Epson c2900 replace module transfer
"replace module transfer" on the screen. I've no access to the printer's menu, I've already change the fuser unit and clean the belt unit
SOURCE: Imaging Unit Missing Error
Hi, I had the same problem. The following Cause and solution may help you fix your machine.
All refereces to left and right are facing the front of the machine as if for normal use.
The cause is due to the connector on thtop left rear of the imaging unit. this connector is mated with a coresponding, retractable connector in the body of the machine. When you open the cover over the top of the imaging unit, this connector retracts back into the body of the machine and when you close the lid it should re-engage with the imaging unit, The problem is that it dosen;t reconnect. I have asumed that it is due wear in the connector operating mechanism. This solution was effective for my printer.
Switch Off!!!
remove the topcover (after removing the colour catridges )and. remove the left hand side panel. You will see a nylon gear mechanism. Sqeeze together the nylon clip inthe centre of the gear wheel, and pull the gear about halfway off. This should allow you to move the vertical geared bar up 1 notch. .Push the gear wheel back on and try the machine to see if it works ok. All covers will need to be closed and if it works ok , reassemle the machine. Job done -about 10 to 15 mins. It tookme alot longer to find it,so some feedback would be appreciated.
Paul
Posted on Sep 15, 2008
  • 44 Answers
SOURCE: I´ve got a message on my oki C5510 mfp
Check the toners are not empty. The printer only estimates how much it thinks should be left, there is a possibilty one is empty. this is best done by removing each toner in turn and checking that the hopper in the drum is full to level with the sponge surrounding it. Next check are the toner sensors. These are small and located to the right of each toner cartridge in the wall of the printer, one could be dirty creating the error and not allowing the printer to start up completely, causing the scanner connection to fail and giving you "Failed to get printer information". On this model the scanner and printer are essentially separate units joined by a USB cable.
Posted on Nov 08, 2009
SOURCE: Lexmark C522n Laser Printer stating "83 replace transfer belt"
how do you reset the transfer belt of a Lexmark C522 colourlaserjet.
Thanks
Alex
Posted on May 10, 2010
SOURCE: Replace fuser E error
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
Posted on Aug 18, 2010
alpug
  • 1961 Answers
SOURCE: I have an Oki c9650
not 8 0\'s...... use only 6
password is 000000
Posted on Oct 18, 2010
My stylus offive t40w printer wont recognise new ink cartridges
epson have these problem common. you have to wash cartriges contact points by aerosol.
May 29, 2012 | Epson Office Equipment & Supplies
Blue doesn't print. I've cleaned the print heads SEVERAL times and I've replaced the blue cartridge. When I do a nozzle check it sometimes prints partial lines but that's it. Pictures...
It appears that the printer is malfunctioning and will require service. I suggest contact its manufacturer to verify the warranty status of your printer, and have it replace by them. If the warranty is already expired, you can send the printer to the nearest service center for repair.
Oct 18, 2011 | Epson Workforce 610 All-In-One InkJet...
Impossible to connect camera with PC. no driver in the PC for camera powershot A510. What's the matter?
Just figured this one out. Man, they don't make it easy. I'm borrowing my roommate's PowerShot A510 and since it has a USB port going out, I'd assume I could simply connect the camera to my PC and access my images directly. Almost every other camera I've seen will register itself to Windows as a straight USB connection (prompting the Windows screen asking how you want to open the connection - 'open folder' etc). This one just sits dead quiet about things :)
If you've just bought this camera at a garage sale or are borrowing it or for whatever other reason do not have the "bundled" software and driver CD or have the camera's serial number, do not bother trying to find windows drivers or try to obtain any software from Canon. You won't get very far.
FINALLY found the solution in the User's Manual (which was free thank God). You can download the manual here: http://usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a510#BrochuresAndManuals
(Select your operating system and download the "PowerShot A520/A510 Camera User Guide". File name is PSA520510CUG-EN.pdf)
In the User Guide, page 107 (I'll paraphrase):
1. Put camera in Play mode (the switch on the back (green arrow in green box)
2. Press Menu button (center one of the three along the bottom of the view screen)
3. In the 1st menu option (Play Menu, again green arrow in box highlighted), use the wheel button to scroll down to highlight "Transfer Order". Press Set (center of wheel).
4. You should now see "Transfer Order (DPOF) at the top of the screen and "Qty. of images 0".
5. Below "Qty of images 0" you'll see "Order", "Mark All", and "Reset". Order lets you select individual images; Mark All marks all current images for transfer; and Reset is reset. Press Set to choose.
Note: pressing the Menu button while selecting images brings you back to this main screen. If you are already at this main screen and you aren't ready to do your transfer yet, DON'T press the Menu button from this screen as it will initiate the transfer to your computer. Not a horrible thing, but might cause a mini freak-out.
7. Once you're selected the images you want to transfer, from the main Transfer Order window (now showing "Qty. of images" with a count of the images you selected), press the Menu button.
8. You'll see a white progress bar at the bottom of the screen. Don't worry! it's not deleting files or something bad.. (my first thoughts :) ..
9. Go to your PC and Voila! the Windows AutoPlay screen is now active!
10. Proceed with normal Windows USB operations (transferring at least, I didn't try any deletion).
I hope this helps somebody else out there who spent the last 3 hours trying to dig through internet hell to get this to work.
Atm, this is as much as I know so I probably don't have any good answers for any questions. Sorry :))
But, hope this helped at least!
Mar 12, 2010 | Canon PowerShot A510 Digital Camera
Changing Cartridges does not move into view so I change it
try the on/off button with the lid open. it should move the cartridges.
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus DX8450
just hit the spanner icon on the printer itself, the chose replace cartridges from the menu that pops up on the little screen.. it wil tell youi when its ready for changing..
Sep 21, 2008 | Epson Stylus C86 InkJet Printer
274 people viewed this question
k24674
jasbo
jasbo
