100 examples cline words - Computers & Internet
What is the definition of an suffix and a prefix i would like to know about it please give me information from the dictionary?
Prefixes and suffixes are grammatical and lingual "affixes." Prefixes are affixed before and suffixes after a base word or word stem to add information. For example, with the word "prehistoric," the prefix is "pre-" meaning "before," the base word is "history" meaning "recorded events and knowledge", and the suffix is "-ic" meaning "relating to the science of."
In other words, "prefix" simply refers to an attachment before or in front of, in this case, a shorter word or stem. In lingual terms, a "stem" is the main part of a word to which prefixes and suffixes can be added and may not necessarily be a word itself, such as "dod" in "doddle."
Similarly, "suffix" refers to an attachment after the end of an existing word or stem, serving to form a new word or functioning as an inflectional ending, for example, "s" or "es" to make for plurality.
Sep 30, 2014 | Games
How do I change a percentage to a fraction
Use this http://www.calculatorsoup.com/calculators/math/percent-to-fraction-calculator.php
OR to work it out yourself.....#
How to convert percent to fraction
  1. Divide the percent by 100 to get decimal number.
  2. Count the number of digits (d) to the right of the decimal point of the decimal number.Example: 2.56 has 2 digits to the right of the decimal point, so d=2.
  3. Calculate the factor (f) for making the decimal number an integer: f = 10 to power d
    Example:
    f = 10 power 2 = 100
  4. Multiply and divide the decimal number x by the factor f: x * f / f = y / f
    Example:
    2.56 * 100 / 100 = 256 / 100
  5. Find the greatest common divisor (gcd) of the fraction. Example:
    gcd(256,100) = 4
  6. Reduce the fraction by dividing the numerator and denominator by the gcd value: Example:
    256 / 100 = (256/4) / (100/4) = 64/25
Example One percent is equal to one hundredth:
1% = 1/100
So in order to convert percent to fraction, divide the percent by 100% and reduce the fraction.
For example 56% is equal to 56/100 with gcd=4 is equal to 14/25:
56% = 56/100 = 14/25
Sep 07, 2014 | Office Equipment & Supplies
Can you give me examples of abstact nouns
Abstract nouns are things that cannot be experienced with the five senses.Things such as: Compassion, courage, intelligence, and laughter.Good examples are listed : http://examples.yourdictionary.com/examples-of-abstract-nouns.html
Aug 28, 2014 | Healthy Learning Relational Aggression:...
Examples cline words
Freezing, frosty, cold, warm, hot, sizzling, steaming, boiling
Jun 20, 2013 | Computers & Internet
25 is 62.5% of 40 what are the step by step process
There are no unknowns in this question, but the step by step process for interpreting the words are:
1)' 25 is' means 25 =
2)' 62.5%' means 62.5/100, so 25 = 62.5/100
3)' of' means denominator of subject (which is the 25), so:
25/40 = 62.5/100.
This might be easier to see if there were an unknown. For example: 25 is what percent of 40? Using the above interpretation, this becomes:
25/40 = x/100 then solve for x.
Or, another example: 25 is 62.5% of what?
25/x = 62.5/100
Sep 27, 2011 | Mathsoft StudyWorks! Mathematics Deluxe...
Give examples of noun derivative
noun derivative - a verb that becomes a noun by adding a suffix.
You sometimes come across words which have been derived from their roots by adding certain structures like prefixes and suffixes.
In your earlier years of schooling, you must have been done with exercises and development activities on the use of prefixes
A prefix- is a group of letters added before a word or base to alter its meaning and form a new word. In contrast, a suffix is a group of letters added after a word or base.
5 Example of prefixes:
Prefixes MEANING EXAMPLES
ana- up, back, again analogy, anatomy, anagram
anti- against antipathy, antiwar, antisocial
apo- from, away from apology, apologize
com- with, together communal, community
con- with, together connect, confide conspire
there are so many example of this. i hope it helps. remember that an adjective derivative is a noun, verb and adjective that becomes an adjective by means of adding affixes.
In this lesson, you will deal with deriving words through the use of suffixes.
A suffix added to the end of a root word.
5 Example of suffixes:
Suffixes Meaning Example
-ics things having to do with optics, physics
-ism the belief in pacifism, terrorism, socialism, communism
-logy study field of biology, geology, etymology, cardiology
-or, -er one who takes part in doctor, actor, teacher, driver
-sis act, state, condition of analysis
We have, for example, a verb that becomes a noun by adding a suffix.
This is called a noun derivative
A noun that becomes an adjective by adding a suffix is called an adjective derivative
Example of Adjective Derivative:
subject- subjective
addict- addictive
react- reactive
success- successive
care- careless
ugly- ugliness
hope- hopeless
steel- steely
accept- acceptable
obey - obedient
These are but few ways by which we can identify how words are derived.
Jun 13, 2011 | Macromedia Computers & Internet
NEED BIGGER FONT THAN 72 on computer
Hi. If your using the MS office aplication like MS Word, You can just type the Value that you want, for example you need the size "100" on the font then just delete the size "72" and replace it with "100" then press enter, but remember to highlight the word that you want to replace the font size before doing this procedure. Hope This Helps
Jun 08, 2010 | Acer Aspire 5500 5570-2609 Laptop
How many cubic centimeters are in 1m3?Explain how you know using pictures,numbers and words.
You first need to know how to calculate volume of a cube. Take the length of the side of the cube and multiply it by itself, and then multiply by itself one final time. For example, if you have a cube that has a side length of 2 cm, you would multiply 2 x 2 to get 4, and then 4 x 2 to get 8 cubic cm.
You are asking about a 1 cubic meter cube. I know that a side of that cube is 1 m (1 x 1 x 1 = 1). Convert one meter to cm. Therre are 100 cm in one meter. The new math will be 100 x 100 x 100 = 1,000,000 cubic cm.
Jan 18, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
Computers & Internet Logo
558 people viewed this question
David Payne
David Payne
