Question about Powerware 9120 UPS System
Can I replace the fan in a live powerware 9120?
The fan in my production powerware 9120 has died, resulting in an over temp alarm. While in this alarm state it apparently is not functioning as a UPS, as I discovered when we lost power last week. The problem is I can't shut this UPS down - it'll bring our whole corporate network down. I've found the directions to replace the fan, I'm wondering if it's possible and safe to do while the system is live.
  • 3 more comments
  • Justin Acklin Jul 11, 2013
    I want to add I did contact Eaton for an estimate to have a tech come and replace it, and their estimate is almost $2000! for a $10 fan...
    I actually found a number of posts indicating any cheap 2-load 12VDC 80mm X 80mm X 25mm will replace it, with instructions how. No help telling me to replace the bearings without more detail on how. Can you even replace bearings on brushless DC motor?
    My question still stands: Is this safe to do while the UPS is turned on? It's in "OVER TEMP" warning already.
  • Justin Acklin Jul 12, 2013
    According to Eaton tech support, this is a part that I can replace myself easily, but the UPS does need to be powered down.
  • Vassilis Chamaidis Aug 15, 2013
    As you said any fan 80X80mm will do. Have in mind that this is live curcuit with high voltages.
    Prepare the fan before installing it. Normally you buy the fan without the connector so a good idea is to add the connector before removing the ups cover. Another way is to use heat shrinking tube to join the wires comming from the board. Personally i prefer to desolder the cables from the failed fan and solder the directly to the new fan. As i said before its a live curcuit and you need to be carefull.
    Problem Solver:
  • 21 Answers
Hey dude your problem is so simple..below are my solutions.
if you already secured the fans for the replacement then its easy for you to do it, try to totally shut down your UPS removing the input and battery supply. avoid replacing the fans with power, its to dangerous. it consist of almost 400VDC inside in it.
call me if you want +63923 3024 585
Posted on Jan 27, 2014
3 Suggested Answers
  • 198 Answers
SOURCE: Powerware 9120. 1500i UPS
You can download the manual and other literature at
http://www.powerware.com/EMEA/UPS/9120_info.asp
The contacts for support in India are found at
http://www.powerware.com/India/Service_Support/IN_Office_Contact.asp
They offer a battery monitoring software package, at
http://www.powerware.com/India/Service_Support/IN_Battery_Services.asp
You can email support at http://www.powerware.com/pp/Check.asp?key=code1
Good luck
Posted on Feb 23, 2008
  • 4 Answers
SOURCE: replacement fans for powerware 9120
9120 fans are rare and uncommon, for alternate solution just replaced the bearing of the fan.
Posted on May 27, 2010
Hello, we have a Powerware 9120 and our question is: If you set the BYPASS option, can the batteries load?? Thank you
Not sure what you mean by load the batteries. Replace them? Yes. Bypass mode is typically used when servicing the unit. You can email Eaton if you like: SinglePhaseTS@eaton.com
Here is the legacy documentation page for the 9120 UPS:
Jun 30, 2011 | Powerware 9120 UPS System
Powerware 9120 6000i model indicates a charger failure. It is the first time that we opened this unit and we do not know the location of the charger circuit (we do not have a schematic diag). Could you...
The charger in powerware 9 series 9120 6000i ,the fan is of a quality that it fails and the heat sink does not get sufficient cooling ,it runs on 12 volt ,i replaced it with a cpu fan from a mainboard on a pc and it works perfectly now. make sure that the fan is running else the charger might go in protection or can fail due to the transistor on heat sink fails.
Feb 08, 2011 | Powerware 9120 UPS System
I ave a powerware 9120 and get a Charger failure alarm
check your batery, may it was leaked, change it with new battery
Jan 17, 2011 | Powerware 9120 UPS System
When i power on the ups it show site fault on the display,i checked the earth wire is ok . what can it be a problem?
Hi, here is the documentation page for the 9120 where you can find the manual: http://powerquality.eaton.com/Products-services/legacy/9120-info.asp You can also contact customer support 800 356 5737 or SinglePhaseTS@eaton.com. You may recognize the product as the Powerware 9120 but Powerware was bought by Eaton a few years ago. The customer support team is most ex Powerware and are familiar with the 9120.
Oct 14, 2010 | Powerware 9120 UPS System
Replacement fans for powerware 9120
A good electronics supplier should have. Get the correct voltage and size, and get one with the largest CFM available.
Oct 01, 2009 | Powerware 9120 UPS System
9120 fan stopped working
On Services can assist you in the repair of this UPS fan and any other critical power service parts/repairs. We have nationwide service, please contact us if you are still looking for assistance.
http://www.gowithon.com
Jun 12, 2009 | Powerware 9120 UPS System
Pw9120-6000
1st, the 9120 is a 700, 1000, 1500, 2000, 3000, 5000 or 6000 Va
if it is a 6000 Va that voltage sounds ok, and the ups as no problem, each battery will be around 12,75 Volts, it will be higher and the charging circle ends.
Jun 27, 2008 | Powerware 9120 UPS System
Powerware 9120 UPS System Logo
169 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
