Question about Radio Communications
Haw do i program a uniden bearcat 210xl scaner
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
You may download a copy of the manual at http://www.repeater-builder.com/uniden/pdf/uniden-bearcat-bc210xl-owners-man.pdf. Programming instructions are on page 7.
Posted on Jul 11, 2013
  • John
    John Jul 14, 2014
    The Bearcat 210 was the best of it's kind when it was introduced. Simply go manually to the channel you want to program, enter the frequency, then program, and then scan, and it should be in the scan rotation. Go to the manual if you want, but it's pretty easy to program. Make sure your frequency in within the range of the radio, and it must be ANALOG radio. This will NOT do DIGITAL radio and will not do 800MHz radios.
5 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: how to program a bc855xlt uniden bearcat scanning
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Posted on Jan 19, 2010
Mechanic688
  • 204 Answers
SOURCE: programing for uniden bearcat scanner bc 144xl
danval, I looked up a pic of your scanner and it is pretty straightforward. If it is the 16 channel I was looking at, here is the step by step programming.
1- Push manual button to go to the channel you want to start programming.
2- Enter the freq number in.
3- Push the E button to enter it in the memory.
4- To review what you programmed, push the Review button.
5- Use manual button to step to next channel and start over from #2
That should get you started with the scanning hobby.
The scanner has a Priority button that when activated will stop scanning and go immediatly to the priority channel if someone keys their mic.
If you need freq's (or more of) for your area, go here and click on your state and county and it'll give you a complete listing.
http://www.radioreference.com/apps/db/
Hope this helps you out, let us know,, Mechanic
Posted on Feb 12, 2008
SOURCE: How do I Program my Uniden Bearcat BC60XLT
how do I program bc60xlt handheld scanner
Posted on Jun 08, 2009
  • 160 Answers
SOURCE: how do i program my uniden bearcat BC350A
you don't, it's already programed
Posted on Jun 12, 2009
How do i progam my bear cat 210 xlz
The 210XL and the 210XLT are nearly identical except for the number of channels, so the 210XL manual should answer any questions you have. You can download and print the manual, at no cost, here:
http://f1.grp.yahoofs.com/v1/wJJ9TdG7Qk65ge9CsRfSuB42k0iiifl8mcGykyii5QiwRK3zlwQQplAZxqlhZNnV_WVX1Yrx0R94b46AAHcoFLxBBlKrQFM/Bearcat-210xl.pdf
Bill B.
Listening in professionally since the 60's
Mar 13, 2011 | Radio Communications
Looking for a manuel for a BC 340 CRS Scaner
You can download and print your manual, at no cost, here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC340CRS%20%28Manual%29.pdf
Bill B.
Listening in since the 60's
Nov 19, 2010 | Uniden BC340CRS Base Scanner
Speaker hum in Bearcat 210XL Scanner.
Nice old scanner, key word is old. Probably an electrolytic capacitor in the power supply is dried-up and needs replacement. Do you get the hum if you operate the radio off of 12VDC?
Jan 15, 2010 | Uniden BC350 Base Scanner
Do they still sell Bearcat 210xl scanner My Dad purchased it back in Oct of 1980... The Seriel Number on it is 4149 Do you know what he would have paid for it back then. Thanks.
They have updated this model many times, so no, they don't sell it anymore. In the '80's he would have paid about $50 for it new. Current value is about $30 or so ....
Nov 20, 2009 | Uniden TRUNKTRACKER III
Looking for a operations manual for a bearcat 150 scanner table top model
I couldn't find the manual for your exact model, but here is a link to the 210XL. Many of the features should be the same.
Oct 02, 2009 | Office Equipment & Supplies
How to program a bc 560xlt bearcat scanner. Thanks, Les. lorlick@yahoo.com
hello there: here is a link for you that will help out ok
best regards mike
How to Program a Uniden Bearcat Scanner BC 140 | eHow.com How to Program a Uniden Bearcat Scanner BC 140. Programming a Uniden Bearcat ... How to Program a Bearcat 5 Scanner. How to Program a BC 560XLT Scanner ...
www.ehow.com/how_5009391_program-uniden-bearcat-scanner-bc.html - 57k -
Aug 24, 2009 | Office Equipment & Supplies
Bearcat scanner 210xl program manual
Here Is A Users Manual For The Uniden Bearcat 210XL 18 Channel Programmable Scanner.
Just Follow This Link And Save or Print It Out In .pdf Format.........
I Myself Used My Dell Laserjet And Printed It As (2) two Sided Pages And Have A Nice Looking Manual. It Is A Complete Instruction Manual That Tells You How To Set It Up!
Jan 24, 2008 | Uniden TRUNKTRACKER III
How to program my uniden bearcat BC350A scaner.
Here is a link to the owners manual for this scanner:
http://www.uniden.com/pdf/BC350Aom.pdf
page 14 begins the procedure for programing the frequencies.
Dean
Rollin CBs
Dec 05, 2007 | Radio Communications
Radio Communications Logo
109 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
