRINTING BLANK
check your corona or high voltage charger . meanwhile you can remove the developer tank rotate it manually & if it rotate fine ,remember that their is a door actuation switch that wouldnt allow the copier to rotate while the door is open . you can remove the tank & use hand to mark the toner surface then restore it & on the copier ,then remove it to know if the mark rotate . if your corona wire cut, burn or if the charger is spoiled all these can cause blank copy
Posted on Oct 11, 2008
firecontrol7
  • 6696 Answers
SOURCE: how do i install my CSPRO 4000 printer to my computer?
The EP4000 is a Minolta analog copier. it has no computer connection.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 13, 2009
firecontrol7
  • 6696 Answers
SOURCE: power is on, but blades dont move
What do mean about blades not moving. The machine is a legacy minolta machine. The paper draw rollers mite need replacement. does the paper leave the draw?
Posted on Apr 15, 2010
SOURCE: Minolta CSPRO EP 1080 isn't copying, shows only warning lights
I have a Minolta 1080 could be used for parts.
jim@solarsystemsintl.com
Posted on Sep 14, 2010
  • 170 Answers
SOURCE: I have a problem with
try to reset the error to reset that error is open the fron door & you will see a small cover square shape with a lock of 1 screw just remove the screw then you will see the reset botton
Posted on Nov 25, 2010
Cspro ep 2030 minolta copying rough in the morning, but okay in the afternoon, solution please
Sounds like the warm up controls are not opperating properly. Or it is in a very cold environment. The "fuser" that provides the heat required to "glue" the toner to the paper may be defective, or the connections to it's controller or the controller is defective. Temporary solution may be to leave it "on" overnight to keep it as warm as it gets in the afternoon. Will take more electricity. But eventually it will need to be repaired, or replaced with a lightly used equivelent. It may be less costly than repair.
May 07, 2015 | Minolta Office Equipment & Supplies
Book Maintenance Copiers Konica Minolta cspro ep300
Exposure lamp the bright light under the big glass is burned out, try reset, by opening front door look to your upper left small access plate remove it this must be done with machine on. press the reset button if the code goes away OK. If not replace the exposure lamp if you can find one a very very legacy Minolta machine!
Nov 27, 2013 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
My photocopying machine is sending me blank pages after photocopy
Minolta cspro ep 1031 My photocopying machine is sending me blank pages after photocopy
Jan 15, 2013 | Konica Minolta EP 2030 3000 Toner 2-410...
RefurbishMinoltaPhotocopier
go to this web site to see how much parts are going to cost!!!!
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 27, 2012 | Minolta Office Equipment & Supplies
Please I want the solution of the code error C0F22 for the minolta EP 3010 CSPRO
Check the drum density sensor must remove the drum to clean it.
Jun 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
Detaile of Code of Minolta Ep 6001 coper
pleas send me cs pro 6001 code 611 salvation
Feb 12, 2011 | Garden
Máy photo minolta cspro ep
what is the problem? sir/mam
Jan 06, 2011 | Minolta EP4000/5000 CS/PRO Copier
How do i install my CSPRO 4000 printer to my computer?
Jul 02, 2009 | Minolta EP1083 CS/PRO Copier
Problem in minolta cspro 2050
What code are you looking for??? I'll tell you what it means for FREE.....
Aug 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
32 people viewed this question
k24674
jasbo
jasbo
