Question about Cycling
Gsmoon atv quad 260 cc
My quad has stopped working, when i move the gear lever nothing happens. any ideas if it is clutch related?
  • 16 Answers
SOURCE: i have a yamaha atv 150 auto and when you rev to
the drive belt in the engine needs replaced
Posted on Mar 04, 2009
SOURCE: mitsibishi colt 97 stuck in 1st gear
Your link broke off. What might have happened is the car got stuck in 1st, and when you shifted to second, the link broke. Not too clued up on your car, but you probably need to drop the gearbox. On some cars you can take out the shifter without having to drop the box and still see if the link is broken. Good luck
Posted on Mar 18, 2009
  • 14036 Answers
SOURCE: 2000 hyundai accent, won't go into gear, clutch works and gearshift moves but nothing happens.
tighten shifting rod bracket.
Posted on Jun 02, 2009
SOURCE: Deore dx shifter stops working
had the same problem, didn't use my bike for longer period. open the shift lever carefully and try something like caramba. worked for me.
sebastian
Posted on Sep 16, 2009
sisadsl
  • 1508 Answers
SOURCE: started bike, pulled clutch lever,
The clutch lever should have some tension, so could be a problem with the hydraulic actuator stuck, or a failure of the clutch. try bleeding the clutch, or pull the clutch cover off and see if the pressure plate moves
Posted on Apr 25, 2010
Quad doesn't go
Hey Jason,
What?? .. slow down and give me more specific detail.. this is not a complicated problem .. just need more info.. could be a simple clutch adjustment... or you need new clutch fiber plates??
Aug 24, 2015 | Yamaha 2004 YFZ450 Limited Edition
Shifter moves on big bear 350 but quad wont reverse now it goes forwards
for some reason you are not getting into reverse , there is no real reason it should stay in forward gears unless there is someting wrong with the shifter itself being in the wrong position this can happen take it off and reposition it and make sure your clutch is disengauging to shift gears , will it go into all gears or just 1 forward , ck into that and be a little more specific on the problem ,good luck
Mar 18, 2014 | Grizzly Big Bear Atv Maintenance Free...
Wont shift from nutral in to gear while running
Often, it mean that the clutch stay engage.
Now the question can be, is the idle to high for the clutch to disengage while at idle? you might try to reduce the idle speed by turning eather the nob on carburator or the ajustement on the cable.
then if the idle is very low and the clutch still engage (that is why you can not shift) you migh want to check at the clutch and see if it is not stuck.
Nov 07, 2013 | RTO 125cc Full Size Adult Quad ATV
Loncin diamo atv 250cc wont move!!i have a 2004 loncin avalanche atv 250cc. the quad starts right up goes into gear but wont move like its stuck in neutral. it has the honda style "auto" clutch...
if it just revs up the the centrifical clutch needs to be changed but if it doesnt then the trans or the rear end might be jamed or even locked up.
Jun 06, 2012 | Motorcycles
Started bike, pulled clutch lever, put bike in 1st gear, let out on clutch and nothing happened. clutch lever moves freely with no tension at all. when i put the kickstand down it shuts off like its...
Apr 22, 2010 | Yamaha YZF-R1 Motorcycles
Alini pocket quad wont move
Have a look at the choke lever. From the starting position, move the lever about 10mm up until you hear a slight click. If not then the clutch plates are not responding to the throttle input. Any lawnmower repair garage will be able to help you more. The 2 stroke works on centrifugal clutch, that is the clutch plates move outwards when throttle lever is pulled. It is a bugger to start. I've got blisters on blisters from the pull cord. My son is 10 and he may well be a little big for his but when it goes, it is fast enough to start kids off with motor bikes. Hope it helps.
Jan 06, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Cycling Logo
35 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
