Question about NEC NDT44 DVD Player/VCR
Resistor Fuses Due to a power surge, this unit has blown the 2 100UK, 275V, 435B MKP fuse resistors. I cannot find a source for them, any ideas please
    Top Expert:
  • 12,223 Answers
Go to http://www.partselect.com/ or www.radioschack.com
and get it
God bless you
Posted on Jul 11, 2013
2006 dodge caravan,fan blower not working on any speeds,was working and functioning on all speeds this morning...any ideas?
you possibly have a bad blower motor resistor. It is located behind the glove box. First check to see that there is power to the blower motor on the black wire at the blower motor. If there is power than ground the dark green wire at the blower motor. if the blower motor runs at full speed than the resistor is usually the problem.
you can also check for continuity between the dark green wire and the dark blue with grey wire at the resistor. Note where those two wires are in the connectors. remove the connectors from the resistor. check for continuity on the pins in the resistor where those two wires where attached. If there is no continuity than the thermo fuse has blown in the resistor and the resistor will need to be replaced.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Nov 08, 2015 | Dodge Cars & Trucks
Lightning damage
Replace the parts with the original ones, a .5 ohm difference on a resistor on the video circuits will cause the unit not to work correctly.
Sep 27, 2008 | JVC HR-XVC27U DVD Player/VCR
I believe the unit has a blown fuse, but I cant locate it?
If the fuse is blown, then you can locate the fuses at the power stage of the power supply, trace the LIVE terminal on the you see a link that connect the fuse and the LIVE terminal of the power source, most of the fuse are easily detached, because they have a fuse holder, but some are resistor like in appearance, it is always solder to the panel board, which make it difficult for people to know that is a fuse, but as a technician they will know.
Hope this will help in solving the problem...
Aug 05, 2011 | Velodyne DLS4000R Subwoofer Speaker
Heater fan won't work
Hope this helps, it it does please leave feedback Thank You and Good Luck
Check fuses
Check power at blower motor
if there is power try to tap the motor this may getting it going but you will need motor.
if no power
check power before resistor
if power present and it goes on/off with blower motor switch
resistor is bad
if no power to resistor check power from fuse to resistor
but most likely it will be either the fuse, resistor or the motor
Jan 01, 2011 | 2000 Chevrolet Blazer
My A/C blower stopped working completely. First it was the number one setting, then it progressed to number two, and so on until finally all five settings dont work. I checked fuses and they were good....
the blower motor is drawing too much amperage and has blown the resistor, start with checking voltage from the switch to the resistor then to blower motor, if the resistor is blown replace it and the blower motor
Oct 28, 2010 | 2001 Pontiac Grand Prix
I have a Hitachi, 42 in. plasma ultravision and this morning I could not turn the tv on. No power.
check the branch circuit of your convenience outlet..the circuit breaker may have tripped..try to connect other appliance to the outlet where your TV is connected..this is to ensure there's power in it..if you are certain then that there's indeed power from the outlet you are sure that the TV is not working..check TV fuse and replace if blown..check resistance between the plug terminals after fuse replacement..if resistance is low, change voltage dependent resistor (VDR) with same value..it is a disk type resistor that looks like a big ceramic capacitor located just after the fuse..either blue,black or red.blown fuse may be due to power surge during the night..
Jul 17, 2009 | Televison & Video
Blown capacitor on 4 year old ac hampton bay is
Not common, keep in mind compositor work almost like a fuse but restrict certain amount of voltage to flow through, power surge or unit overload from AC compressor kicking on and off can cause the resistor to fail; its parts of electronics working. My AC unit trip my main fuse box once in the great while, nothing surprises me when it come to electronics.
Jul 16, 2009 | Hampton Bay Heating & Cooling
1998 chevy blazer
fan blower resistor. Under hood near blower motor. Follow the power that goes to blower back to resistor, there should be several wires on it. That's the most LIKELY source of your problems.
Aug 06, 2008 | 1999 Chevrolet Blazer
NEC NDT44 DVD Player/VCR Logo
Top NEC Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
