Question about Radio Communications
Octo bt3 - Octopus Bluetooth - How to pair with a new iPhone. Previously had a nokia
SOURCE: My nokia E63 wont find bluetooth headset
I had a similar problem with my headset.. but found the solution.. I am using Jabra 2010.. ok.. so just switch "off" the headset...go to the pair menu on e63.. then switch on the headset.. and then look for new pair devices option.. voila it came up. hv been trying for almost 3 weeks before i got the sequence right.. somehow if u had switched the headset on beforehand.. it wouldnt recognise it only.. the solution is here at jabra website .. although.. they dont hv e63 listed .. but the same procedure for e71 worked fine for my handset..
Posted on Aug 05, 2009
EdNelson
  • 149 Answers
SOURCE: My iPhone 4 bluetooth won't
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode ***(usually you have to hold the power button for 7-10 seconds)***
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Posted on Jan 04, 2011
Tekmekanik
  • 34 Answers
SOURCE: I cannot remember how to pair BlueAnt bluetooth to new devices
You will need to set the Z9 into pairing mode before your iPhone will find it.
The manual for the z9 is here
With the Z9 OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start flashing. The Z9 is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes.
Enter Passkey "0000" when your phone prompts you. The phone and Z9 will now Pair.
Posted on Mar 10, 2009
bob_computer
  • 3153 Answers
SOURCE: cannot pair my Emerson EM-227 wireless headset with my Iphone
Some headsets have a built in code not all are 0000 check your documentaion for both the phone and headset
Posted on Aug 08, 2009
SOURCE: How can I pair the anycom ARIS-21 bluetooth with
Just push the button for a long time until the led is not flashing but the colors of the led are changing red and green. I connected it to my laptop and my phone too.
Posted on Sep 27, 2010
Why can't I pair iPhone 4s with 2008 BMW
make sure your bluetooth is turned on by going to settings>bluetooth
Jul 19, 2014 | Apple Iphone 4s I Phone 4 S Factory...
My octopus leaks from the head (not the hose). Could it be an internal problem?
A rebuild or simple adjustment can make it stop leaking if it is coming out of mouth piece if it is leaking from anywhere but mouthpiece or hose connection it needs service.
Mar 26, 2012 | Oceanic Swivel Octopus, Scuba Diving...
When I first bought the product I had no problem pairing it with my 16 gig iPhone. Since replacing that phone with the 32 gig iPhone I have been unable to pair the plantronics K100 with my new phone. Why...
One possibility: If your new phone is paired but not connected because the K100 is looking for the old phone. When powering on the K100 it searches for the last connected cell phone. If the last connected phone is not within range, or the Bluetooth feature is turned off on the phone (which hopefully the first iPhone is turned off or at least out of range), then another phone within range that has been previously paired with the speakerphone can be connected by tapping the Multi-function button.
For additional help, Plantronics K100 Users Guide
Good Luck from Headsets Direct!
Jun 14, 2011 | Plantronics K100 Bluetooth Headset
How do I make the connections with the main valve, I am buying a new octopus not yet assembled,
If I understand your question properly, all you need to do is remove one low pressure plug from the first stage regulator, then screw the hose end in from the new octopus.
Feb 04, 2010 | Aeris A1 Octo
I have switched bluetooth on on my iPhone and its says its searching for devices but thats all its doing. My old nokia phone has picked up my iPhone on its paired devises but the iPhone doesn't pick the...
Bluetooth on iPhone:
On iPhone:
1) Go to Settings
2) Go to Reset
3) Select "Reset All Setting" (Make sure you save passwords. Data is safe.
On Bluetooth unit::
Clear all previous pairings.
Once iPhone reboots, turn on Bluetooth.
Sep 11, 2009 | Apple iPhone 3G
How to use safe second with a Scubapro full face mask
Yu only need the octopus adapter kit to put on an octo and you can swap out should your primary reg **** out.
Feb 18, 2009 | Scubapro Full Face Mask, All
Scuba octopus?
An octo IS a regulator. There are two types or regulators on a typical scuba rig. Your first stage reg that is attached to your tank valve. From this first stage, there are hoses leading to your primary breathing second stage reg and your Octo second stage. The job of the first stage is to bring that possibly 3,000 psi air in the tank, down to a more reasonable pressure of about 150 psi. From there, the air goes to the second stages and can be reduced down further by these second stage, on demand (meaning it delivers air when you inhale and stops when you finnish inhaling), regs. The Octo is a second stage back up for a buddy that is out of air or if your own primary second stage ( the one you normally breathe from) is no longer functioning. Octos are generally ( not always) a cheaper reg, that may not have all the bells and whistles that a primary air source does. It's there for an emergency, so ease of breathing under load and tuning adjustments are minor. It gives you air when you're in a pinch, thats the important thing.
Dec 01, 2008 | Aeris A1 Octo
What side does the octopus go on? left or right?
The reason to have it on the right is because that is "standard". I dive with a long hose (7') and an octo around my neck on a 22" hose. So long as you explain it to anybody you dive with and talk about your plan for air sharing in advance, it shouldn't be an issue.
Radio Communications Logo
569 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
