Toshiba es 230 error ca10 - Office Equipment & Supplies
3 Suggested Answers
  • 628 Answers
SOURCE: display F120 error in my Toshiba etudio 230
F120 indicates database abnormality.
What u can do:
1. Rebuild the database ( 08-684 )
2. If the error is not recovered, initialize the HDD. (Enter “2” at 08-690.)
PS: Press "0+8" & ON the machine in order to enter setting mode.
Posted on Jul 29, 2009
rezazadeh
  • 328 Answers
SOURCE: I need to how what ERROR CA10 in a Toshiba e-600
problem in laser unit.most popular in polygun motor
Posted on May 27, 2010
What does call for service F 070, in toshiba e studio 230, refer to ? How can I solve the problem?
Toshiba Studio 230 Error Codes
Toshiba e-Studio 230 Error Codes Code: F070
Code
F070
Description
Communication error between System-CPU and Engine- CPU
Sep 30, 2016 | Toshiba E-studio 230 Multifunction Copier
Toshiba Estudio 230 Screen frozen
actualizar el firmware de la copiadora, disco duro formateado Sustituir si es necesario
Sep 05, 2016 | Toshiba E-studio 230 Multifunction Copier
Error toshiba e720 c370
Segun El Ribbon de toshiba me dice que la tarjeta de SyS es igual de la toshiba E-455 a la de la E-855. El problema es como hago la transformacion de version 455 a 855 . Mi pregunta es como hago o cual es el procedimiento . Gracias
Feb 12, 2014 | Toshiba E-STUDIO 850 Copier
Toshiba E-studio 230 Copier shows this message call for service 631012
Well, first of all Francis, that isn't your error code, that's your meter (the odometer of the copier so to speak). Error codes will show C--- or E---
examples are C447 (fuser error) or E010 (fuser related jam)
Jan 10, 2013 | Toshiba E-studio 230 Copier W/net Print,...
Clear maintenance counter es 162f
Hi:
Press # * clr * then key in main code 20 sub code 01 and press the start button . Then press the function clr button twice to get back in normal mode.
Andrew
Jul 07, 2012 | Toshiba Office Equipment & Supplies
Error code "CA10"
Hi how are you this is jack .....(jack_pak@hotmail.com).. my personal ID.
Laser optical unit related service call
[CA10] Polygonal motor abnormality
Is the polygonal motor rotating?
NO 1. Check if the connector CN352 on the LGC board is disconnected.
2. Check if the harness is open-circuited or the connector pin is disconnected.
3. Check if the conductor pattern on the LGC board is short- or open-circuited.
4. Replace the laser optical unit.
5. Replace the LGC board.
YES
Is the printed image distorted?
YES 1. Check if the connector CN352 on the LGC board is almost disconnected.
2. Check if the harness is almost open-circuited or the connector pin is almost
disconnected.
4. Check if the laser unit cooling fan is stopped.
5. Check if the suction area of laser unit cooling fan is plugged up.
6. Replace the laser optical unit.
7. Replace the LGC board.
Thanks
Best Regards,
Aug 05, 2010 | Toshiba E-Studio 3511 Color Copier
The display on my ST-CA10 is out of function
have u solved the display problem?
i have the same problem.
tell me please, if you solved it...what should i do to make it work.
thanks
lin-q@hotmail.com
Jul 30, 2010 | Technics Audio Players & Recorders
I need to how what ERROR CA10 in a Toshiba e-600 mean.
May 24, 2010 | Toshiba E-Studio 3511 Color Copier
Display F120 error in my Toshiba etudio 230
What u can do:
Jul 28, 2009 | Toshiba e-Studio 232 Black and White...
20 people viewed this question
k24674
