Bosch wae22460au 01
Machine not washing or spinning
barkencoa
  • 3463 Answers
SOURCE: Not Draining or Spinning
Check to see if there is a removable lower plastic cover at bottom front of washer, if there is remove it ,and on the lower right hand side, you should find the pump filter.
Unscrew anti-clockwise, remove and clean.
Please rate my solution.
Thanks.
Posted on May 30, 2009
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
  • 662 Answers
SOURCE: mACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Posted on Jun 15, 2010
  • 662 Answers
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 17, 2010
How do i get the bottom filter out off my bosch front loader washing machine WAE22460AU. it will turn one quarter of the way but will not come out.
plenty of you tube videos on how to remove filter on a bosch front loader either go to www.youtube.com and search for bosch washing machine changing filter.
Dec 30, 2014 | Bosch Washing Machines
Bosch Washer WFK2401UC/01 Does not spin. Replaced Power cir. Bd. Turned on started right up. completed cycle. Went to wash this morning Drum will not spin
Sometimes the brushes on the motor get worn and they cause motor to act intermittently. I changed my brushes and this corrected the problem of not washing or spinning.
Dec 11, 2014 | Bosch Washing Machines
How do I use the spin button on bosch
Each time you press it within a cycle program it toggles through the different speeds
Sep 26, 2014 | Bosch Washing Machine Control Panel...
WFO2864GB/01 will not spin
FIRST IS THE WATER PUMPING OUT WHEN WASH IS DONE AND IT SWITCHES TO SPIN? IF NOT THEN IT WILL NOT SPIN YOU HAVE TO GET RID OF THE WATER FIRST. IF IT IS NOT PUMPING OUT THEN THE PUMP MAY BE THE PROBLEM.
May 06, 2014 | Bosch Washing Machines
Error E:01
The control board is seeing the door as open even though it may be closed. Here is how to repair it:
http://www.techanswerslive.com/appliances/bosch-nexxt-washer-error-code-er%3a01/1
Mar 13, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I lost my instruction boooklet for my Bosch WAE22460AU washing machine. Can I possibly download it from the net? Kind regards Loris
http://www.bosch-home.com.au/WAE22460AU.html
Go here and select the user manual.
Then select the proper manual.
Mar 20, 2011 | Washing Machines
Bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Make sure there is no water in drum.
Remove and clean pump filter, this is usually located at the bottom front right of washer, behind drop down cover.
Unscrew anti- clockwise to remove and clean.
Good luck.
Dec 13, 2009 | Bosch Washing Machines
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
Bosch washing machine won't spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Oct 26, 2008 | Bosch WFK 2401
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
