Question about Acer Office Equipment & Supplies
Acer 6699 ote - Acer Office Equipment & Supplies
My laptop acer aspire 5755-6699 touchpad was not working. it shows notifications was elan touchpad was not working properly
Is the none of the keys are working? Check out if you have enabled the keyboard...... if everything is k then let us know the os
Jan 20, 2015 | Acer Aspire 5755-6699 15.6" Core I3 2.2...
What is the nearest whole number of 6699
The nearest whole number to 6699 is 6699.
Oct 06, 2014 | Office Equipment & Supplies
Aston martin db7
Fuel pump needs replaced.
Oct 25, 2013 | Cars & Trucks
Itower ote stopped working
open the r.control and clean the keypads with contacts cleaner from dirty, oxide, corrosion and try again.
God bless you
Oct 24, 2013 | Sharper Image Televison & Video
Everytime I tried to turn on my Acer Aspire 5755-6699, I always get the same screen saying.... (Look at picture below)!!!!
Hello
Try to run in safemode with command prompt
when that comes up type in the blackbox
1. fixboot
2. rstrui.exe
1=fixes the boot partition where you look to be stuck at
2= launches the system restore option
If they both fail then you need to use the disk you got with your pc or buy one of the web!
This will however mean that you will loose your data by blowing the hard drive away.
http://www.ebay.co.uk/itm/281085121700?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Mar 30, 2013 | Computers & Internet
How to overcome heatsink problem in acer laptop
1) this a problem for technician. However you must open and clean the heatsink very well, Very Dust must be around and this provoke heating2) Test the fan is working good or has faulty, and replace3) Tight all connector from the computer4) See if the power supply is o.k or is faulty.God bless you
Jan 29, 2013 | Acer Aspire 15.6-inch Laptop Core I3 2330m...
My packardbell easyne problem?ote R4 laptop can not detect microponoes after it was reformat. what seems to be th
try installing your sound card drivers ? and go in sound propertys and make sure mic is not muted or turned off ? hope this helps !
Jun 03, 2011 | Computers & Internet
Driver not found
hi u can downlode www.mercuru.com ok thanking you ote for as
Mar 18, 2009 | Computers & Internet
69 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
