Question about Sewing Machines
Tajima embroidery machine, when sewing, stop,change color, the needdle stay down , cut break the needdle
akylas
  • 26 Answers
SOURCE: brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Posted on Jun 10, 2008
RickE1
  • 202 Answers
SOURCE: Bernina 180E Embroidery module not recognized
Anytime there is a communication issue between machine and module attach the module to a different machine and check it. Possibly at a dealership. This will tell you whether its the machine or module. If its the machine then the soldering points on the embroidery module plug to the A-print (on the side of the machine) circuitboard need to be checked. Then most likely replace the A-print circuitboard.
There are other tests that need to be done in the service program that will help pinpoint and troubleshoot issues with the embroidery unit. Such sensors or stepping motors, etc. Should be left to a tech.
Hope I helped.
Posted on Feb 11, 2009
mohammed387
  • 1952 Answers
SOURCE: embroidery sewing machine ''emotions'' EM1
www.embroiderydesigns.com/free_embroidery_design_download.aspx
Posted on Jun 12, 2009
SOURCE: I have a viking Iris sewing and embroidery machine
When I had that happen, it turned out that I had not wound the bobbin thread correctly (it was not wound tight and smooth enough). Wound a new bobbin from scratch, and all worked fine.
Posted on Jul 10, 2009
chrismyers67
  • 53 Answers
SOURCE: cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
Posted on Jun 06, 2010
How do you correct/fix a 316 error/main shaft motor error on a Tajima 2 head embroidery machine
I hope this link will help.
http://www.digitsmith.com/tajima-tmfd-g1220-type-2-error-316-a-31639.html
Sep 28, 2017 | Sewing Machines
I have Tajima embroidery machine TFMX1508 Igot error code 6D2 what's wrong is it who knows
This should be in your Troubleshooting guide in the manual.
Here are some codes related to trouble codes on a Tajima machine, may need the correct error codes for your make Model machine.
http://www.theembroiderywarehouse.com/errorlist.pdf
Cheers and good luck!
Embroidery Services
San Diego, CA
Aug 07, 2017 | Sewing Machines
How do I fix error code 2CF of Tajima embroidery machine for TFSN,TFKN,TFGN.
2CF - An immediate stop came in from an external. Check the external device or the connection to the external device.
device TMLG, connector joint 16 JH08
Check for a loose connection in any external device like a keyboard or card reader.
Feb 06, 2015 | Sewing Machines
How to adjust trimmer on tajima tumx
WIll need more information about what you are trying to adjust?
Machine functions a mechanical cut, but the thread wasn't cut?
Cutter has timing to be set or replace the fixed blade. are two basic possibilities. I need to know what it's doing cut wise? to know what to adjust.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 19, 2014 | Sewing Machines
Hello, Error 225 Travel outside the set embroidery area
( When the software frame limit is set, or
on cap machines) Here is website for all the errors:
May 17, 2014 | Sewing Machines
Hi. I have a commercial one head tajima embroidery machine. I was sewing and realized I had no thread on one bobbin so I stopped the machine. Instead of continuing on, I decided to start all over with a...
Your new embroidery program has to be loaded first. The 2b7 is referring to needing instructions or in other words the embroidery program has to be loaded. Shut the machine down and turn the machine back on and load just as before.
Jul 06, 2017 | Sewing Machines
Tajima embroidery machine troubleshooting
We are having a similar problem with one of our single head Tajima TMEX-C1201 machines. In our case the design runs part of the way, then the head jumps and continues running and ruins the work. Any feedback on this would also be appreciated. Thanks.
Jul 15, 2013 | Sewing Machines
Color Change problems
Probably you have too small (cannot be accepted by sewing machine or threatening to break a thread) stitches in the deleted blocks, try to optimize a design.
May 23, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
