Question about Cell Phones
What are the applications of magnetic gradiometers?
Magnetic gradiometers are used by archaeologists for exploring sites with minimum damage to the surroundings. They are relatively easy to use and cost efficient.
Posted on Jul 11, 2013
PLEASE PROVIDE MY PUK NUMBER MY THIS MOBILE NO. 8858819223
Do you have blank magstripe cards
Yes we do. Order minimum is 100 cards.
$25 for Low Coercivity - LoCo
$35 for High Coercivity - HiCo
What does Coercivity Mean?
Coercivity is the term used to designate how strong a magnetic field must be to affect data encoded on the stripe, and therefore, how immune the data is to damage.
Measured in Oersteds (Oe), the coercivity of a common credit card is about 300 Oe, considered low coercivity. Consequently magnetic money clips, refrigerator magnets, etc., play havoc with the data on your credit card's stripe. High coercivity (HiCo) magnetic stripe technology relies on particles -- generally barium ferrite (low coercivity uses iron oxide) -- with coercivity values ranging from 2500 to 4000 Oe.
The encoding technique is the same as for LoCo technology, except that it requires a stronger electrical current in the write head. Virtually immune to domestic-type magnets, HiCo substantially decreases the chances of accidental data erasure. Despite this superiority, HiCo hasn't yet replaced LoCo technology, due to the widely established base of LoCo encoders and the increased cost of HiCo encoders. Standard magnetic stripe readers, however, can read either HiCo or LoCo stripes.
High-coercivity cards are currently used in applications where the need for performance, for example in critical test equipment, outweighs price. A single magnetic stripe can hold several tracks of recorded data, which can be rewritten and updated. The ISO\IEC 7810, 11, 12, and 13 series of standards specify a three-track format, encoding scheme, and bit density for all financial card applications.
http://www.smartcardsupply.com/Content/Cards/magstripe.htm
Jun 21, 2016 | Computers & Internet
Which monono laser printer suits for extra dark printing on butter paper i tried almost. Pl guide
Dear Rajendra
You can choose any laser printer with printing resolution 600-1200 dpi. According to the type of toner non-magnetic toner will perform the best and lasts long without deterioration of its color. Before buying the choosed model you may download the driver and verify the setting procedures to confirm. Also if you are going for prepare for master the driver setting should have option for lower the dpi up to 300 , in case of screen print application. Few manfs are hp,canon used magnetic toner where as samsung,brother,konica minolata etc. are used non-magnetic toner on their low/ middle segment.
Thanks.
Jan 12, 2015 | Laser Office Equipment & Supplies
What are the uses of magneto meter?
I don't work on motor cycles
Oct 30, 2013 | Motorcycles
What are the applications of very low frequency electromagnetics?
Very low frequency electromagnetics is used in mineral exploration and water exploration. In the air VLF is used with it's airborne optically pumped gradiometer magnetometer systems.
Jul 31, 2013 | Garmin Gmu 44 Magnetometer P/n...
What is a part called pick up for a 1997 honda civic ex
My best guess, is this what you are asking for.
MSD NON-MAGNETIC PICKUP ASSEMBLY -- For V-6 even-fire applications; 0.75 x 16 x 2.25 in. thread size, 72 in. harness; Engineered for extreme applications; Designed and tested on 300 plus mph top fuel dragsters; Each pick-up is hand wound on a special bobbin and terminated to tinned conductor Teflon jacketed wiring and undergoes a vacuum procedure to remove any air inside the housing; Features wires that are routed through a strain relief for protection; The assembly is installed into precision housing and is potted with a fracture resistant epoxy compound; For MSD flying magnet crank trigger kits.
Apr 07, 2013 | Vehicle Parts & Accessories
I have an application whereby I want to glue a magnet to the back of the watch and attach it to a metal shroud. I need to remove it and reattach it to the shroud several times a day. Will the operation...
Generally an LCD watch is not affected by magnetism. A mechanical or quartz watch will be effected. My advice is to set a magnet on the watch and see what happens. A mechanical and quartz(or any watch with analog hands) will stop. Michael
May 24, 2011 | Sportline 220 Sport Timer Stopwatch ...
It does not turn on. The LCD was blank before last turn off.
Hi, it is because there could any one of the resoan
1) The BlackBerry smartphone battery is depleted.
Replace the BlackBerry smartphone battery or recharge the smartphone by connecting it to the personal computer.
2) Magnetic or static interference is obstructing the BlackBerry smartphone.
Move the BlackBerry smartphone away from magnets or the source of static interference and perform a hard reset.
a) Remove the battery cover from the back of the BlackBerry smartphone.
b) Remove the battery, and then reinsert it after a few seconds.
c) Replace the battery cover
3) When running Application Loader, a problem occurs.
Erase and reload the data on the BlackBerry smartphone:
a) In BlackBerry Desktop Manager, open Application Loader. b) Click Next. The Handheld Application Selection window appears.
c) Verify correct applications are selected and clickNext.
d) Click Advanced.
e) Select the Erase all application data and Erase all currently installed applications option and clickNext.
f) Click Finish. The data on the BlackBerry smartphone is erased and reloaded.
If this procedure does not resolve the problem, contact your technical support representative or blackberry service centre.
Hope this information will be helpfull for you.
Oct 16, 2009 | RIM BlackBerry Bold 9000 Smartphone
2003 Toyota 4 runner Issues
Replace your magnetic clutch relay.
TSB EL011-05 : A/C LIGHT FLASHING - MAGNETIC CLUTCH RELAY 6/3/2005 - 2001 – 2004 Toyota Camry, ECHO, & Celica. 2002 – 2004 4Runner, Corolla, & MR2 Spyder. 2003 – 2004 Matrix, Sienna, & Solara. This bulletin is to provide information regarding countermeasures to the A/C magnetic clutch relay for A/C light flashing (inoperative A/C) issues on some vehicles equipped with a magnetic clutch compressor.
Applicable Warranty*:
This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for 36 months or 36,000 miles, Whichever occurs first, from the vehicle’s in-service date.
* Warranty application is limited to correction of a problem based upon a customer’s specific complaint
Sep 02, 2008 | 2003 Toyota 4Runner
Instructions for use
SoftPay is a marketing term that Verifone uses for a set of terminal applications which share some common code. When you see a terminal splash screen saying "Powered by SoftPay" that means that the application running in the terminal was written using the SoftPay modules.
Because there are a number of different SoftPay applications, there is no one single key to that feature. There isn't a single inclusive set of all features of all versions of SoftPay applications. Each application is different because it is written for a different processor.
Jun 28, 2008 | VeriFone (M19755014US1) Magnetic Card...
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
