Question about Microsoft Xbox 360 Slim Black Console
Xbox 360 slim wont turn on but it beeps and lights up
Whenever i hit the power button or eject button it beeps and lights up like it was going to turn on but then just turns back off. It doesnt show anything on the tv and i am using HDMI. The power brick is orange no matter where i plug it in to.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
There is a short somewere In the system and it is in protect mode and will not turn on so that the console does not get harmed anymore than it already is. the best solution for this is to send it in to Microsoft and get this problem fixed
Posted on Jul 17, 2013
  • 5 Answers
SOURCE: power cable light is orange and xbox 360 wont turn on
try checking the usb is it damaged? the pins in the usb may be shorted to ground..pry any pins up and the system will work..this happened to me.
Posted on Mar 02, 2009
nealj121
  • 152 Answers
SOURCE: power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Posted on Apr 10, 2009
  • 5 Answers
SOURCE: XBOX 360 power brick flashing orange and green
according to the microsoft website:
The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply itself. The power supply can turn itself off when there is too much current, too much voltage, or too high a temperature. Under these conditions, the light on the power supply will turn from green to orange or to red. Or, the light will turn off. When the power supply light is green, the power supply is working correctly.
To help the power supply work correctly, always try to use the following best practices:
  • Make sure that all ventilation openings in the power supply are free to ventilate.
  • Do not put the power supply on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
  • Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
  • Plug the power supply directly into a wall outlet. In other words, do not use extension cords or power strips.
Basically, feel if it is overheated. if it is let it cool down. If not try a different wall socket. If that doesn't work you probably have a problem with your power brick or console. Try borrowing someone else's power cords.
Posted on Jun 15, 2009
localwonder
  • 6784 Answers
SOURCE: Power Bar has a red light, xbox wont turn on
OK, this is a power supply issue here. you will need to replace the power supply board asap/ it is malfunctioning.
Contact Microsoft for this repair.
Posted on Jun 22, 2009
  • 143 Answers
SOURCE: My Xbox 360 won't turn on. When I plug the power
Sounds like a bad power supply, or on two occasions I have found that one of the USB ports had a bent pin which was shorted to the metal housing, which wouldn't let the unit power on. So check all of the USB ports
Posted on Dec 04, 2009
Xbox 360 s power issues
I've had this happen before I unplugged the ac box the plugges up to the outlet for 10 s and it fixed mine I hope this helps
Mar 04, 2014 | Microsoft Xbox 360 Slim
Xbox 360 slim, beeping and freezing
your motherboard could be a little loose, if this continues for a while longer you may get RROD so id get a tech guy to take a look at it.
Jun 09, 2013 | Microsoft Xbox 360 Console
Xbox 360 won't eject with front button.
Depending on your Xbox slim(black) or original (white), you can hold down the Xbox button, or go to the main menu and eject from there manually, this is a temporary bug, it also dependes on the ae of your xbox so don't mess with it and retry every few hours
Mar 17, 2013 | Microsoft Xbox 360 Console
How do i sync the wirless controller to the xbox
There's a button on the front of your 360 and the same button is on the front of the controller. You hit the button on the 360 and the green lights around the power button start to circle. Then you hit it on your controller and the green lights around the xbox guide button start to circle. In a second or two they'll find each other and both will flash at the same time, and it's synced up. I've linked a video for both the Xbox 360 and Xbox 360 Slim.
Jun 27, 2011 | Microsoft Xbox 360 Controller
Red light blinks and wont stay on when push power button
You can do this fan test.
Turn the main switch off, hold the eject button.
While holding the eject button, turn the main switch on, when the power light is green, release it and you should hear a beep.
The fan will operate at the highest speed possible and will eject any disc that is inside.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and the red light will blink. When this happens, turn the main switch off and on then turn it on normally.
Tell me how this goes!!
May 05, 2011 | Sony Playstation 3 (PS3) Console
My xbox slim eject button stopped working a few weeks after i bought it
Can you open it using the middle button on the handheld controller? I have the regular 360 but I doubt it would be that different. My eject button has not worked in years but if the tv is on and you hold down the middle button on the controller it should say eject disk / turn off system. If you haven't tried that then do so it works everytime for me.
Nov 04, 2010 | Microsoft Xbox 360 Console
My sons xbox 360 wont turn on
Check the power supply unit, if the light is green or orange and still doesn't power on, try pressing the eject button on the xbox it should turn on if you do, if the power supply is red then you should contact xbox support.
Oct 21, 2010 | Microsoft Xbox 360 Console
My xbox 360 keeps on restarting
hit the bution by the on bution and in dack of the controlor
Mar 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Slim Black Console Logo
251 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
