Question about Coffee Makers & Espresso Machines
Got a genesis compact steamer but it is blocked. It is heating but when I press release button it does not releasethe steam
  • 2039 Answers
SOURCE: blocked steamer outlet /frother tube
hello take the pipe put it in a solution of calcium remover leave it in for a couple a day calcium in pipe is like concrete after a day or so try to pass a steel wire in it the calcium gonna get softer everything gonna come of after take the same product fill the machine run the machine with it for a good clean up most of the people loose good expresso machine because of hard water a clean up every few month it gonna work good and our coffee gonna be warmer .p.s when you use special cleaner rinse the machine very good the cleaner is very corrosif cheers
Posted on Jan 15, 2008
SOURCE: Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Posted on Mar 17, 2008
mirran
  • 515 Answers
SOURCE: making froth
try to make a cup of water after you used steam, you have to cool down the boiler.
Posted on Aug 08, 2008
  • 105 Answers
SOURCE: steamer on Elna press electronic
if you go to... http://www.elnausa.com/ and under contact us they may be able to help you with a manual and if your press is working.
Posted on Sep 27, 2008
  • 29 Answers
SOURCE: My Steam Vac won't release any soap water mix
My model number Bissell is different than yours, but many models work similarly.
Capt. Obvious fixes: Water flow often stops unless both water and soap tanks have liquids. Also make sure the dial is set to Floor Cleaning, not Tool Cleaning or somewhere in between.
Sometimes an air pocket inside the machine (even a new one) keeps water from flowing, until you reprime the Bissell's internal pumps. To prime the pumps the easy way, turn it on, then press, hold, and release the water-and-soap trigger a few times, waiting a few seconds each time.
Still nothing? Prime it the slightly harder way. Separate the two water tank pieces. Only have the base tank filled and mounted on the Bissell without the piece that sits atop the tank. Turn it on. Kneeling on the floor in front of the Bissell, reach up and press the soap and water trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel just a bit of suction. Lift your hand up and down a few times, a few seconds apart. Release the trigger and repeat a few times.
Still no liquids? If your Bissell has been used at least a few times, particularly if you didn't thoroughly clean the machine when finished, but after a year or so in a hard-water area like mine even if you are good about cleaning it, the water sprayers on your Bissell may have clogged with mineral deposits. This is a *fairly* easy thing to fix yourself, but please read all the way to the end and check out the GOTCHA before trying this.
Unplug the Bissell. Remove the water tank pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your roller brushes when you press the water-and-soap trigger at the top of the Bissell's handle, and tend to clog with mineral deposits.
Only work on one sprayer at a time so you can see how it goes back together.
As you squeeze the red plastic sides of one red water sprayer, push up on the underside of the sprayer from underneath the bottom unit of the Bissell to release the sprayer from its mount in the base. Clean any lint or debris out of the mount area. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove one water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip up the hose so it compresses the spring and is no longer on the red plastic water sprayer. (See GOTCHA about the spring, below.)
With the clip released, now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the end of the red water sprayer that was inside the hose in your mouth and seal your lips around it, and try blowing through it. If you can't blow air through it, it's clogged. Open up a paper clip and push it back-and-forth through the small hole in the hose end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Click the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
The GOTCHA: Once when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. It’s best to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, fix this by removing the six screws on top of the Bissell base (this is the surface the water tank mounts on top of), and pry it up. Pull out the hose, reattach the red water sprayers on the hose, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
You might want to prime the pumps again (instructions above). If the sprayers are clear, and the pumps are primed, but it still doesn't get the floor wet when it should, the problem may be more serious. You may a pump or motor inside the unit replaced.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Thoroughly rinse out and empty both water tank pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and get all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and needs more pampering than a vacuum cleaner, doesn't it??
Posted on May 31, 2009
Shark Super Steamer
The steam generator is defective.
Aug 28, 2016 | Euro-Pro Shark Super Steamer
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
Shark press & release won't heat or steam
Yes, the heating element needs to be replaced which can be done by any competant electrician.
Mar 21, 2014 | Shark Press & Refresh Fabric Steamer...
Steam will not travel through hose scunci steamer ss1000
Blocked with limescale maybe? if its heating to correct temperature to disperse steam then I has to be blocked, that or its not heating up to boiling heat
Mar 03, 2014 | Vacuums
How to get canister steamer to steam
It seems like defective valve outside boiler
Dec 08, 2013 | Steamfast Heating & Cooling
Euro-flex monster baby 1000 watt will not release steam
try running a descale through the unit. probably blocked with mineral deposits. Descaler available at most steamer retailers
Sep 20, 2009 | EuroSteam Vapor Steam Cleaner Vacuum
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Coffee Makers & Espresso Machines Logo
71 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
