Broken machine for making glasses
Glasses are turning 60 degrees wrong
The head was done and I need the torque setting for this vehicle.
M10 bolts: 1st step; - 18 ft./lbs. 2nd step; - turn 60 degrees 3rd step; - turn 60 degrees M12 bolts: 1st step; - 22 ft./lbs. 2nd step; - turn 60 degrees 3rd step; - turn 60 degrees
2.0 Engine
Feb 02, 2016 | 2005 Hyundai Tucson
Aquarius wt745 hotpoint machine need to reset the pogram - as machine program not working properly
You have said "Every Program" but I'd like to make sure that's the case. The issue you're describing is highly unlikely to be programming. More likely I would suggest, is that the heater in the machine has failed. As a result, a 60 minute program (Which is planned to take 60 minutes taking into account the average time the water takes to heat up), will run for AGES while the machine waits for the heter to get the water up to temperature, which it can't because the heater is dead. Firstly, test this theory by running a 60 degree wash and feeling the door glass after 20 minutes. It should be HOT, my guess is it will be cold. Also, If I'm right, a cold wash program will run fine (Rinse and spin for instance) As will spin and pump out settings. If this isn't the case, then there is a possibility of a blockage. Though you have said the pump works, I would suggest disconnecting the waste pipe from your drain and putting it into a bucket. Fill the machine and then pump out. The water should FLOOD out VERY fast. If it's slow or a trickle, there is a blockage in the pipe or pump.
Sep 06, 2015 | Hotpoint Washing Machines
60 degree wash wont spin
Would it not take time to heat up water to 60 degree temp before it starts to spin ?
May 03, 2014 | Zanussi Washing Machines
I have a customer who has a Warm Morning direct vent propane heater: model DV.203 AMA. His complaint is the thermostat does not seem to work properly. The dial is turned to the lowest setting and it...
Some thermostats have a default lower limit such as 60 degrees to prevent complete loss of heating. The lower limit is not set by the user.
Nov 19, 2013 | Heating & Cooling
Water too hot
Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well.
Jul 20, 2011 | Washing Machines
High suction press (98psi), normal head press (140psi); full sight glass;low super heat (10 degrees);normal subcooling (13 degrees) new txv, new evaporator, new condensing unit 70 degree air from vents ...
lower fan speed.....and double check head pressure, sounds very low!!! should be around 250-275.....also make sure the return air grill is large enough.
Aug 09, 2010 | Goodman CLQ36AR49 Air Conditioner
Find cos 32° 45'
Look at the column of keys under the ALPHA key. You have the integral, the square root, and then the key that has a degree sign, an apostrophe and a double closing quotation mark. That is the one you use to enter the angle in sexagesimal notation. To simplify my task I will symbolize the key with [DMS], degree, minute , second.
To calculate cos (32° 45')
you press
[COS] 32[DMS]45 [DMS] ) and press [=] The result si 0.841039013
Hope it helps.
Nov 08, 2009 | Casio FX-115ES Scientific Calculator
Spin and agitator not working
VERY POSSIBLY THE MOTOR/GEARBOX COUPLING HAS BROKEN. NEEDS TO BE REPLACED. SWITCH WASHER OFF THEN TILT WASHER 60 DEGREES BACKWARDS AND CHECK COUPLING. THERE IS A KIT WHICH CAN BE BOUGHT. DEFINATELY A D.I.Y. REPAIR.
Aug 17, 2007 | Whirlpool LSB6200KQ Top Load Washer
DIal is misaligned!
It could be a faulty water heater stat ,or the hot and cold fill pipes are the wrong way round. close Ireland bye bye
Sep 01, 2006 | Tricity Bendix WDR1040W Front Load Washer...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
