Question about Vehicle Parts & Accessories
I need to repair the spindle on the front wheel assembly.The grooves are stripped. Any ideas?
  • 109 Answers
What kind or car I take it a front wheel drive if so must replace the cv joint or axle
Posted on Jul 11, 2013
Front wheel gear not engaging
move wheels out to meet gear if gears stripped switch wheels from front to back
May 05, 2012 | Pentair White/Gray Legend Platinum...
How do i remove the brake caliper on a 1994 f350 4x4 there are no bolts attaching it
If this is a Pin Slider, here is 1996 steps:
Section 06-03: Brakes, Front Disc 1996 F-150, F-250, F-350 4x2, 4x4, Bronco and F-Super Duty Vehicles Workshop Manual
REMOVAL AND INSTALLATION Caliper
Heavy-Duty Rail Slider, F-Super Duty
Replace brake shoe and lining (2001) as follows when the lining is worn to a minimum thickness of 0.794mm (1/32 inch) above the front disc brake rotor shield. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Always replace all brake shoes and linings on an axle. Never replace only one wheel (1007).
Removal
  1. To avoid fluid overflow when the caliper pistons are pressed into the caliper cylinder bores, siphon or dip part of the brake fluid out of the brake master cylinder reservoir (2K478). Discard the removed fluid.
  1. Raise the vehicle and install safety stands. Remove the front wheel and tire assembly.
  1. Place an appropriate size C-clamp on the disc brake caliper with end of clamp against caliper and end of screw against outer shoe. Tighten the clamp to bottom the caliper pistons in the cylinder bores. Remove the clamp. Do not use a screwdriver or similar tool to pry caliper pistons (2196) away from the front disc brake rotor (1125).
  1. Clean excess dirt from area around pin tabs.
  1. Tap upper caliper pin toward inboard side until pin tabs touch the front wheel spindle.
  1. Using Hydraulic Caliper Pin Remover D89T-2196-A or equivalent and a light hammer, drive the pin from the disc brake caliper as follows:
    1. Position the notched end of the tool against the caliper pin (retention tab half), at a 45-degree angle from the pin retention tabs.
    1. Tap the tool with the hammer to compress the retention tabs.
    1. As the retention tabs are compressed, move the tool to gain a straight approach to the caliper pin, and continue tapping to drive the caliper pin through the caliper/spindle groove.
  1. Repeat removal procedure for lower caliper pin.
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not let the disc brake caliper hang by the front brake hose (2078). The front brake hose could become stretched or twisted which can cause the front brake hose to leak and rupture, resulting in failure.
    Remove the disc brake caliper from the front disc brake rotor. If the disc brake caliper is to be removed for service, remove the front brake hose from the disc brake caliper. Plug the end of the front brake hose to prevent fluid loss and entry of air into the system. If the disc brake caliper is not to be removed, wire it up to the frame of the vehicle to avoid damage to the front brake hose.
Installation
stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Always replace all brake shoes and linings on an axle. Never replace only one wheel.
  1. NOTE: There is a raised section at one end of each shoe so installation can be made in one direction only.
    Install new inner and outer lining.
  1. Lubricate the knuckle upper and lower inner pad grooves and caliper grooves with Disc Brake Caliper Slide Grease, Silicone Dielectric Compound D7AZ-19A331-A or equivalent meeting Ford specification ESE-M1C171-A. Install the disc brake caliper on a front wheel spindle, making sure the mounting surfaces are free of dirt.
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not allow the tabs of the caliper pin to be tapped too far into the spindle groove. If this happens it will be necessary to tap the other end of the caliper pin until the tabs snap into place. The tabs on each end of the caliper pin must be free to catch on the spindle flanks.
    Position caliper pin with the pin retention tabs oriented adjacent to the spindle groove.
  1. Tap the caliper pin on the outboard end with a hammer. Continue tapping the caliper pin inward until the retention tabs on the sides of the caliper pin contact the spindle face. Repeat procedure for the lower caliper pin.
Oct 23, 2011 | 1994 Ford F350 Crew Cab
Replacing axel on passenger side of 2000 hyundai elantra please give a step by step
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    • Front wheel
    • Spindle nut
    • Wheel speed sensor, if equipped
    • Outer tie rod end
    • Stabilizer bar link
    • Lower ball joint
  3. Press the stub shaft out of the hub.
  4. Pry the inner joint out of the transaxle or intermediate shaft.
To install:
NOTE
Use new circlips, split pins and self-locking nuts for assembly.
  1. Install the inner joint so that the circlip is felt to seat in the retaining groove.
  2. Guide the stub shaft into the hub.
  3. Install or connect the following:
    • Lower ball joint and torque the nut to 43-52 ft. lbs. (58-70 Nm)
    • Outer tie rod end and torque the nut to 17-25 ft. lbs. (23-34 Nm)
    • Spindle nut and torque the nut to 144-187 ft. lbs. (195-253 Nm)
    • Front wheel
  4. Check and/or adjust the wheel alignment.
Jun 16, 2011 | 2000 Hyundai Elantra
Need pictures and procedure 91 Ford pickup F250 twin I beam ball joint replacement.
Wheel Spindle, F-150, F-250, F-350
Removal
  1. Raise the front of the vehicle and install safety stands.
  1. Remove the wheel and tire assembly. Refer to Section 04-04 .
  1. Remove the disc brake caliper (2B120) from the rotor and wire it out of the way. Refer to Section 06-03 .
  1. Remove the dust cap, cotter pin, nut retainer, nut, washer and front wheel bearing (1216).
  1. Remove the rotor from the front wheel spindle (3105).
    Item Part Number Description 1 606085 Clamp Bolt 2 3B404 Camber Adjuster 3 800895 Nut 4 800937 Nut 5 3049 Front Suspension Upper Ball Joint 6 3050 Front Suspension Lower Arm Ball Joint 7 3105 Front Wheel Spindle 8 642569 Cotter Pin 9 3304 Steering Sector Shaft Arm Drag Link 10 383489 Nut 11 3001 Front Axle Assembly 12 388727 Bolt A - Tighten to 77-103 Nm
    (57-75 Lb-Ft) B - Tighten to 68-92 Nm
    (50-67 Lb-Ft) C - Tighten to 113-153 Nm (83-112 Lb-Ft) D - Tighten to 340-460 Nm (250-339 Lb-Ft)
  1. Remove bearing cone and roller (1201) and wheel hub grease seal (1190). Discard the seal.
  1. Remove front disc brake rotor shield (2K004). Refer to Section 06-03 .
  1. Disconnect the steering linkage from the integral front wheel spindle and spindle arm by removing the cotter pin and nut and then removing the front wheel spindle tie rod from the spindle arm with Tie Rod End Remover TOOL-3290-D or equivalent.
  1. Remove the cotter pin and castellated nut from the lower ball joint stud.
  1. Remove the nut from the axle clamp bolt and remove the bolt from the axle.
  1. Remove the camber adjuster from the upper ball joint stud and axle beam. If required, use Ball Joint Removing Tool D81T-3010-B or equivalent to remove adjuster.
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use a pickle fork to separate the ball joint from the axle as this will damage the seal and the ball joint socket.
    Strike the inside area of the axle as shown to pop lower ball joints loose from the axle beam.
  1. Remove the front wheel spindle and ball joint from the axle.
Ball Joint, F-150, F-250, F-350 SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number U-Joint Tool T74P-4635-C Ball Joint Remover T94T-3010-AH
Removal
  1. Remove the front wheel spindle (3105) and ball joint assembly from the axle. Refer to Wheel Spindle, F-150, F-250, F-350 in the Removal and Installation portion of this section.
  1. NOTE: Lower ball joint must be removed first.
    Install the front wheel spindle in a vise and remove the snap ring from the lower ball joint.
  1. Remove the lower ball joint from the front wheel spindle using U-Joint Tool T74P-4635-C and Receiver Cup D81T-3010-A5 or equivalent for F-150. Use Ball Joint Remover T94T-3010-AH for F-250 and F-350.
  1. Turn the forcing screw clockwise until the ball joint is removed from the front wheel spindle.
  2. CAUTION: Do not heat the ball joint or the front wheel spindle to aid in removal.
    Assemble U-joint tool and cup on the upper ball joint, and turn forcing screw clockwise until ball joint is removed from the front wheel spindle.
    Installation
    1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not heat the ball joint or axle to aid in installation.
      NOTE: Upper ball joint must be installed into the front wheel spindle first.
      NOTE: Individual ball joint tools are included in Ball Joint Adapter Set D81T-3010-A or equivalent.
      To install the upper ball joint, assemble C-frame assembly, Ball Joint Receiver Cup D81T-3010-A5 and Installation Cup D81T-3010-A1 and D81T-3010-A3 or equivalents inside cup D81T-3010-A4 or equivalent in position on the front wheel spindle.
    1. Turn forcing screw clockwise until ball joint is seated.
Mar 25, 2011 | Ford F-250 Cars & Trucks
How do i pull the hub off my 2002 mazda , on drivers side front
REMOVAL & INSTALLATION Except Miata FRONT
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    • Steering knuckle from the vehicle
    • Inner oil seal from the knuckle
  3. Using Mazda Hub Puller tools 49 G033 102, 49 G033 104 and 49 G033 105, pull the front wheel hub from the knuckle assembly.
  4. Remove or disconnect the following:
    • Bearing inner race from the front wheel hub
    • Retaining ring from within the knuckle
    • Front wheel bearing from the knuckle, using the hub puller tools
    • Brake dust shield
  5. Clean and inspect all parts but do not wash or clean the wheel bearing. The bearing must be replaced. To install:
  6. Using Mazda Press tools 49 G033 107 and 49 H026 103, install a new dust shield cover assembly to the knuckle.
  7. Using the press tools, press a new wheel bearing into the knuckle assembly.
  8. Install or connect the following:
    • Wheel bearing retaining ring
    • New oil seal using Installation tool 49 V001 795
    • Front wheel hub using the Mazda press tools
REAR
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section. NOTE: The wheel bearings are not serviceable. If the bearings are bad, a new hub/bearing assembly must be installed.
    • Rear wheels Fig. 1: Exploded view of the rear wheel hub and bearing assembly (disc brake model shown, drum is similar) 7923mg87.gif
    • Brake drum, if equipped
    • Rear caliper and rotor assembly from the hub, if equipped
    • Hub dust cover
  3. Raise the staked portion of the hub retaining nut with a hammer and chisel.
    • Hub retaining nut and discard it
    • Hub and bearing assembly from the spindle Fig. 2: When installing the new hub nut, be sure to stake it into the notch on the spindle 7923mg86.gif
    To install:
  5. Install or connect the following:
    • Bearing assembly on the spindle. Torque the new nut to 131-173 ft. lbs. (177-235 Nm)
    • Stake the nut into the groove in the spindle
    • Dust cover
    • Assemble the brakes
    • Rear wheel
Jan 01, 2011 | 2002 Mazda Protege
I would like to know if the wheel bearing is in the shaft or the hub?
The Constant Velocity (CV) joints are located on the inner and outer edges of the axle shaft. The axle shaft runs through the hub and bearing in the spindle.
Jun 16, 2010 | 1999 Daewoo Nubira
Need repair instructions for right front wheel assembly or hub (bearing) repair.
Hi, first put the van on jackstands and take the wheel off. then take the brake caliper and bracket, these are removed by loosening the bolts that hold the bracket to the spindle. then remove the rotor (you may have to give it a few love taps with a rubber mallet to break the rust loose), then you will need an axle nut socket set to remove the center large axle nut, this can be rented at any advance auto parts store or its equivalent. an impact gun will make removing this nut and the wheel bearing retainer bolts much quicker. once you get the axle nut loose you will need to take your rubber mallet or a brass hammer and hit the end of the cv axle to drive it out of the wheel bearing. finally remove the three wheel bearing retaining bolts located on the opposing side of the spindle, after that take any hammer and strike the wheel bearing on the backside to drive it out of the spindle( it may give a little bit of a fight to drive it out). then unclip the wire for the abs and remove the bearing. the assembly is just the reverse of the removal. good luck and have fun!
May 20, 2010 | 2000 Pontiac Montana
How do i change inner tie rod , do i need a special tool.
i think steering gear has to be removed to get rubber bellows off to access tie rod.
486d579.gif Section 11-02: Steering System, Power 1997 Continental Workshop Manual
DISASSEMBLY AND ASSEMBLY Tie Rod and Bellows SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Bench Mounted Holding Fixture T57L-500-B
Disassembly
  1. NOTE: Drill out mounting holes in holding fixture with a 9/16 inch drill to allow the power rack and pinion steering gear assembly mounting bolts to fit.
    Mount power rack and pinion steering gear assembly in Bench Mounted Holding Fixture T57L-500-B.
  1. Remove tie rod ends (3A130).
  1. sve~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care not to damage bellows. If bellows are damaged, this will allow contamination into the steering gear and cause leakage.
    Remove four clamps retaining bellows to steering gear housing (3548) and front wheel spindle tie rods (3280). Discard clamps if damaged or excessively corroded.
  1. NOTE: Steering gear does not use rivets or roll pins between the inner front wheel spindle tie rod and rack.
    Remove bellows along with power steering gear rack tube (3K762).
  1. Position power rack and pinion steering gear so that several steering gear teeth are exposed. Hold steering gear sector shaft (3575) with an adjustable wrench on end teeth only while loosening ball joint nuts.
Assembly
  1. Expose several steering gear teeth and hold steering gear with adjustable wrench.
  1. Tighten each front wheel spindle tie rod separately to 90-110 Nm (67-81 lb-ft).
  1. Thoroughly clean steering gear and steering gear housing bore of any foreign material. Any abrasive material is extremely harmful to high-pressure oil seals.
  1. Apply Steering Gear Grease C3AZ-19578-A or equivalent meeting Ford specification ESW-M1C87-A to groove in front wheel spindle tie rod where tie rod bellows clamp to front wheel spindle tie rod and uniformly to inner diameter of tie rod bellows before installation. This allows for toe-in adjustment without twisting tie rod bellows.
  1. Install tie rod bellows and power steering gear rack tube. Make sure power steering gear rack tube is positioned as shown.
    Power Steering Gear Rack Tube and Tie Rod Bellows Installation
Apr 04, 2009 | 1997 Lincoln Continental
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
