Question about Bosch Dishwashers
Bosch dishwasher Spv40coogb
Door too stiff how can I adjust the tension
SOURCE: DOOR TENSION
open the dishwasher and look at the top of the chassis, where the door catch is. You'll see 2 screws with hexagonal heads, one on either side of the catch. Turning these screws will apply or reduce tension on a wire liked to a spring on either side of the door. Tension must be equal on both sides.
Posted on Feb 18, 2008
SOURCE: adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Posted on Aug 17, 2008
aborcass
  • 2651 Answers
SOURCE: Door Tension Adjustment on Electrolux Dishwasher
you should be able to remove the lower acess panel, and the tension springs are on both sides, cant really picture how to adjust tension( font or back), but there should be enough room to get a flashlight and you hands under there to make the adjustment
Posted on Oct 26, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Bosch Dishwasher Model SHU66C soap door will not open
This is most likely the actuator for the soap door. Unplug and remove door covers to find it, and check it is not seized. Look at "wax motor" online to understand working, as they often use these (and may appear siezed - when actually ok)
Check cables are not broken and connectors not corroded.
Replace actuator if you are uncertain, and try again.
Further problems may be the contact to control it in the controller assembly or a broken cable between the two.
Posted on Jun 06, 2010
  • 4336 Answers
SOURCE: adjust door tension on jdb-5
There are springs on both sides of the door, likely one has snapped. You can get at the spring without removing the machine, sometimes, by pulling the bottom panels...
Posted on Jul 02, 2011
Testimonial: "Thank You"
How do I adjust the door tension on a Bosch SHU 6802 undercounter dishwasher to keep it from falling open
you cant change the tension more likely one of the ropes attached to door spring has snapped so you are only getting counterbalance from one spring not two.
Feb 04, 2017 | Bosch Dishwashers
Bosch dishwasher door tension
Most dishwashers have big springs that run front to back at the bottom sides of the body. These are the door springs. Tension is adjusted by moving the spring to one of several holes in the frame. One way will give you less tension on the door the other way will increase it. If the dishwasher is new, why not call service and let them deal with it. Should be under warranty.
Mar 24, 2015 | Bosch Dishwashers
Door hinge tension adjustment
You have to change the springs at the bottom back.It; s easy.You must buy the item 0509 at this page or anyother you like http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/All-Products-Parts/Model-SHX45P05UC60/1794/0130000/1010702P/00005?blt=06&prst=&shdMod=
Then you must access the bottom side of the base of dishwasher and with a screwdriver pull off the old springs.After this you will see a cordon that you must remove it and connect this to the new springs.
Sep 05, 2013 | Bosch Dishwashers
How do i adjust the tension of the door hinges on a bosch dishwasher?
you cant you only can change the springs. probably one is broken
Feb 24, 2010 | Dishwashers
Adjusting door spring tension on a Bosch dishwasher
underneath are 2 L-brackets with the springs attached. Pull those out (with the door closed) and tension will be released. Shorten the strings attached to the springs and reinsert the L-brackets.
Nov 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Door has become stiff in operation and does not move up and down smoothly. is there an adjustment?
Most of the time the dishwasher door hinges are located on the framing at the bottom of the unit behind the kick plate. There should be a spring on either side with a series of small holes in the bottom framing. Move this spring closer to the door for less tension, further away for greater tension.
Sep 10, 2009 | Dishwashers
Bosch dishwasher door leaks
Hi have you adjusted the door striker on the top part of the dishwasher? This is the part that the main door latches onto and can be adjusted in or out!
Feb 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Oct 26, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Door Tension
just about the most difficult job to do on a dishwasher, not normally a job for the home mechanic, i am an appliance engineer of 20 years and often shy away from jobs like this,
there is often no adjustment, the hinges are sprained, more often that not by people either putting weight on the door to stand back up, or children climbing on to get higher
the only thing i think you can do is to check the springs are in place and nothing is broken or just come off that can be put back?? sorry
Oct 14, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
