Question about Blizzard Entertainment Video Game Consoles & Games
Starcraft windows 7
Font/font.gid cant be loaded
I cant change the font size on my customer invoices?
OS not specified
For Windows 7
http://www.wikihow.com/Install-Fonts-on-Windows-7
Look the same for Windows 8 or later
So, your PC will have the available fonts you want. Replace the one the program uses for those and rename the ones you had, so you can use them later..
Jan 02, 2015 | Avanquest My Invoices And Estimates Deluxe...
Problem of internet explore 11
I understand that you are having issue with the fonts in windows 7 64 bit operating system. You can restore the default font and remove any changes that you've made to your display settings from Appearance and Personalization.
Here's how:
a. Open Fonts by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Fonts.
b. In the left pane, click Font settings.
c. Click Restore default font settings.
Note
This also removes all manual changes that you've made to your display settings.
Refer the links for the information on;
Change your font settings http://windows.microsoft.com/en-US/windows7/Change-your-font-settings
To install or delete any particular font:
Install or delete fontshttp://windows.microsoft.com/en-us/windows7/Install-or-delete-fonts
Mar 12, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Where can i down load a contvecta font?
http://ufonts.com/fonts/lhf-convecta-base.html
Mar 10, 2014 | Microsoft Windows 7 Ultimate for PC
Error Message on Starcraft install
I would uninstall the game then reinstall it and see if that makes a difference if not it could be you video card.
Jul 28, 2012 | Blizzard Entertainment StarCraft Battle...
Localization.xml could not be loaded
I had the same thing Locaization could not be found while trying to download Oringal Starcraft not broodwar... HELP
May 03, 2012 | Blizzard Entertainment StarCraft Battle...
How to install Fonts in windows 7
hello nirav702,
To install Fonts in Windows 7, simply follow this step:
1. Download Your fonts and then unzip
2. Right clik on it and then click on properties
3. Under the General tab You will see an Unblock Button (click on it only if u see the Unblock Button, if it's not then ignore this step)
4. You can either drag and drop the font to directory: "C:\Windows\Fonts" or u can just double click on the font and install it
hope this help
Apr 14, 2010 | Broderbund ClickArt 19,000 Fonts Full...
MY Macbook pro disc drive wont read the Starcraft game discs. Every other cd or dvd i put in the drive at least reads, but when I put in starcraft it just spins for a second, pauses, and spins again...
I was pretty disappointed when I couldn't play a 12 year old game on my new macbook either. The best thing to do is go to battle.net, load up the CD key and then load the software onto your mac. The downside is that you will need internet access before playing even if you play single player. That's the way I got around it.
Apr 11, 2010 | Blizzard Entertainment StarCraft Battle...
When iam lunching starcraft brood war it gives me a messege says can't load file (rez\data\version.txt) plz some body help me thanks
Do you have the original Starcraft? Brood War is just a expansion of Starcraft and cannot play without the original Version!
Mar 05, 2010 | Blizzard Entertainment StarCraft Brood War...
Having problem with Photo Explosion on Windows 7. Get this error Load MPEG vio Driver Error "ulead.datPE.ini
A way to fix this error which is a font problem is to take the PE.ini from ProgramData\Ulead Systems\Ulead Photo Express\6.0 and stick it in the ulead.dat file in the Program Files (x86) if you have a 64 bit system and then find the u32Comm file in the program files (x86) and change the font to a font where it will not say that error again, I have done this in Windows Vista before and it worked, I also done it in Windows 7 and that also worked allthough right now I can't remember what font so you'll have to trial and error the fonts and maybe the sizes etc. but it's mainly a font error within Photo Explosion Deluxe, 1 problem I'm having is Photo Explosion Deluxe 3.0 loads on one desktop and loads fine newly created desktops but it doesn't load on others. I figure it was made by cheap software creators.
Nov 29, 2009 | Nova Development Photo Explosion Deluxe...
Starcraft Broodwar error "script 4849664 does not exist"
If you are using Vista, try to disable your firewall and run program as Administrator. Windows firewall might be preventing the program from loading or installing correctly.
Nov 28, 2009 | Blizzard Entertainment StarCraft Brood War...
Video Game Consoles & Games Logo
Top Blizzard Entertainment Video Game Consoles & Games Experts
James Wishart
Josh Hannegan
Josh Hannegan
Level 1 Expert
Bruce Meyer
Bruce Meyer
Level 1 Expert
Are you a Blizzard Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
