Question about Home
How do I wash several aprons together without them getting tangled?
    Problem Solver:
  • 10 Answers
You can tie the apron strings together so they don't get tangled. Or even safer is if you put them in a pillow case and tie a knot in the pillow case.
Good luck
Posted on Jul 11, 2013
Simplicity Pattern 4597-apron A has missing or vague instructions to make pleats & sew pocket to front of bib apron. Can anyone explain how to make the pleats and secure to the bib apron front.
Search the internet for "pleat" instruction:
Google
Once the pleats are formed on the one piece, the two pieces are stitched together with a regular seam (as though there were no pleats in the second piece).
Apr 08, 2016 | Simplicity Sewing Machines
Why are my business shirts on a gentle cycle or any wash cycle so badly tangled togther?
Hi Stella,
I suspect the tangled shirts coming out of the washer is a result of the differences between the way a front loader vs a top loader clean clothes and can not be avoided. I don't think this is the source of the wrinkles though. I suspect the wrinkles are more a result of how long clothes remain in the dryer *after* the cycle has completed. If you remove the clothes *promptly* from the dryer and use a "dryer sheet" you will reduce / minimize the wrinkling you're seeing.
Mar 28, 2015 | Washing Machines
Any good ideas for storing yarn without it tangling? My yarn is so messed up and it takes me ages to untangle before I can even get started.
Try taking a 2 liter soda bottle. Wash it out really well and stick the ball of yarn inside and feed it through a hole in the lid. It will stop it rolling around and getting all tangled. You can also use an old oatmeal can for this.
Feb 25, 2013 | Crafts & Hobbies
The washer states "Pulsating System for Tangle
Tangling problems are normally related to how the washer is loaded. Do not place a garment around the perimeter in a circular fashion. Instead drop the article straight down in a kind of 'heap', one item next to or on top of another but not layed out in a circle. Hope this helps.
Dec 31, 2010 | Avanti Top Load Washer W797
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
How do i attach the raincover to the maclaren major elite buggy
TO FIT THE RAIN APRON
The rain apron can only be used in conjunction with the fitted sunshade.
The rain apron may be fitted with or without the footrest attached.
A Place the rain apron over the attached sunshade with the ventilation vents on each side of the
sunshade.
B Attach the six eyelets (three each side) to the corresponding pins located on the sunshade, rear legs
and front legs.
C Place the rear apron flap between ‘X’ tubes and seat back. Attach the two poppers
Jul 10, 2010 | Maclaren Major Elite Umbrella Stroller
Apron string caught under the rod the agitator sits on. How do I take it off to remove the apron string
Is it a top loader if it is.
You can remove the agitator.
Remove the dispenser pops out, you might need a flat screw driver. After that remove the cover in the agitator.
There should be a bolt. remove the bolt and now you can pull out the agitator.
Now you can get the apron string right out.
http://www.pdxappliance.com
Feb 27, 2010 | Washing Machines
Apron stuck under the spinner
Hello blubear0105 ,
Download the Service Manual and take a look at Page 37 “Tumbler Removal” You will need a #20 Torx driver to remove the tumbler the SM doesn’t call that out. It’s easy to remove, post back if you have any questions. Rich
The Service Manual for reference. Sears Parts Direct for reference.
Oct 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Clothes come out tangled
Things tend to intertwine in the washer, even more so in front loaders. The only things that I have found that help is to use fabric softener, a gentler cycle, and an extra rinse. This alleviates the problem some for me, but it doesn't really go away entirely.
Regards, --W/D--
Aug 01, 2009 | Kenmore Washing Machines
Apron caught under wringer
Hi Karen,
That is a real pain when that happens, but let me see if I can help.
First on the top of the agitator or wringer you will see a small cover. You will need to pop that off to reveal the screw hidden underneath. Remove the screw and then the agitator will pull upward and off. The agitator on the hotpoint washing machine is really hard to pull off so you will really have to pull. When the agitator comes loose you will ofter be pulling so hard that you could hurt your arm on the top of the tub so be extra careful or get some guy to get hurt for you. Once removed I am sure the apron can be easily removed and all will be well again. Good luck to you and please dont forget to rate me. Have a nice day.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Oct 28, 2008 | Hotpoint Washing Machines
Home Logo
902 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
