Question about Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver
What can cause loud humming?
I have a new Bose L1 Model II and a new Mackie DL1608 and when connected I am getting a loud humming? Any suggestions??
  • Bose Expert
  • 43 Answers
The most likely cause of hum with a Bose L1® connected to a mixer is a ground loop. Try connecting the L1® and the mixer to the same power source.
Here is an article specifically about hum with the L1®
Audio System Noise and the L1
Posted on Jan 18, 2015
    New Friend:
How to connect bose 5.1 to mixers
Posted on Jul 16, 2013
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Bose companion II speakers
You mean this adapter: 3.5mm STEREO JACK M TO 2 RCA F ADAPTER
Posted on Aug 15, 2008
SOURCE: Loud hum when Bose Companion 3 Series II speakers are turned on.
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
Posted on Nov 14, 2009
bronk50
  • 27725 Answers
SOURCE: get loud hum from both
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on May 23, 2011
How to hook up bose L1 Model II with two B2
From the Bose instruction manual (wonderful what can be achieved when one reads ;) )...
Bose manuals for L1 and B2 here:
Bose L1 Model II with B2 bass module L1 portable loudspeaker systems...
Aug 06, 2014 | Bose Audio Players & Recorders
The Tone Match unit is not receiving power
If you are using the Bose ToneMatch cable (black cable - the connectors are round barrels with square connectors). Then this should work fine.
If it doesn't then try a different cable. You can use a network Cat-5 cable.
Note - if you are connecting to an L1® Model I or L1® classic then you need an T1 Power Supply.
T1 ToneMatch Audio Engine power supply tone-match-unit-not-receiving-power-l4qeg2fyniuwsgnfiobf0ph3-1-0.png
Apr 26, 2014 | Bose L1 Model II Dual Bass System with...
Can i connect 8 b2 and 4 l1 model 2 and play at the same time as dj
For each Model II Power Stand you can connect one B2, then run the bass line out to a PackLite Power Amp to power a second B2. To do what you want, you will need 4 PackLite Amps.
Bose PackLite power amplifier Model A1 Accessories L1 reg portable...
Mar 19, 2014 | Bose Dual L1 Model II w/ 2 x B2 Sub & T1...
L1 model 2 trim not working with tonematch
The Model II Power Stand Trim only affects the Model II Analog input (1/4" jack).
It has no effect on the signal from the T1®.
Here are some notes:
L1 Model II Bose L1 Encyclopedia FAQ Wiki l1-model-2-trim-not-working-tonematch-l4qeg2fyniuwsgnfiobf0ph3-2-0.png
Jan 28, 2014 | Audio Players & Recorders
Connect Mackie Profx12 to L1 Model II
On the Mackie ProFX12 pan all the inputs to the LEFT and take the LEFT output and ran that to the Model II Power Stand Analog Input. Here is an article with all the details.
Stereo Mixer to Mono L1
Dec 19, 2013 | Mackie ProFX Series ProFX16,...
Mackie dl1608 and Bose l1 humming
This sounds like a ground loop.
Make sure that everything in your signal chain (mixer and anything that plugs into the mixer, and the L1®) are all plugged into the same power source (power bar).
More tips here:
Ground Loop Bose L1 Encyclopedia FAQ Wiki
Jul 11, 2013 | Audio Players & Recorders
Just bought a ProFX8 mixer to connect to my Bose L1 PA system, but as soon as I connect the outputs to the Bose inputs and raise the master fader there is a "ground hum" even without anything...
Make sure you are using BALANCED audio interconnect cables AND that the speakers and the mixer are powered from the SAME receptacle... Yes, this means running extension cords. It is a ground loop problem. You should be using XLR or TRS cables BALANCED cables from the mixer to the basss unit of the L1 system. The bass unit and the mixer MUST be powered from the same receptacle to avoid ground loops and hum.
Aug 17, 2011 | Mackie ProFX8 Professional Compact Mixer
Get loud hum from both bose companion II speakers when i disconnect left speaker hum goes away tried most everything else thanks
hope this helps
May 23, 2011 | Bose Companion II Computer Speakers
Jun 28, 2009 | Bose Companion 3 Series II Multimedia...
Loud hum with static when speakers turned on
There is def. a loose connection somewhere in your system. This is a grounding problem within the system if nothing else. Def. a "lazy" connection somewhere.
gurutim
Mar 10, 2009 | Bose Companion 3 Series II Multimedia...
Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver Logo
631 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
