Question about Kitchen Ranges
Robinhood 9000 tripping earth leakage. Possible to replace moor and electronic PCB
2 Suggested Answers
Controlfrk
  • 304 Answers
SOURCE: I require a circuit diagram for the electonic
The Link Below will take you to their website archive page. You will need the exact model number, with all numbers and letters, from the plate on the unit (Probably inside the vent filter). Click on "Please select a model" and choose your model from the drop-down list and three links will appear. One will be the "Parts and Service Manual PDF" Clicking on this link will give you the wiring Diagram.
Good Luck
Robinhood
Posted on Sep 06, 2009
How do i fix my lg multi flow fridge/freezer that trips the earth leakage all the time
It may be possible the defrost heater is shorting to earth or ground. This would trip the GFI every time the refrigerator went into defrost. It also is possible that water has infiltrated the insulation and causing a leakage current. This would be much harder to fix.
Mar 22, 2015 | LG Refrigerators
Hoover dryer manual
never a good idea to run with out earth wire????
which earth wire did you remove heater or motor
if you removed the heater wire and it works
then change the heater
Jan 26, 2014 | Washing Machines
GW708U Fisher and Paykel Washing machine Power Controller board trips earth leakage breaker
Hi your pump may be leaking the earth to trip breaker.
Check or replace the pump.
Feb 04, 2013 | Fisher and Paykel Washing Machines
My fridge tripe the earth leakage everytime I switch on the fridge.
call ana accredited electrician to check the insulation of the wires and for vermin infestation that is across electrical connections
it could be a faulty capacitor or failed motor as the earth leakage breaker is also a fuse for excessive current draw
Jun 08, 2017 | Whirlpool Refrigerators
Machine is tripping the electricial supply sometimes
Check for water leaks near the PCB. Otherwise, its most likely the steamboiler element has earth leakage. You can check for this using the Resistance setting on a multimeter.
Mar 01, 2012 | Schaerer Opal Espresso Machine
Every time I plug the iron into the socket it trips all the power in the house..!!
You probably have water or moisture across the terminals, due either to spillage or leakage and it is tripping the earth leakage. Empty the iron out and dry it out thoroughly by placing it on a warm surface for several hours. If it still trips the power after that the element has possibly shorted to earth and the iron will need replacing.
May 12, 2011 | Vacuums
My Defy 621 stove causes the earth leakage to trip after a few minutes when the oven is swithed on. The thermostat was resently replaced. Could it be one of the elements, although it seems they are...
Most likely an element. When the heating wire expands inside the tube it contacts earth and kicks out the earth leakage. Select 'grill' and try the oven. If it does not trip out the lower element is the culprit. Replacement is easy for a reasonably adept handyman - just make sure that the mains are off!
Jan 16, 2011 | Ovens
Motherboard dies after earth leakage trips
By the time you need to replace the "new" spare motherboard it will probably be time to upgrade anyways.
I say just swap it out and keep that old board tucked away for a rainy day.
Dec 06, 2009 | Computers & Internet
Westinghouse 410l fridge trips new RCD's in fusebox
Tripping an earth leakage would indicate a break down of insulation in the windings of the compressor, the possibility of a short circuit in the wiring system or the defrost element down to earth. I recommend you have a certified technician check it out before you have a fire. If the Hoover is in good condition there is no reason not to replace it. Rate me please.
Mar 11, 2009 | Refrigerators
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
