I have a Rhpb-10297 mainboard it regulator heats up..needs help.
1.)well u can keep it in a cool room
2.)don't put it on a hot carpit
3.)don't put it on a cover
Posted on Jul 11, 2013
  • mya jones Jul 11, 2013
My n81 over heats when i am use it for more than 10 minutes and causes the battery to drain and eventually turns off after that
This is a fault in the motherboard, a possible shorting in a semiconductor thereby draining high current and so the battery is drained.
In most cases the motherboard needs a replacement unless the component that is heating is discrete, a possible diode or regulator.
Need to take consensus after a visual check to estimate.
Oct 03, 2011 | Nokia N81
The control panel is very dim on my Thermador RDSS30 oven
Cannot Read Display or See Temperature Thermador RDDS30
FixYourBoard.com repairs this failure and back their work with a two year warranty.
May 14, 2011 | Thermador Ovens
Coffee maker did not heat
An electric coffee maker has an electric flow-through brewing water heater with a heating resistor controlled by a temperature dependent regulating switch responsive to the temperature of the heating resistor, and a warming plate heated by the heating resistor for maintaining the prepared coffee at a desired drinking temperature. Apparatus for adjustably prolonging the interruption of heating current 2 to 5 times the normal cooling time of the regulating switch is connected in circuit with the heating resistor and the regulating switch, and a manually actuated small quantity control means connects the heating current interruption prolonging apparatus in circuit with the heating resistor and the regulating switch. The prolonging apparatus may be an adjustable auxiliary electric heater in parallel with the regulating switch and thermally coupled thereto or an adjustable timer in series with the heating resistor and regulation switch and triggered by the opening of the regulating switch
Jan 31, 2010 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
The monitor led is green but it gives white flash and still blank
Check the volatage regulator in the mainboard resolder all you found dried unsolder parts inside mainboard. Voltage test the regulator IC if have a voltage flow 2.5 to 5v DC. check ribbon cable connector from mainboard to controller board if properly connected. In the controller board find the small fuse test it for open.
Reminder:
When you voltage test in the power board
in the primary section of power supply
use hot ground. Do not use the hot ground
when you voltage testing the secondary
power supply, mainboard and controller
because it will cause of damage
semiconductor. For safety use cold ground
for secondary, mainboard and controller
board.
Aug 29, 2009 | ViewSonic VA712 17" LCD Monitor
Not powering on
maybe one solution is to change your power supply.
if this is not helping you ...... sorry is better to take another mainboard in place to have serviced that you have is costing you less. same MB you have or better is under 100$.
Apr 07, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
I need sound card Driver
se link given below
http://support.creative.com/downloads/download.aspx?nDownloadId=10297
click on agree licence agreement
download start
Nov 28, 2008 | Computers & Internet
Viewsonic VG919S 19" LCD
Hi
You must focus to mainboard of LCD monitor find the voltage regulator IC. Voltage test the regulator IC use digital or analog multimeter range 10v dc connect the negative to cold ground, these regulator providing a constant supply of 2.5 - 5v to all IC in the mainboard. check the scalar IC. Because scalar IC will convert analog input signal of Red, Green & Blue. Lastly check the controller board, check the ribbon cable connector from mainboard to
controller board for lose, check the fuse inside controller. I think the exact problem of your monitor could be either the (mainboard) or (LCD panel where the controller board is located).
Oct 06, 2007 | ViewSonic VG910S (Black, Silver) 19" LCD...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
