Question about Samsung Refrigerators
My samsung 3 door refrigirator is leaking - Samsung Refrigerators
    Filmmaker:
    Uploaded 5 video answers.
  • 91 Answers
Try to check under the vegetable drawer - are there any water there?
Posted on Jul 11, 2013
Samsung refrigirator water dispenser works without filter but does not work with filter
Not enough water pressure in supply line to get past filter?
Open valve feeding supply line more and see what happens.
Sep 06, 2017 | Samsung Refrigerators
Freezer unit not getting cold. Upper unit seens ok
hi there is two importent things u have to check
the first would be thermostat the second one is refrigirant
Sep 21, 2012 | Samsung RF265AA Bottom Freezer French Door...
Freezer door is leaking water on refrigirator model # frs20zshb5 the freezer side of the body where the magnetic strip touches the door is hot to the touch
You know, it's really normal to touch it hot on the door side.
Because it has heater to eliminate moist build up that can cause rust.
Check the drain pan (that is full of water) for clogged.
Unclog it using flexible solid wire and insert it on drain pan tube.
After that, those leak will be minimize.
Thanks for asking.
Jun 29, 2011 | Frigidaire Freezers
My air is not running correct.. blowing hot air out.. what can we do to fix this problem
hi
this may be because following reasons.
1. you might have kept the temperature selection switch in heater please check it.
2.there may be leak in the AC line which might have drained the refrigirant so no cooling effect.check the line for leakage.
3.the refrigirant used may be less which doesnt give much cooling effect.
4.the cooling fan which cools the refrigirant may not working or speed is reduced which may reduces the heat transfer rate
if my answer were useful to you please vote me.
Jul 11, 2010 | 2003 Hyundai Santa Fe
I have a side-by-side Samsung refrigirator RS24FAMS. There is bad smell coming from the back of it. I took off the panel at the lower back but found nothing suspicious. The smell is not from inside the...
there is a drain pan over there next to the compressor ...the old water get there and dry out ...see with flash light all over you might need to clean it (turn unit off) and do it gently ...good luck use some cleaning spray...
Jan 03, 2010 | Samsung RS2630SH Side by Side Refrigerator
Hi, can you give me few points to start from
First thing i need to know what kind of refrigerator you have..
Model # and make...
take a dollar bill and close it in the door gasket and see if you get a pull on the bill when u pull it out.. go along the whole door gasket like that and it will tell ya if your gasket got a leak anywhere...
Aug 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung side by side refrigirator
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Aug 20, 2008 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
