Question about Nikon Coolpix L110 Digital Camera
Nikon L110 battery getting discharge in few clicks
I have Nikon L110 camera. which uses 4 AA batteries. after 5 to 6 clicks get error battery exhausted. Had tried with new brand batteries but same issue observe. Kindly help what is a problem. Is problem related to camera.
    Guru:
  • Nikon Expert
  • 362 Answers
It could be a bad battery charger circuit in your camera. Try charging your batteries in an external charger. Adorama.com sells an Delcon Devices external battery charger for $9.95. If that works, your problem is solved. If not, you will need to send the camera to Nikon USA for repair.
Posted on Apr 23, 2014
SOURCE: Battery EXTREMELY Exhausted
As the other person says Nimh rechargable batteries are the best....Also somewhere in the menu system you will find that you need to define which type of battery you are using, this may be the cause...Nikon UK have an excellent after care team if all else fails.
Posted on May 25, 2007
SOURCE: Nikon L18 does not work with AA HR6 batteries
Sorry, I had not charged the batteries, Works fine now!!
Posted on May 11, 2009
  • 12 Answers
SOURCE: Blurry Photos & Batteries Exhausted
I may be able to help with the battery problem. Two suggestions: 1) With a WHITE eraser (preferably at the end of a pencil) rub the metal tabs in the camera that makes contact with the batteries. They may be slightly corroded. DON'T use a pink eraser. A fine sandpaper will also work, but is more difficult to work with inside a small space. 2) The metal tabs may be pushed in too far. You may need to pry them out with a small flat-head screw driver or needle nose pliers. Do so gently.
GregM23
Posted on Sep 07, 2009
SOURCE: Nikon L100 shows battery exhausted error message
That's the bug in Nokin L100, update the firmware version from 1.0 to 1.1, this will solve the battery exhaust problem. Firmware version 1.0 has only 2 battery (Alkaline and Lethium) option where as Firmware version 1.1 has Nickle battery also. But, to update the firmware you need to have EH-67 AC Adapter to give power to the camera.
Posted on Feb 11, 2010
  • 97 Answers
SOURCE: Nikon 7600 Battery Exhausted
There is a menu item on the camera to select what kind of battery (Li-Ion, NMh, or Alkaline) is being used. I strongly recommend the use of a rechargeable cr-v3 battery in this camera. There is also a reset function for the battery indicator.
Posted on Apr 22, 2010
Nikon L110 takes time to start
What type of battery does it use? check to make sure it is a new or fully recharged battery. Sounds like it may have experienced some type of moisture or elevated heat.
Jan 21, 2014 | Nikon Coolpix L110 Digital Camera
My Nikon coolpix L110 is not responding at all or takes forever to respond
Try resetting the camera by removing the battery for 15 mins, then insert the battery and go into the Menu to set the Date and Time.
Mar 20, 2012 | Nikon Coolpix L110 Digital Camera
Changed batteries in a coolpix l110 and cant get anything to work. No power and lens wont retract. tried everything in manual thus far with no results.
What type of battery did you use with your camera? Is the type your L110 support? Seems your camera use AA batteries, but not all of the AA battery which can put into your camera is OK. many cameras only support Li-ion battery or Alkaline batteries
Jun 30, 2011 | Nikon Coolpix L110 Digital Camera
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
Nikon Coolpix L110. Less than a month old. Keeps saying "batteries exhausted" even with brand new batteries
Are you using good quality batteries? Cheap supermarket batteries (usually zinc carbon) tend to be weaker than quality alkaline batteries. Look for alkaline batteries with the code "mn1500" somewhere on either the battery or the packet. Also, rechargeable batteries can vary between brand in that some hold less charge for less time than others. So look for the code "2000" or "2500" on the pack if you want to use rechargeables. Many cameras use only 2 AA batteries and it takes a lot of power just to start them (charging the flash and extending the lens etc.) and need a good battery for them to work.
If this doesn't solve the problem (I think it should) then you may want to return the camera and have it replaced under warranty.
Hope this helps.
Jan 20, 2011 | Nikon COOLPIX L18 Digital Camera
I just replaced the batteries in my L110 and when I click to take a picture the camera shuts down. I replaced the batteries again and the same thing happens. Camera is about 6 months old.
I've found that the type of battery makes a difference. I always use the lithium energizer, they have alot of life to them, last longer and allow you to take many photos. You can also get rechargeable to save money in the long run. Just make sure they are of good quality, so basicaly I would not go with the off brand batteries or standard AA, lithium works the best and run around $9.00, but worth it. Hope this helps :)
Nov 09, 2010 | Nikon Coolpix L110 Digital Camera
Coolpix 2200/3200 Battery Compatibility
The Coolpix 2200 / 3200 camera is designed to use 2 (two) AA type batteries. Due to Nikon’s advanced power management technology, two standard AA Alkaline batteries can provide more than 100 photographs. For better performance, please consider using Nikon EN-MH1 rechargeable batteries. These are available as an optional accessory at Nikon dealers and at The Nikon Mall Recently a new type of battery, the CR-V3, has been released to the market from several battery venders. The CR-V3 is similar in shape to two connected AA batteries and easily fits in your Coolpix camera compartment. Nikon has confirmed compatibility only with the following battery brands. Please use one of the following brands when using CR-V3 type batteries. Duracell Sanyo Panasonic Due to it’s unique design the Eveready Energizer® brand CR-V3 battery may not be compatible with the Coolpix 2200/3200 camera.
Aug 30, 2005 | Nikon Coolpix 2200 Digital Camera
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix L110 Digital Camera Logo
75 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
