How to solve the hanging problem of yamaha psr3000
Please ans
2 Suggested Answers
mosesmos1
SOURCE: 16TRACK SONG RECORDING IN 'YAMAHA PSR3000'
i have yamaha psr 3000...
in my keyboard has some problem like system error...
when i switch on my keyboard this problem is arises...
please help me....
Posted on Dec 07, 2009
Yamaha psr4000 no sound when i play keys
To start with try a master reset, whilst the instrument is off press and hold the top (highest) sounding key whilst turning on.
When the screen displays Yamaha release the top key.
If this doesn't solve the issue then it could be a number of things as the keyboard does a self check on startup and will hang if a fault is found. Check each rubber switch is not stuck down or even missing this can cause this issue. Please report back either way.
Dan
Becketts Music Ltd
May 18, 2017 | Yamaha Music
Yamaha psr-e333. Can switch on but cannot play even the grandpiano func. Its just "yamaha" written on the display..
Dan
Becketts Music Ltd
Apr 28, 2017 | Yamaha Music
2000 r1 idle hangs
Hi, Anonymous and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/2-general-motorcycle-discussions/339738-annoying-hanging-idle-2000-r1.html
Doesnt like returning to idle
Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Oct 12, 2013 | 2005 Yamaha YZF-R1
Laptop hanging
Please change the Browser as i was facing the same problem i recommend you to install Mozilla firefox it's an awesome browser supports everything...
I hope it will help you if you have not solved yet give me more details so i could be able to sort which kindda problem you are facing.
Jul 03, 2013 | Acer Computers & Internet
Hi, I own a Tyros 1 which gave me a lot of pleasure the past almost ten years. I installed a hard drive about a year ago and loaded a large number of extra arrangements. A problem developed recently. At...
Hi.
Try holding down the rightmost white key while powering up the keyboard. This is a minor system restoration, which may solve your problem.
Below is a way to run diagnostics as well >>>>
DIAGNOSTIC TEST:
if you think there might be something wrong with your board, you can have it perform several tests to see if all works well.
1. Power off
2. press C2# - F2 - G2# (all three together) and while keeping them depressed,
3. switch the power on.
You'll see the word "TEST" on the display
With Tempo - / + you can go to the test you want to perform. Start/Stop will start the test. Wait till a test is done!
You can check following items :
001 : Version
002 : Rom Check 1
003 : Ram Check 1
004 : flash Check 1
005 : Wave rom Check 1
006 : Effect ram Check
007 : TG 1 Check
014 : Pitch Check
015 : Output R Check
016 : Output L Check
019 : EQ low Check
020 : EQ mid Check
021 : EQ high Check
023 : Mute Check
025 : MIC Test (PSR3000)
027 : Sw, Led Check
028 : All panel led on Check
029 : Red led On Check
030 : green led On Check
033 : All LCD on Check
034 : All LCD off Check
036 : LCD Brightness Check
037 : LCD Pattern Check
040 : Pitbend wheel Check
041 : Moduration wheel Check
046 : Padal 1 Check
047 : Padal 2 Check
053 : Midi Check
055 : Video out NTSC RGB (PSR3000)
056 : Video out PAL RGB (PSR3000)
057 : USB To Device / Host Check
058 : USB Storage Device Check
059 : Card Check
061 : Keyboard Type Check
067 : Rom Check 2
068 : Ram Check 2
069 : flash Check 2
070 : Wave rom Check 2
071 : Effect ram Check 2
088 : Factory set
089 : Test End
When at 086, press Start/Stop to exit the test mode and your keyboard will continue to start up normally.
Good luck and regards.
Jan 01, 2013 | Computers & Internet
Red marks on start-up screen on yamaha psr3000
It is possible after 6 years of use some of the component values of components on the circuit boards are begining to shift. Some electrolytic capacitors may be in the early stages of failure, short of a large investment in time and testing of components, there is no simple quick fix.
One broad brush approach might be to replace all the electrolytic capacitors with newer polymer types, they are more expensive, but also much more stable and durable.
Apr 03, 2012 | Music
I have recorded a song on the psr3000 in midi format. i want to delete some parts of this song. can someone help
I can't seem to get the manual but I will guess that your keyboard doesn't have the onboard facility to do that. You may need an external computer program to do it. Here is a link that explains:http://www.psrtutorial.com/util/index.html You may need to download some drivers as well so here is the link:http://usa.yamaha.com/products/musical-instruments/keyboards/arranger_workstations/psr-3000/?mode=model Here is a link to some good freeware and shareware midi sequencing programs:http://www.hitsquad.com/smm/win95/MIDI_SEQUENCERS/ There is a selection for all platforms not just Windows95.
Nov 08, 2010 | Yamaha Music
Intermittent continuous booting issue.
Your processor is over heating you need a new fan might need a new processor also it depend how hot you got it.
Oct 14, 2009 | Computers & Internet
please help me....
Apr 29, 2008 | Yamaha Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
