Question about Chevrolet seal. hydraulic power brake booster. spacer. air brake
97 chevy
Icant get my brakes to pressure up
  • Chevrolet Master
  • 15,557 Answers
Have you bled the air out?
Posted on Jul 21, 2013
The back brakes system on my 97 chevy lumina
the following link shows how to replace and adjust the rear brake shoes for chevy lumina
97 lumina rear brakes Yahoo Video Search Results
Jul 04, 2016 | Cars & Trucks
My 97 Chevy blazer won't start I hear the fuel
Bad fuel pump, fuel filter, it may not have enough pressure or you aren't getting spark
Jul 29, 2013 | Cars & Trucks
97 chevy suburban AC clutch won't engage pressures
Looks like the low pressure switch gets power from a 10amp ac fuse. Power then goes to the ac relay which is powered on by the ac heat controller on the dash. Power then goes thru the high pressure switch to the compressor. The ac relay is grounded to the body. Do you have power on the lite and dark green wires going into the relay and is it grounded ?
Jul 26, 2013 | Cars & Trucks
97 chevy suburban k1500 brake lights work when barely touched then go off when pressed harder
Check your Brake Switch on the Back of your Brake Pedal, you have loose wires or your switch is not working properly
Apr 09, 2013 | 1997 Chevrolet K1500
97 Chevy S10 rear end squeek that goes away when brakes are applied
If you have rear disc brakes, one of the rotors could be warped and causing the pads to move in the caliper.
You should be able to remove one wheel at a time, lock down the rotor with the lug nuts, and put the trans in low gear or reverse to listen for the noise.
Jan 14, 2013 | 1997 Chevrolet S-10 Pickup
I have a 97 chevy c3500. the left front brake was locking up while driving. i replaced the caliper and bled and am still having the same problem. the right front brake is fine as well as the rear brakes. ...
sounds like the brake hose has colasped not letting the fluid return back from the caliper, common promblem on chevrolet another sign is it will pull to the right when braking hope this helps.
Aug 15, 2011 | Chevrolet C3500 Cars & Trucks
97 Chevy Suburban. Front left brake caliper apllies brake pressure but will not close when pressure to the pedal is relieved. We replaced both calipers (drum brakes on back) but the problem is still there....
i would have to say the master brake cylinder is at fault. there are ports in the cylinder that allow fluid back into the reservoir. these ports may be clogged. or the brake hose/line is clogged. have you changed the brake hose?
Mar 27, 2010 | 1997 Chevrolet Suburban
97 chevy truck 1500 gear shift gets stuck in park
You can remove the interlock off the gear shift or maybe spray some crc on it otherwise probably a loose wire or switch
Jul 09, 2009 | 1999 Chevrolet S-10 Pickup
Chevrolet seal. hydraulic power brake booster. spacer. air brake Logo
46 people viewed this question
Top Chevrolet Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Chevrolet Air Tool and Compressor Expert? Answer questions, earn points and help others
