when i power on and it come with the compaq screen it go right into the safe mode it have some option there . if you what to log on 1 log on nomal 2. log on using boot.ext 3 safe mode 4. step by step if i select anything it will go into the safe modewhen i power on and it come with the compaq screen it go right into the safe mode it have some option there . if you what to log on
1 log on nomal
3 safe mode
4. step by step
You can't post conmments that contain an email address.
Provide more description regarding your issue.
Is there any error message when you try to boot without safe mode?
Does the computer just boot to safe mode without asking you anything?
Andy
It's very hard to troubleshoot without seeing the computer.
I think the easiest thin that I can tell you would be to boot in save mode.
Backup your data to a USB drive and reinstall Windows using the factory restore disk.
AndyIt's very hard to troubleshoot without seeing the computer.
Andy
Boot the computer into safe mode (tapping F8 while it is booting) and select the Administrator account. From there, go into control panel>user accounts.
Select the user account you need to access, modify password (you won't need to enter the current password in this mode).
Did this resolve your issue? If so, please rate it. ty.
Start your computer in safe mode (tap F8 key when starting up) then log into safe mode as administrator then go to user accounts and remove password from any account set up on computer. Restart and your done.
Try to load to safe mode ,do this after restarting the pc and before loading to windows hit F8, and chose safe mode, when u load to safe mode try to change the setting, hit apply and ok, then load to windows normally and let me know wat happen?
Maybe it has come to got error in the system files or you were infected with a potent virus, try to boot your system in safe mode by pressing "F8" at first boot. select with network connection. scan your system online like panda online scan( go to panda website).
on safe mode You can also restore your system at the previous date where in the system is functional.
else if this not work then you have to clean install the system by reformatting and reinstallation of the OS. ( you can search the document in installing windows in google.) but first back up your important files before proceeding.
goto start --> run --> type msconfig --> there should be a option to change to the boot tab, under boot options tick safe mode off. and press apply and then ok and restart your computer
Does your desktop comeup and give any time before it shutdowns, say 1 minute or something like that,
You can log into safe mode and do system restore by pressing F8 once you power on the computer, but you need to keep on pressing till you see the safe mode option.
1 log on nomal
3 safe mode
4. step by step
