Aeg lavamat 66600 error code e50
Stops part way through a cycle before dispensing conditioner and machine is full of water. shows code E50. Pipes and filters appear free of sludge happens on all wash cycles.
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
  • 174 Answers
SOURCE: ERROR CODE E50 SHOWING AFTER POWER SUPPLY INTERUPTION
It was probably your washer that tripped the electric . e50 relates to the motor check the carbon brushes they will be worn out. hopefully with new brushes you will be back in action. the programme wont start with a fault on the motor
Posted on Jul 24, 2010
rylee_smith
  • 8619 Answers
SOURCE: error E50 how can i
Hi
Thanks for using FixYa. Error E50 indicates motor fault, you’ll have to check the brushes and wiring of the motor and check if it makes a hum sound, if it does and you can see that the motor is not working then it is the motor that should be replaced. If everything else appears to be working fine then it is the PCB that should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 04, 2010
SOURCE: I have an AEG Lavamat L 16850. It has stopped
We have this problem for nearly 2 years now. It always occured in a special program ("Kochwäsche/Buntwäsche 60°" what means coloureds/boiled 60°).
The AEG technician didn't find the problem. Since we avoided that program, the problem never occured again.
But now, close before 2-years-warranty-by-law I demanded them again to repair it. I will report.
Posted on Dec 17, 2010
lidiya_k_99
SOURCE: AEG Lavamat 62800 keeps stopping
AEG Lavamat 62800 keeps stopping and displaying error E50. What is the problem and how do I fix it?
Posted on Apr 23, 2012
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
AEG Lavamat 60810 E50 7Beeps Does seem to still work but display shows E50 and some time E70 and 7beeps over and over. Many thanks
E50 does mean problem with motor or tachometer placed on the motor. Could be: worn carbon brushes, motor faulty, wiring, electronic faulty.
E70 does mean problem with heating phase.
Could be: NTC sensor faulty or badly positioned, wiring faulty, electronic faulty.
Dado
AEG Lavamat 60810 E70 7Beeps Does seem to still work but display shows E50 and some time E70 and 7beeps over and over. Many thanks
First of all, read exactly alarm code.
Press "Spin/Rinse hold" button and "Prewash" simultaneously for at least 2 seconds: the LED switch off and then display the
sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down. During the time the alarm is displayed, the appliance continues to perform the cycle or, if it is in the
selection phase, it keeps in memory the options previously chosen.
E70 - Family alarm code
  • E71 - Washing NTC sensor faulty
  • E74 - Washing NTC sensor badly positioned
Causes: NTC sensor badly positioned; NTC sensor faulty; wiring faulty; PCB faulty.
E50 - Family alarm code
  • E51 - Motor power supply triac short-circuited
  • E52 - No signal from motor tachometric generator
  • E53 - Motor triac sensing circuit faulty
  • E54 - Motor relay contacts sticking
Causes: Motor faulty; wiring faulty; PCB faulty; current leakage from motor or from wiring
Dado
How do I empty water from conditioner dispenser
The dispenser often has a small amount of water in it after a completed cycle so that's nothing to worry about. A lot of water usually means the dispenser needs a good clean. Pull the dispenser as far as it will go and then give a sharp tug to pull it completely out. The middle dispenser cover can then be taken out and cleaned, and so can all the other parts you've removed. The pipes in the machine and in the dispenser tray should be cleaned out well, as these usually cause the problem of retaining water. Put the cover back on the centre section securely and then push the whole tray back into the machine gently. Good luck!
Oct 15, 2014 | AEG Lavamat 72640 Front Load Washer
What does E50 flashing on a Aeg washing machine
Your Water inlet valve is bad or has failed! You need replace either Hot or cold valve.
Jul 25, 2014 | AEG Washing Machines
Code fault E50
Need to put into self diagnostic mode and test the components. You can find the tech repair sheet in the machines that will tell you both what the error code is, how to test it, and how to replace it.
Dec 21, 2013 | AEG T57800 Electric Dryer
My AEG Lavamat 66600 Washing Machine is showing E60 Message how can I remove it to get the machine working again. Thank you
Please remove the power plug and depress all the buttons on the panel, while the power plug is inserted and power switched on , press on the start/pause/stop. it must restart the controller unit or there can be external or internal errors as designated by E60.
Check the door switch,drain pump and inlet flow.
Jul 25, 2012 | AEG Washing Machines
Aug 07, 2011 | Washing Machines
About mid cycle, a significant amount of water leaks out of the bottom. No error message comes up and the machine continues functioning. Machine is AEG oko lavamat 72640
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
Jan 25, 2010 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
250 people viewed this question
Top Washing Machines Experts
