Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Frigidaire upright freezer and frig with freezer on top
I had a power failure. Bought dry ice. Put 1 10lb block in frig and 1 10lb block in freezer. Power came back on while I was not home. Frig/freezer shut down, presumably because it got too cold. Has not come back on since it got too cold. Does anyone have a solution? Larry
  • 63 Answers
It might have low volatge to compressor and burned out overload try unplugging it again wait a few hours and plug it back in it might start working good luck if it doesnt try replacing relay overload compasator they sell a kit called a 3 n 1 start kit
Posted on Aug 29, 2007
Why is my freezer working but not my frig in frigidaire upright with seperate doors
Check the rear is clean and clear. The condenser should be warm, not hot. If it cools down towards the end of the rungs and the last bit is cold. suspect short of gas.
Further check any fans etc and remove any excess ice, and make sure the door seals ok.
Aug 06, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
You need to remember heat rises and cold air falls. The best way to load a freezer is to put meats on the bottom. They take alot longer to freeze and thaw and can save your stock if you have a power failure. Keep non-critical things like ice cream, ice, and other thing towards the top for quicker access.
May 10, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
My freezer doesn't seem to be freezing as well as it has in the past. somethings are frozen hard but ice cream isn't as solid as it should be
Try this... unplug...
take everything out and defrost the freezer
(go get a couple bags of ice and a big clean garbage can so you can keep the food cold)
you can defrost the freezer faster with a hair dryer
when you finish turn t'stat to high setting... put all food back in and dont overload and dont block any air vents (if they are located at top dont overlaod)
plugg in wait 24 hrs...
if you dont notice a difference let me know...
hope this was helpful
Mar 08, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer froze on top thawing on bottom
Dispose of the unit and buy a new one. If it leaked the refrigerant out you have to fix the leak before charging it again. The chances of finding the leak are slim.
Sep 01, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frig no longer cold
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
May 27, 2009 | Frigidaire Freezer Refrigeration White...
Ice forms on copper pipe under freezer off compressor
it sound like your unit has a bad sensor on it or a leak. you should never have to add refrigerant to a unit unless theres a leak then it has to be repaired firdt the recharged.
Jan 11, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Water leaking from ceiling of frig, no ice forming.
pat,this is tom.if your box temps are fine.then you have a blocked defrost drain.[if temps bad ,will condensate in fresh food because warm temps]couple ways one is to shut box down eight hours other is to remove the back frezer panel and clean out all that ice and clear can use blow dry to melt ice[watch water and electricty do mix at all,be carefil]once ice gone use weed eater line with nott in one end to push threw and come out ouher end and cleanin His name,tom
Jan 02, 2009 | Freezers
Freezer bad smell
the defrost pan is located under the frig. if there is a cover at the bottom on the front remove it and the pan should slide out
Nov 17, 2008 | Frigidaire Freezer Refrigeration White...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
118 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
