FixYa.com
Tags:
RCA Burner
Help with JVC CDRW 121 It doesn't recognize the... (by 2 users)
By Bray - usenet poster
I need help trying to figure out how to fix my CDRW121.  It has
stopped recognizing the blank CDRs.  I have cleaned the lenses at no
avail.  I also replaced three of the melted capacitors but the
equipment still doesn't work properly.  Any ideas?  Has anyone else
had this problem with this product?
GOMER
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by petersweetma, posted on Jan 27, 2008
rca cdrw cdr 121 burner
Best Solution
posted on Aug 08, 2005
FixYa! (100)
Kim1
Kim1 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The manufactures never give out any technical information or service
information about how these work for their particular design. If you have
some components that have been overheated or damaged, you can be sure that
there will also be some more serious damage.  You would have to troubleshoot
the drive at the component level, using the proper test facilities to
determine the exact failed devices.
The obstacles would be to have the proper test and diagnostics equipment,
and to have replacement parts for the proprietary parts.  You would be
economically and in a practical sense be better off to replace the drive
with a new one.  It may even be a question of being able to do a laser,
servo, and tracking alignment.  This is all done at the factory when
assembled, through service software, with the service CD disks.
Other than any simple mechanical fixes, or a simple electrical fix, I have
never seen anyone have much success at servicing one of these drives at the
component level.
Greetings,
Jerry Greenberg       GLG Technologies GLG===========================­==============
WebPage         http://www.zoom-one.com
Electronics        http://www.zoom-one.com/electr on.htm
Instruments       http://www.zoom-one.com/glgtec h.htm
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 19, 2007
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
I had a problem with a cdrw121 with it stopping right in the middle of a recording, but showing the cd as being full. I suspected a heating buildup problem with the write laser and added a small (30mmX30mm) cooling fan inside the cabinet blowing just a breath of cool air into a small opening in the enclosure that houses the write transport mechanism. This did the trick and I have not had any problems since. I can now write 79min 59sec cd's continuously for 8-10 hours straight. The fan was a 12 volt 80ma unit and I powered it from one of the ribbon cables that carried 12 volts and ground. The only other issue that seems to cause problems with this unit is that you must use recordable audio cd's. They have a flag prerecorde onto them that this system looks for, as do many audio cd players. This is very important.
Solution #3
Helpful (85)
Cato
Cato - usenet poster
Rating: 0%, 0 votes
That is an RCA, not a JVC, yes?
Make sure you're using CD-R AUDIO blanks. Not much else you can do - the
recorder portion is not a serviceable part, it's replaced a a whole
assembly, and way too expensive for an out-of-warranty repair.
Mark Z.
Can you Help with these CD and DVD Burners problems?
CD and DVD Burners
dvd burner question
I only have one slot for a... Answer This...
CD and DVD Burners
acer dvd burner
wont write to dvd +r Answer This...
CD and DVD Burners
puk codes
i need a puk code as my phone... Answer This...
CD and DVD Burners
Dvd writer problem
My systor dvd duplicator can't... Answer This...
CD and DVD Burners
Mp3 Mom
Can I send an Mp3 via e-mail to... Answer This...
Repair Service
Find CD and DVD Burner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
