My HP CM1312NFI is connected to my home network. It's wired to my router. I have the printer a fixed IP but it keeps disconcerting and looses connection. What can I do so it will always print without
    Problem Solver:
  • 12 Answers
Make sure you set the printer's IP address to a valid private IP address in the same range as that of your home router, and be sure you can ping it from your PC; you can check if the IP is saved, it is usually shown on the LCD.
More about private IP ranges:
http://en.wikipedia.org/wiki/Private_network
Posted on Aug 25, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Try a print server, some are on sale now at cclonline.com
Posted on Aug 03, 2013
SOURCE: HP LaserJet P2015n Printer IP adress
To Me it looks like your printer is set to automatically select an available IP address. If there is no IP available you get the 0:0:0:0 You need a static IP set up for the printer, this will make sure that no one can use the IP. If this is a company printer, get IT to set it up for you. If its your home network you can set this by yourself by either connecting your printer via usb and using the software from HP or if you have an IP you can log into your PC by entering the IP address in the address bar of your browser. You should get the HP page up for your printer. Set the IP from there in the networking section. I hope this helps a little
Posted on Sep 23, 2008
  • 47 Answers
SOURCE: Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Posted on Nov 27, 2008
  • 551 Answers
SOURCE: HP laserjet 2015dn IP address problem
please do not assign dynamic IP on the network printer. give a static IP on it base on your network config. and also, please do assign all you computers on the network with static IP's so that every time they boot there will be no IP conflict or problem on the network connection.
Posted on Mar 05, 2010
SOURCE: print from nokia E63 through WIFI
Try connecting your printer directly to the wifi router/switch in a shared network configuration. Then go to your router settings, find the local ip address add this as the 'host'. Your settings should be as follows:
Driver : HP Mobile Printing
Bearer: Socket/HP Jetdirect
Access Piont: My Home Wifi (kaba)
Host : ip address of you printer
user : Blank ( tried my windows username,no use)
port : 9100
Printer Model: Officejet Printers
You will have to reconfigure your drivers on your pc as well. Mine installed as a wireless shared printer even though the printer is not wireless but I have it connected to my wifi switch for sharing and it worked fine.
Good luck
Damien_1977
Posted on May 20, 2010
  • 5 Answers
SOURCE: Can not connect to personal Wi-Fi network
This instruction is to setup Brother Laser printer 2170W in windows 7
Turn off Windows Firewall
To reset the printer:
Turn off the printer.
Press and hold the Go Button in front, at the same time turn on the printer from the right side. You will see three lights(Error, Drum, Toner) turn on. Release the Go button. The light is not blue and is off.
Now, Press the Go button 7 times. Wait for some seconds.
The three lights will turn on and off by themselves. The printer warms up and then stops.
Connect the ethernet cable to the wireless router and the printer
in the browser type:
http://192.168.1.1
It shows the device connected and its ip address.
Close the browser and open new browser
on your internet browser type in http://(ip address that you see as device)
click on "Network configuration"
user: admin
Password: access
click on "configure interface". Change it to "Auto Switching" Click OK
You are back in "Network configuration"
click on Configure wireless
Make sure it is "Infrastructure" and the "channel" is correct.
Also "Authentization Method" should be "open system"
Choose your encryption method
type in your password in "hexadecimal format" and click "submit".
If your password is ascii change it to hexadecimal with an online converter
Follow the instructions.
Wait until it prints the papers.
When it tells you to remove the ethernet cable, Do not remove.
Wait until printing is done. Turn off the printer and remove the cable. Turn on printer.
Now Print the printer status:
click on the Go button once to wake up the printer.
Now click on the Go button 3 times. Wait! it will print 4 pages.
Look at the last page
you will see the IP address of the printer.
go to your browser and type in http://( new ip address that you see on last page)
The last step is again in the "configure wireless" to "configure TCP/IP"
choose something like 192.168.1.198 the last 3 digits should be a high number. Close browser.
Now put in the CD and install the wireless Driver only. All Done!
Turn ON Windows Firewall
Posted on Jun 25, 2010
Wired connection ps3 cant obtain ip address
If your home or office printer is part of a network, meaning it is connected to a networked computer or router, then it will have a TCP/IP address identifying it on the network. This address can be used to share the printer with new users on the network, or to get ink and paper levels on your computer. This address can be found whether using a simple printer, or a printer/scanner combo machine such as the HP Officejet 5610, which will be used as an example here. * Click your PC's "Start" button and choose "Control Panel."
* Choose "Printers and Faxes." Left-click "HP Officejet 5610" and choose "Properties."
* Click "Ports" then drag the divider between the first and second columns to the right to display further information about your printer, including the TCP/IP address.
* Open the "Applications" menu and choose "System Preferences."
* Click "Printers."
* Choose "HP Officejet 5610" and click "Options and Supplies." All network information for the printer will be displayed.
Mar 15, 2013 | Sony Playstation 3 (PS3) Console
I have followed directions for putting my HP LaserJet 4050 series PCL6 laser printer online via our home router. I have downloaded the correct driver. The printer shows in my list of printers, but w
1. Setup the printer with the router via network cable (This model is not wireless) on DHCP. The router should see the printer as a IP address on the web admin.
2. Next re-install or configure the printer via a network connection and IP.
Feb 11, 2013 | HP LaserJet 4050 Series PCL 6
I have a hp pavilion dv7-2277cl laptop (64 bit) and a hp laserjet 2605dn. suddenly the communication between the two has gone missing. This is a wireless network and worked until last week. I have down...
The one that is missing in the network is the printer.So try to reconfigure the IP of the printer again using the wireless wizard in the printer manager. Or go to Using the HP Network Diagnostic Utility in Windows - HP Customer Care (United States - English)
Also ; Very seldom does the printer itself cause problems. To determine if you have printer trouble, do the following:
  • If you're using a wireless connection, see if the wireless indicator lamp is illuminated? Can you turn on the wireless radio from the control panel of the printer?
  • Print a Network Configuration page and a Wireless Network Test report from your printer's control panel, if available.
    • Does the Wireless Network Test report indicate trouble?
    • Does the report indicate that the printer is connected to your wireless router, and not to a neighbor's? The network name the printer is connected to will be shown on the both the Network Configuration page and Wireless Network Test report.
    • Compare the printer's IP address [X]
      IP address
      An IP address is a series of numbers by which computers, printers and other devices on a network are known. An IP address is usually issued by the local wireless router (network) from its DHCP service. A device is given an IP address that is similar to the wireless router's IP address. For example, if the wireless router's IP address is 192.168.1.1, a printer may be given an IP address of 192.168.1.5. to the gateway IP address [X]
      Gateway IP address
      This is the IP address of your wireless router. . They should have a similar format (for example, the gateway IP address might be 192.168.0.1 and the printer IP address 192.168.0.5). If the printer has an IP address similar to 169.254.XXX.XXX, it probably is not connected to your wireless network.
    • On some printers, the Network Configuration page will list all wireless networks detected in your area. Is your network listed among those found? Does it have good signal strength?
    • Are there several wireless networks on your same channel or using channels close to your channel? You should use a channel at least 5 channels away from the closest used channel. Consider changing your wireless router's channel to 1, 6 or 11.
  • Are there any error messages on the printer or unexpected blinking lights (consult your manual to determine what to expect)?
  • Reset your printer (usually by removing the power cord from the back of the printer, waiting 30 seconds and then reconnecting the cord. Consult your manual for specifics).
  • Restart your wireless router [X]
    Wireless router
    A wireless router is networking hardware that allows both wired and wireless devices to connect to a network. When connected to a wireless router, devices such as computers, printers, and other Wi-Fi enabled electronics can share one Internet connection AND connect to each other. Connections can be made to the wireless router through a wireless connection or a wired connection using an Ethernet cable. by unplugging the power cord, waiting 60 seconds, then reconnecting the cord to the wireless router.
Dec 16, 2010 | HP Color LaserJet 3500 Printer
I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
Dec 03, 2009 | 2wire Computers & Internet
HP P2015dn wirless connection stopped working
There is not wireless netwrok card is HP LJ P2015dn, However as i can understand you r using External Wireless Router or Wireless network or jet-direct card if u r able to work fine on USB than printer printing mechanism is working fine.
If u connect the printer via wired network connection and it keeps on loosing IP address than it may be problem with onboard network card of the printer.
If printer keeps on loosing IP Address than try upgrading the firmware of the printer.
To check the firmware and IP Address of the printer print a configuration page by pressing and holding down green button for 6 to 7 seconds
May 28, 2009 | HP LaserJet P2015dn Printer
Printing from a home network
Well its noting to do with your router.If the printers are not printing on the network,you need to check the printer drivers first of all,and see if they say 0 ready with a green check mark,If yes then check the ip address of the printer and double check for the same on the computer.They have to be the same if it has to print.If its not the same uninstall the printer drivers and the reinstall it.That should fix it once and for all.
Apr 05, 2009 | HP DeskJet F380 All-In-One Printer
Wireless Dell laptop can't 'find' HPDeskjet 5150 Printer
this printer is (as per HP specs) only connected via USB or Wlan Print server.
Check connection using USB cable and be sure Printer driver are correctly working.
Check on Router your Print server IP address (Lock it out of DHCP)
Put both PRT and PC on same home network (normally HOME or MSWORK)
Put Printer server IP address into your printer properties/port tab/ IP.
OR check if you see your printer server in your Windows network/home network
Jan 11, 2009 | Computers & Internet
Please Help! My IP is driving me crazy!
modem only transmits signal.
router talks to your provider and gets IP address from them, depending on your subscription, you may have a static or dynamic IP.
your computer gets internal (home network) IP from the router, you don't have to worry about that since it is the router's IP address that is seen on the internet (router splits / shares a single internet connection in home networks).
about wireless connection from computers/wi-fi gadgets to the router, must configure the router with the ff:
wireless network name (aka SSID)
security type (WPA/WEP) and password/passphrase/security key
channel (1-12)
the above info must be then set to the connecting computers/gadgets
about wired connection: a working ethernet cable (looks like a phone cord but fatter) and a working computer/gadget ethernet port.
Wii will work - check Wii's website for connectivity options / instructions.
Dec 18, 2008 | NetGear WGR614 Router
Apr 08, 2008 | HP LaserJet 3055 All-In-One Printer
Initial wireless activation freezes unit
Beth, Any details on what firmware version worked for you. Have a WRT54GS V7 -- and having same darn issue!! - Jen
Aug 16, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
65 people viewed this question
jasbo
jasbo
