Freon volume is there freon in toshiba p300d laptop.
My laptop turn of when heat cooling system
  • Christo Urumov Jul 11, 2013
    Master:
  • 663 Answers
Please rephrase your question or post because I couldn't understand it. It would be great if you make it clear so that I can provide you with a detailed troubleshooting steps.
David
Posted on Jul 11, 2013
3 Suggested Answers
  • 103 Answers
SOURCE: I have bought a secondhand Toshiba laptop P300D
try press and hold Fn then Esc key,that will enabled the webcam, if nothing happens,try to update the driver for the webcam
Posted on Jun 27, 2010
joecoolvette
  • 5660 Answers
SOURCE: Are the display bands compatible?
1) Toshiba Satellite P300-13j LCD screen example,
http://www.screentekinc.com/Toshiba_Satellite_P300D-13J--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Thin Film Transistor (TFT) Active Matrix LCD screen, that is WXGA, and uses one CCFL for a Backlight.
2) http://www.lcds4less.com/ToshibaLaptop__Toshiba_Satellite_P300D-12L__laptop-screens.html
Thin Film Transistor (TFT) Active Matrix LCD screen, that is WXGA, and has 1 CCFL for a Backlight.
There is a pretty good chance. The screen Inverter and LCD screen are a matched unit. I would remove the screen Inverter from the P300-12L, and use it also.
Looks like this,
http://www.lcd-inverter-shop.com/Toshiba/Toshiba-Satellite-P300D.html
If I may ask;
1) Is there obvious damage to the LCD screen?
2) If there is not obvious damage to the LCD screen, have you used an external VGA monitor with the laptop?
To see if the problem is the graphics chipset, or the video cable, or inside the Display Assembly.
A) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P305/take-apart-notebook-1.htm
B) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
Post back in a Comment.
Regards,
joecoolvette
[Primer:
An LCD screen cannot produce light by itself,
(Click on the monitor icon,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/ )
It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
LED stands for Light Emitting Diode
CCFL stands for Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Observe the last 8 photos especially. This article shows you that the LCD screen is an assembly. It is composed of layers. Just like the 3M company's tutorial. Also shows general instructions for replacing a Backlight.
A screen Inverter is used to convert the power from the laptop, for the LCD screen, and Backlight.
It is a small circuit board, and is usually mounted towards the bottom of the LCD screen, and behind the Display Bezel.
A CCFL, (Or two of them), uses a screen Inverter.
LED backlighting however, may or may not use a screen Inverter.
Using LED's for backlighting is relatively new, when discussing backlighting technology.
Some of the first designs of LED backlighting does use a screen Inverter.
Newer designs do not seem to.
90 PERCENT OF THE TIME the problem can be attributed to a bad screen Inverter.
Posted on Aug 21, 2012
Looks like this,
If I may ask;
Regards,
joecoolvette
[Primer:
Aug 21, 2012 | Toshiba Satellite Computers & Internet
Black screen on p300d laptop, computer willnot boot
maybe you have the lcd disabled? when you press the power button does it sound like it is starting up at least? if so, plug in a secondary monitor via the vga/dvi port on the laptop or look for the Function key on the keyboard that will re-enable the monitor
good luck
May 11, 2011 | Toshiba Satellite P300D-ST3711 Notebook
How skip bios password
When you type in the BIOS password, let the notebook load and use the Toshiba Utility to remove the password.
Hope that helps.
Dec 14, 2010 | Toshiba Satellite P300D-ST3711 Notebook
I have bought a secondhand Toshiba laptop P300D and dont have a manual. How do I use the built in webcam?
Jun 27, 2010 | Toshiba Satellite P300D-ST3711 Notebook
Drive doesn't read CDs
in device manager try uninstalling and reinstalling the cd-rom driver. If that don't work the infered reader is probably bad
Apr 04, 2010 | Toshiba Satellite P300D-ST3711 Notebook
How to turn on web camera
Open Control Panel -- > "Scanners and Cameras" Wizard, then Double Click to open the icon located there. This will automatically turn on your Webcam.
Nov 14, 2009 | Toshiba Satellite P300D-ST3711 Notebook
Need drivers for laptop hard drive crashed reloaded windows but no drivers toshiba does not list this model
www.drivermax.com
visit the above site, download the free driver utilty and it will scan for hardware, find the latest drivers and let you choose what to install( I used it to "downgrade" from vista to xp on my Toshiba Equium P300D, it was excellent).
Oct 10, 2009 | Toshiba Satellite M35X-S109 Notebook
Laptop stops wafter some working heating
I THINK you mean, Laptop stops working after heating up... If that is so, that means your Cooling system is not functioning, and the computer has turned itself off to protect your MOTHERBOARD, CPU, RAM and HDD from heat damage. Which means, you can likely get your cooling fan replaced in a shop for about 100 bucks (outside of warranty) and have your pc back the way it was when you got it new.
Aug 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
Will not log off or shut down properly
sounds to me like a spyware problem.... i recommend downloading a spyware scanner and scanning your computer for threats
May 28, 2009 | Toshiba Satellite P300D-ST3711 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
