Modem my modem showing all lights dim and ON as i power ON my modem and it is not working please help me
    Top Expert:
  • 12,223 Answers
Reset the unity disconnect the power from the wall by 40 seconds. An then connect again. They a small switch, use the pencil erase point and click, and restore the mode. try again.
Try to use the disk coming with the MODE, and make troubleshooting. Use the utilitity network for diagnostic and repair
If the problem persist, you must call to the company supplier for internet, for support help.
God bless you
Posted on Jul 11, 2013
My usb modem [lemon 3g] does not get detected. when i plug the modem it does not show anything i.e usb icon detected hardware etc. when i clikc on cmy computer also it does not show any connection why is...
First, check for the power source, there should be a light indicator on the panel of the modem, else, power is a problem, check your adapter/power cable. Next, is use USB cable/USB port, try to use other USB cable/USB port. Another option is to check your Control Panel - Device Manager, see if there is a USB Modem currently installed. Remove/delete the device from your Device Manager. Going back to Control Panel, select Add Hardware. If still fails to detect, your Modem is dead.
Good luck.
TedMac
Sep 18, 2010 | Computers & Internet
Modem only shows pc/activity light on. Other lights that are normally on are not working. When I unplug and plug in power line green lights show momentarily and then go immediately off and stay off.
Your modem is either not working and you should request/buy a new one. Only other problem could be the incoming coax lines could have triggered a problem. But most likely the problem lies within the cable modem as they do have a tendency to just stop working.
Jul 16, 2010 | Arris SURFboard® SB5101 Cable Modem
My modem randomly resets and no internet.
either the modem is going out or its a problem with your internet provider. before calling to complain to the internet provider. run down to your local walmart or electronics store and pickup a modern if you have the same issue its your internet provider.
i delt with a modem that was causing a similar issue. the problem ended up being the modem was running hot. i modified the case and added an external fan and the problem went away.
hope this helps. good luck
Mar 03, 2017 | Thomson RCA DCM245R Modem
Dim Head lights not working, but full light does. Car: honda crv 2003. On dim switch, all three cables on the bulb connector are hot(+). I need help on this. Thanks
I believe the dim function uses a ballast resistor in the earth circuit, this would be bypassed when full power is needed that is why all 3 show power. Sorry I cannot help with the location, but if you price one up at a dealer they should tell you where it is, some Hondas have them on the front panel below the l/h lamp, under the bumper cover.
Oct 28, 2009 | 2003 Honda CR-V
Modem only shows two lights; can't connect my PC to the internet!
It sounds like you've lost connect to your ISP. Have you checked with them to make sure you don't have an interruption of service?
If it's not an IOS, work with the ISP support technician to trouble shoot. They may have to replace the modem if they can't isolate the problem.
May 21, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
HELLO
First, try to reset the router. Hold the reset button at the back of the router for 20 seconds then unplug the power. Make sure the modem is off as well. While the modem and router are off, double check your physical connection. Make sure the modem is plug into the Internet port of the router and your PC to port number 1. Power on the modem first, wait for the lights to go solid then power on the router. Check if the internet works fine.
Hope that helps.
Sep 15, 2008 | Belkin Computers & Internet
Please help
hello!
are you trying to access the router setup?
are you trying to configure the router?
i have read the same problem on the supportrix forum and you may try this simple steps and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
Aug 14, 2008 | D-Link DI 514 Wireless Router (DI-514)
Modem keep rebooting.
It sounds like you have a bad modem. Have you tried to plug the device into a different power outlet? This will rule out that it's a possible power issue in the outlet.
If no change by trying a different outlet I would replace modem.
Hope this helps.
MO
Jul 12, 2008 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
