Aiconditioner high pitch noise
Fujitsu aircon makes this terrible noise that drives us crazy!
  • 4 Answers
Have you tried applying pressure to it with your hand? It sounds like something is vibrating because it came lose.
Posted on Jul 11, 2013
5 Suggested Answers
  • 51 Answers
SOURCE: HORRIBLE NOISE!!
call tech or installer and check condensor fan assuming noise is outside. shut down outdoor unit and hand spin the fan blade to see if it is rubbing
Posted on Aug 09, 2009
caroldon
  • 17130 Answers
SOURCE: fan making high pitch sound,
If you are confirmed with the noise coming out of the fan unit, then please do not waste much time but open the front panel and look into the air flow slot if there is any foreign particles struck inside.You will need to get access if the sound is coming from the rotary fan as sometimes some objecct would have got struck into the vanes of the fan. Once it is confirmed as when you switch off the sound reduces and on switch on the sound increases, then it is confirmed and removing the front panel unit becomes important. Be careful with the connecting lines so as not to break the cooling pipes if you are able to do without removing .
Hope you start with the first part and dislodge any particles by an extended probe. Hope I could help. Good day
Posted on Aug 18, 2010
SOURCE: My Fujitsu Halcyon Split ac/heater wall unit is
hi i have fujistu inverter2500/600 and it is shut down after 3 minutes after starting up
Posted on Dec 19, 2010
caroldon
  • 17130 Answers
SOURCE: Once you turn on aircon
Your AC needs a good overhauling as the fan seems struck on the bearings or the blades are rubbing the sides. Also the compressor fails to cool as there can be low gas, low pumping pressure or a blocked condenser.
You need to remove clean the coils and lubricate the fan to be set back. Check the capacitor to the fan and compressor as a low value will reduce the speed and so reduce pumping pressure.
Posted on Apr 11, 2011
2007 Cadillac escalade makes loud noise when starting the car. Sounds like the air suspension on a navigator when it adjusts, but louder. Lasts maybe 20 seconds. Happened 3-4 times within the year. Any...
Try to better describe the noise.
Is it a
scraping of metal
grinding / rubbing
high pitched shriek like a drive belt slipping
Is it
underneath the body
under the hood
in the aircon
when you pull into gear
when you pull away
etc
Do a bit of detective work and come back.
Sep 28, 2013 | Cars & Trucks
High pitched noise coming from TV
could either be the speakers on the tv packing up and the only best way to fix this either take it into a shop to get repaired or just bin and get another one depends on how much it would cost to fix
May 18, 2012 | Memorex MT2206 TV
Fan noise indoor unit (asu12rlq) fujitsu
A high pitched noise from the fan unit, means a bearing issue from the motor. You must replace the fan motor to get rid of the noise.
Dec 17, 2011 | Fujitsu 24R1 Air Conditioner
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
RCA DLP HDTV making terrible noise
your color weel is going bad and needs to be replaced
May 19, 2010 | RCA HD52W59 HDTV Projection Television
Kenmore refrigerator has loud high-pitched noise problem
I would suggest calling sears repair ( this refrig is still under warrenty ) and have them come out to check . If they say it's normal , tell them you want the refrig replaced . You do have rights with a new product not working to your standards .
Sep 19, 2009 | Kenmore Refrigerators
Fridge is making noise
The high pitched sound could be from the evap fan motor. If you can get to it a drop of silicon oil would solve the problem.
Dec 18, 2007 | Hotpoint HSS25GFP Side by Side...
Pitched noise coming from the fan
When I first got my PS3, It had the annoying high pitched fan sound as well, but went away after a week and has worked fine ever since, no problems at all. I have the 60 gig version, so. Maybe if yours is new you just need to break it in?
Apr 30, 2007 | Sony Playstation 3 (PS3) Console
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
