Question about Breville Fresca BES860 2Cup Coffee Maker
Replace water tank seal
Does the back have to come off or can it be pushed thru, have undone scews on back but feels fixed still thanks colin
Just had this replaced by a electronics repairer. There are two screws needed to be removed to take the top off first. One under the tamper, the other near the steam wand. Once they're out (and after removing the 6 out of the back) apparently you can take the back off to replace the water seal :)
Posted on Jul 26, 2013
2012 Keystone Cougar XLite 32 SAB model... Where is the city water to fresh water tank switch?
feeling air from the pump means that the pump needs priming
Turn on a tap for the pump , prime the pump
if you have damaged the pump seal it will leak at the motor end of the pump
Oct 21, 2017 | Washing Machines
My fathers Bosch water wizard tf 250 will not start. the water will flow but no gas will not ignite or come through the pipe to the heater. the gas bottle is full. thanks Dave Tooley
Dave, make sure that the gas valve on the Propane tank, is fully open and that the inline gas shutoff valve near the heater is turned ON. Those are the basic two things that would prevent the gas from flowing thru the gas line, to the heater.
If the above valves are ON, the problem then lies with the gas control valve on the water heater. If it has pilot light that has to be lit, make sure that the heater's gas control valve is properly in the PILOT Position, before attempting to light it. It must be able to be pushed ALL the way in and you should feel strong pressure pushing back at you (other than spring pressure). When you feel that, it's in the PILOT Position and ready to be lit. Once it's lit, continue to hold the Pilot Button in for 1 minute, then release it. If the Pilot stays lit, turn it to the ON Position.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 22, 2011 | Heating & Cooling
The black rubber valve seal that I have replaced is still no sealing of the water completely causing an overflowing systen. I have tried the the trouble shooting recomendation to take the cap off and run...
The next time it starts to run take the lid off of the tank and gently pull up on the flush valve lever arm putting a little more pressure on the seal and if it stops the water from running then there is something impeding the seal. Check the seal seat and make sure it has no high spots or anything stuck to it. If you look at the bottom of the seal and it has just the slightest dent in it then you need to check the valve seat for debris.
Feb 09, 2011 | Fluidmaster Plumbing
Unit is leaking water on the left side and after we fill up the water container. We are placing it in the proper position but it leaks constantly. It there a service fix for such a situation? ...
Hi
If its leaking under the water tank, its this.
There is a seal on top of the machine under the water tank. To get to it, remove the water tank, and set aside. There is a large doughnut shaped cap on top of the machine. Slip a screwdriver on the outside edge of the cap and pry up gently. When it snaps up, go to the other side of the cap and do the same. There is a black seal in the center and if you stick your finger in the center and it lifts out, it needs to be replaced. Clean any residue inside the opening with a Q-tip.
When you get the new seal, it won't slip in. Insert it at a slight angle (double lips down), then take your finger nail and run it around the bottom edge of the seal until it slips in, then push down. Snap the cap back on and your set to go.
If its leaking under the machine, its your boiler.
If its leaking into the dredge drawer, its the thiumbscrew in the brew unit, that holds the filter screen in.
If its under your drip tray there is a pocket behind the brew unit that has a cloged drain, just above the center of the drip tray in back.
Jan 07, 2011 | Spidem Trevi Digital Plus Coffee Maker
I have a Whirlpool Gold GU3600XTSY0 Model. There is slow water leak from the right side bottom front of the dishwasher. It looks like the water is leaking from a sensor on the bottom. The sensor has a...
I would look at the door seal being a problem as well. if the water level float were leaking, it would be worse then just a little water. The door seal is always the first to go. these seal can be replaced by pulling the old one off and pushing the new one back in place. should be able to buy new seal from the people the unit can be bought from.
Dec 19, 2010 | Dishwashers
My water tank is leaking SERIOUSLY into the machine and all over the counter. Is there a washer that might be missing? Is there a repair place in Houston, TX that can fix this?
Hi
There is a seal on top of the machine under the water tank. To get to it, remove the water tank, and set aside. There is a large doughnut shaped cap on top of the machine. Slip a screwdriver on the outside edge of the cap and pry up gently. When it snaps up, go to the other side of the cap and do the same. There is a black seal in the center and if you stick your finger in the center and it lifts out, it need to be replaced. Clean any residue inside the opening with a Q-tip.
When you get the new seal, it won?t slip in. Insert it at a slight angle (double lips down), then take your finger nail and run it around the bottom edge of the seal until it slips in, then push down. Snap the cap back on and your set to go.
Dec 14, 2010 | Saeco Royal Professional Espresso Machine
AM14C slight leak at the bottom of the water deposit tank,
I love these machines. Keep it and fix the leak.
If you have a leak. You have to find out where it is coming from. Dripping water from the bottom of tank can be coming from a number of different places and at different times thru out the cycle. The rinse cycle or wash cycle or all the time.
The first place to check is the pump. It will leak during the wash cycle. Especially from the top gasket. This one commonly goes out.
The pump motor shaft seal will leak all the time but will drip from motor, not the tank area. You want to fix this before it ruins your motor bearings or motor.
But since you have a corner machine, the first thing to check is the rear door panel. This is were your door would be if you had a straight thru machine instead of a corner machine. It has teflon guides just like your actual doors and they do leak at times or all the time if the guides are
not sealing. IF food particles accumilate at the bottom of that panel it blocks the water from running back into machine and instead, onto your floor from the bottom of tank areas. This is anther common leak.
The teflon guides should be replaced if they have cracks in them or are brittle and flaking apart. Sometimes they slide down and can be push back up from inside the machine. In either case, you will need to clean all the crud from that back panel edge. Usually thats all I do to fix that leak is just clean it up and push those guides out to outside edge with the tip of my screwdriver to tighten the seal between them and the channel.
Hope that helps!
Jul 10, 2010 | Hobart 40 in. AM14-254 Free-standing...
Hi my bissel proheat 2 will not shoot out water
I had this problem, too. My machine is only a year old, so I was hoping it wasn't the pump already. I called the help line, and surprise - no help. They recommended a fix-it place, but the fix-it guy wouldn't help me over the phone. So I fiddled around with it and found the problem - the plug thingy underneath the main tank. The spring mechanism inside it was stuck, preventing any water from going thru it.
Lift out the main tank in the front and bring it to the sink. Feel inside the plug underneath. While holding the tank upright over the sink, push inside the plug. Water should squirt out the bottom of the plug. If it doesn't, turn the tank over, unscrew the plug, and try pushing the inside of it. It is spring-loaded like a ball-point pen. When I pushed the inside of the plug a few times, screwed it back in, and then put the tank on again, the machine worked like new. If your plug doesn't spring, maybe it needs to be cleaned out or replaced. If a new plug is needed, it probably doesn't cost as much as bringing it in for service. It's a small, simple part, and can probably be ordered online. Good luck!
Nov 06, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Breville Fresca BES860 2Cup Coffee Maker Logo
145 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
