How to unmute your nook
My sound is gone I can not here anything at all and I don't know what happen
    Master:
  • 663 Answers
I suggest that you do a system restore to a time when the computer had the sound.
To do system restore, please do the following:
1. Click Start > Programs > Accessories > System Tools > System Restore
Select a restore point. Make sure that it's before the problem occurred. Launch the restore. Wait until completed.
You can also install RadarSync and scan your computer with it so that you will know if there are any out-of-date drivers in your computer which can cause a lot of issues. You can use the same software to update all drivers.
David
Posted on Jul 11, 2013
How do I unmute my NOOK HD?
Just go to Google play and download "sound control +" (it`s free) When you open the application click the icon that looks like a speaker. (Not the one that looks like a speaker with a line through it.) Your sound should come back.
Apr 13, 2015 | Tablets & eReaders
My nook HD got muted.....
If you have low battery It mutes itself.
Download "Volume Control +" app
Apr 14, 2014 | Computers & Internet
Nook hd how to unmute sound videos
I'v never seen that before.... try calling tech support.
Jan 06, 2013 | Computers & Internet
I don't know how to unmute my nextbook tablet.
JUST LONG PREES THE + BUTTON .... I ALMOST DESTROYED MY TAB TRYING TO FIX IT MY SELF... BUT I GOT IT!!!!!!!!!!
Dec 23, 2012 | Nextbook Tablets & eReaders
How transfer music to nook
First in the OS make sure that recording device is USB (Start > Setting > Control Panel > Sounds and Audio > Audio). Adjust the audio recording volume, as well (Start > Programs > Accessories > Entertainment > Volume Control > Options> Properties. Click on Adjust Volume For Recording, for some versions of Windows). Unfortunately you can't directly listen to the recording on USB in this software. You would need a regular turntable with amplifier and then RCA L/R audio to 3.5 mm audio adapters. Connect this to the Line In of the computer (blue port) on the sound card. Then set the recording device to Line In and unmute Line-In in a similar way as above.
Now try recording in Cakewalk Pyro. (I recommend making a short recording and then playing it back to check the settings.) Try the Windows Sound Recorder (similar to finding the audio recording volume) to record if Pyro doesn't work. You may have a problem with the USB turntable or your USB port. You should see a waveform if the software is recording anything. Adjust the audio so that the entire waveform is consistently less than 100% of the maximum. A flat line in the center of the audio trace is a sign that there is no incoming audio signal. I usually start the software recording and then start the turntable at the correct track. Thus a flat line for a few (~10 seconds on my system) is normal.
After recording, you need to export the file or files as MP3s. (I subdivide a longer recording into tracks but that can be a pain. Identifying the "break points" is not always obvious.) Then File > Export (iirc). Select the MP3 option and the quality. I put all my music into the myusername/music/recordings subfolder (I created the folder) to make them easier to find again.
Connect the USB cable from the Nook to the computer. Access the Nook from the File Explorer. (Double-click on the Computer (My Computer) icon with Windows, it's the Devices icon on a Mac.) Then double-click on the Nook's icon (there may be more than one).
Open a second explorer window to the directory where you saved the MP3s. Then just drag and drop the files/folders to the Nook. If you put the files onto the internal memory of the Nook, make sure to put them in the My Music or My Audiobooks folders. (You can do transfer the files to the memory card without plugging in the USB cable, if you have a card reader. Just be careful not to lock the read/write switch on the card and do not reformat it.)
I've used several programs and found Audacity (free) to be just as good and straight-forward to use. However, the programs all work the same way. If the USB device isn't working (or the default recording device), you get nothing.
I hope this helps.
(I will note that most of my recordings were done from cassettes using Line-in from the headphone jack. Thus I only had to diagnose problems with the patch cable and the default recording device once I checked that my headphones worked for the tape. I saved my recordings as WAV and then burned them to CD as Disc At Once for a player that didn't read MP3s.)
Jun 22, 2012 | Cakewalk pyro 5 Full Version for PC
I can't get my nook to work it keeps wanting a password and i don't have one
If you haven't already set up a Nook account,you should. It's easy to do, but you have to have acredit or debt card to do so.
Feb 25, 2012 | Barnes & Noble Nook
Can't connect my 2nd Nook Tablet
Since the nook is wireless, I don't understand what the problem is. Doesn't your nook make a wireless connection? Does it recognize any of the other wireless signals in your area? If it doesn't recognize any wireless signals, then the problem is in your nook and not from your router. Try going by a Barnes and Nobel book store and see if it will log onto theirs. And most Barnes and Nobles have people trained on Nook troubleshooting.
Feb 01, 2012 | Westell Wirespeed VersaLink...
I bought a nook tablet,and i have a netgear router wpn824v3. i don't know what to enter when my nook asks for ssid and password. can you tell me what to do?
your wifi router has ssid and password. try to look the settings inside your router and go to wireless security settings.marmeto12_4.jpg
Aug 22, 2011 | NetGear RangeMax WPN824 Router
People cant hear me when I make a phone call
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.lge.com/us/mobile-phones/LG-VX8500-Pink.jsp
Mute Function and other sound adjustments from page 21 in your manual.
The Mute Function prevents the transmission of
your voice to the caller. To quickly activate Mute
touch Left Soft Key [Mute], then to unmute
touch Left Soft Key [Unmute].
Hope this helps, let me know if I can do anything else for you. Don’t forget to rate me or leave a short not. I appreciate it. Thanks.
JimmyC
Oct 15, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
