Question about Cameras
Polaroid xs20 jerking recording problem
I got a Polaroid XS20 and did a test recording and it jerks say every 5 seconds of recording time. is my Miro SD card to slow
SOURCE: polaroid a300 camera is saying sd protected
Well, make sure you have checked the small gray tab on the left side of the sd card. It needs to be in the unlocked position. Too bad for me, because i have the same problem and my sd card isn't locked...
Posted on Dec 19, 2007
SOURCE: Camera turns on for a few seconds, then off.
A light rap with a knuckle when powering up fixed the problem, at least temporarily. Lens extended, camera works fine. Not exactly a technical fix, but it worked for me.
Posted on Feb 21, 2008
marinos
  • 114 Answers
SOURCE: is the polaroid i533 camera
No, the polaroid i533 camera is not compatible with sdhc memory cards. Use only SD cards.
Posted on Jun 27, 2008
  • 102366 Answers
SOURCE: Polaroid i733 card error
The i733 works with SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it won't work. You need to go with SD cards, 2GB and smaller.
Posted on Sep 13, 2010
SOURCE: my polaroid i733 turns on the beeps 3 times then turns off
Had the same problem with our i733 Pink Polaroid. Beeps three times and then shuts off. The reason for this is that the lens is stuck in the partially open position. Because our camera was long past warranty and we bought it for $40 second hand I took the brute force approach. I grabbed hold of the lens and wiggled it from side to side while trying to pull it out (forcefully but being as careful as I could not to damage it) and then there was a small "pop" and the lens came out all the way and the camera was good to go again. Hope this helps.
Posted on Oct 16, 2010
Polaroid service center in Delhi
It will be open from 9am to probably 5 or 6 pm, ring up and it should say if you ring at the wrong time. Phone: 800-765-2764. To reach a live person, press 0 when recording begins. Main company URL: http://www.polaroid.com.
Feb 10, 2016 | Computers & Internet
I was told by one of your representative that a tuner for my TV, Model TLAE-01912 was supposed to be ship to HAGOPIAN TELEVISION CENTRE LTD at 864 MERIVALE RD, OTTAWA, ON, K1Z 5Z6. Telephone number:613...
First, let me apologize for brenda. Some people can't help being jerks.
Second, no one at FixYa ever told you to ship anything anywhere. You need to contact the company to whom you shipped the tuner. FixYa cannot give you the status on an item you shipped to another company.
Oct 12, 2013 | Polaroid DRM-2001G DVD Recorder/HDD...
When l unplug xs20-006 from the charger the screen goes blank,changed power settings but still goes blank ?
When you plug the back in, does the display come back on or does the laptop need to be powered on again?
If you need to power on again, your battery is faulty.
Feb 10, 2011 | Computers & Internet
Is there a way to reset the Poloroid DVC-00725F, I seem to have lost my menus, just a black box appears with no text ?
Well, it didn't fix my camera, but when I plug it in to the USB port, and hold down Enter, Play, Record, and the Pic/Shutter top button simultaneously for 5 seconds or so when the camera boots, it goes into test mode. At which time it goes through tests, but doesn't really fix anything. Good luck to you.
It should say: pcba test program 2 times d50h-polaroid-g0911n
then prompt you to hit the power button
Oct 24, 2010 | Polaroid DVC-00725F Flash Media Camcorder
I have the polaroid dra-01601a dvd/hdd audio
First of all with all do respect I do not have the polaroid drm 2001G. I have as I exprest in my letter to you the polaroid dra 01601A. The problem i had was an audio problem and i simply rechecked all my connections and found that I needed and extra set for HDMI plugs on my TV.
Jan 03, 2010 | Polaroid DRM-2001G DVD Recorder/HDD...
No audio on polaroid DRM-2001G
just unplug the power cable for few seconds
Oct 21, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Polaroid dra-01601a hdd to dvd recording
You will have to split the title and record on more than one DVD. The default speed is SP, that is 2 hours of recording. If you want to record longer programs, go into setup and change the default record speed to one of the other settings, for example: SP+ which is 2 1/2 hours or one of the other longer record settings. This DVD burner will only record at the same speed as you recorded to the hard drive. You can also edit out the commercials by using segment. Go to the title you want, press the right arrow, scroll down and select segment. When you want to start your edit, press enter. when you want to stop the edit, press enter again. You can use your right arrow to skip forward 30 seconds and your left arrow to skip back 10 seconds if you went too far when editing. You will see where your edits are on the screen by the darker color. Do this through the whole program. When you record to DVD, the commercials will not be recorded. Hope this helps you.
May 01, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Polaroid film for Captiva
Polaroid 500 films for Captiva are not distributed anymore.
You can still order them from Kodac or at any service shop.
The only online place where you can buy it is on Ebay:
Type polaroid 500 into Ebay bar in your country to find offers.
Regarding Fuji, this is the most similar product (Australia), I am not sure they work on captiva, some seller sells them for polaroid 500
More offers (worldwide)::
Fujifilm FP-100C $9 to $14 - 8 stores Fujifilm FP-100C - 4 x 5" $20 to $33 - 5 stores
I would order just one Fuji pack, to test it, I was in your shoes, if it does not work get a good provision of Polaroid 500 from ebay.
Sep 14, 2008 | Photography
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
