Question about Philips 27PT81S 27" TV
My TV turns on by itself
I followed the steps listed in the manual to set and activate the timer - the current setting is ACTIVATE OFF, yet the TV still turned on by itself today.
  • 45 Answers
Does it Turn on at a certain time? or its turning on all the time? Those it have a mechanical switch like some DVD players have? It may be a broken contact in sidethe switch is making it going on all the time. Best Regards Patrick
Posted on Aug 27, 2007
I have the UPM ETW 350 user manual. It is easy to follow up to and incl. setting on time BUT setting off time is a mystery. Is there a 1-800 nu. I can call to be waled thru?
http://waterheatertimer.org/UPM-timers-and-manuals.html
This line of timers has mostly disappeared from market... I do not know who is offering tech support for the product.
If you purchased the timer recently, it may be previously used or non-functioning.
The manual is complicated and incomplete ... probably because they have built-in or intuitive steps that display when you program the timer... or they assume you want to fiddle around with their product.
It appears the timer must be wired correctly prior to programming.
http://waterheatertimer.org/How-to-wire-timers.html
- you set the current time first... you toggle through menu choices using arrow keys... go to clock...press set.. toggle to find current day (today) and then press set button... then do the same for hour and minute... pressing set button to confirm each selection.
- to program... you toggle through menu choices using arrow keys... when 1 ON appears on display... press set... select day or days for program 1 on using arrow keys... press set... select hour and minute... and press set after each to confirm selection.
These steps confirm setting for program 1 ON ...the day hour and minute that program 1 turns ON
Each ON program requires OFF program..
Probably the timer automatically displays program 1 OFF as soon as program 1 ON is set... then you follow same steps to select day, hour and minute for program 1 off.
Repeat steps to set up to 20 programs.
Do not touch buttons for period of time, and the timer probably displays current time and is ready to go, but manual is unclear about setting the mode..
http://waterheatertimer.org/How-to-troubleshoot-timers.html#in-wall
Gene
Water Heater Timers Save Money
Mar 06, 2015 | UPM Hardware & Accessories
Need to connect to my roku
Here we provide some easy steps for connect Roku:
• Connect the power and insert batteries in Remote
• Connect your TV with HDMI port
• Plug HDMI cable
• Now you screen is flashing on you TV
• Select language according to you
• Connect your Network, it could be wired or wireless
• Enter your Internet or Wi-Fi password
• Now wait for connecting...
• After connecting, you may see a Roku activation code is on your screen
• Put your Roku activation code into www.roku.com/link and start watching your favorites with your Roku.
For more information and guidance about Roku, visit us now
www roku com link enter code Roku Activation Link Roku Activation Code
Feb 01, 2015 | Roku XD Streaming Player 1080P Wireless-N...
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
User's guide for kambrook electronic timer kd94
Could not find a free guide, but e-how lists the basic instructions.
Instructions
    • 1 Set the day and time on the timer. Press and hold "Clock." While holding the "Clock" button, press "Day" to scroll through the days of the week and select the correct one. Press the "Hours" and "Min" buttons to select the correct time. Release "Clock" when you are finished.
    • 2 Press "Prog" set the "On" time for the switch. The word "On" and the number "1" will appear on the left side of the display.
    • 3 Press "Day" to choose an individual day or a block of days. Choosing an individual day means that this specific program will only activate on that day; choosing a block of days means that the program will be active on each day in the chosen block.
    • 4 Set the time that you want the timer to switch on by using the "Hours" and "Min" buttons to select the appropriate time. Press "Prog" when you are done to complete your entry of the "On" time.
    • 5 Select the "Off" time for your timer by using the "Day," "Hours" and "Min" buttons to choose when you want the timer to switch off. Press "Prog" again to save this entry. Repeat steps two through six to set additional timers.
    • 6 Press "Day" and "Hours" to activate the random timer mode. An "R" will appear on the LCD screen, indicating that the timer is in Random mode. This will cause your timer to switch on and off at different times, following no set pattern.
    • 7 Press the button that looks like a hand with the index finger extended to perform a manual override. The display will show you whether it is in Manual or Auto mode, and whether it is turned on or off. "Manual On" means that the time is switched permanently on while "Manual Off" indicates that the timer is turned off. "Auto Off" activates the program that you have set, while "Auto On" turns the time on until the next schedule "Off" time, after which it continues to follow your programmed times.
    • 8 Press "Clock" and "Prog" at the same time to use the countdown feature. Use the "Hours" and "Min" buttons to select the length of the countdown, and press "Manual" to start.
    • 9 To reset the entire unit and clear all programmed times, use the end of a paper clip or a ball-point pen to press the "Reset" button, located above the "Manual" button.
Read more : http://www.ehow.com/how_5565934_program-kambrook-timer-switch.html How to Program Kambrook Timer Switch eHow
Nov 24, 2011 | Hardware & Accessories
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
I have a double pol 208 dgm100 and i conect whith contactor and i cant able to program please can you help
Tork digital timers and manuals appears on following link
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DGM
DGM100 programming manual:
http://waterheatertimer.org/pdf/TORK.DGM100.INSTALL&OP.pdf
DGM100 is single channel timer, so timer operates all Loads at same time.
In other words, if you have 2 different contactors, the timer cannot set different schedules for each.
7-day programming
32 set points
Programming buttons:
1) When powering up the unit, model number 100P appears on screen.
LCD displays 12H which is an automatic (AM/PM) format.
Press ENTER to keep 12hour am pm -or- press HOUR to change to military time, and then press ENTER
2) Unit is in RUN mode and time displays.
3) Set current time:
Press DAY/Month key to select current Day.
Press HOUR key to set current hour (with AM/PM).
Press MIN key to set current minutes.
Press ENTER key to confirm.
Unit now stores present time. Seconds are set to zero.
4) Daylight savings time (DST) automatically adjusts for daylight savings time, if you choose this option.
In step 3 you set current time, but you did not set the Month and date.
YES DST: If you want DST then follow step 5 and enter Month and date.
NO DST: If you don't want DST, then skip Month and date, and move forward to step 6
5) Set month and date.
Press MODE until DATE displays
Press Month button to set current month
Press Date button to set current date
Press ENTER to confirm
6) Set programs
Press MODE key until SET displays
Display shows --:-- 01 which is program1
-Press DAY/MONTH key to set day(s) you want program1 to turn ON
Following are choices that display on screen:
MO to FR (MO, TU, WE, TH, FR)
SA and SU (SA, SU only)
MO to SA (MO, TU, WE, TH, FR, SA)
SU to SA (SU, MO, TU, WE, TH, FR, SA)
Individual days: SU, MO, TU, WE, TH, FR, SA, and D
for Special Day (usually a holiday).
-Press HOUR key to set hour {check AM/PM} you want program1 to turn ON.
-Press MIN key to set minutes you want program1 to turn ON.
-Press ON/OFF button to select ON, and then program1 will turn ON at your set schedule.
Press ENTER to confirm setting.
Display now shows --:-- 02 which is Program2
-Press DAY/MONTH key to set day(s) you want program2 to turn OFF
Choose same days you chose for Program1 ON so timer does not have conflicting programs.
-Press HOUR key to set hour {check AM/PM} you want program2 to turn OFF
-Press MIN key to set minutes you want program2 to turn OFF
-Press ON/OFF button to select OFF, and then program2 will turn OFF at your set schedule.
Continue setting up to 32 different programs.
When finished programming, press MODE button until RUN appears
Manual shows more programming options such as override, reviewing programs, setting special days.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 04, 2011 | TORK Timer 1 Channel Signal Timer Dgs100
How to activate bluetooth in i5700 hand set for file transfer
Hi Friend,
Please follow the below steps to activate the bluetooth in your Mobile Phone
Step 1: From the Home Page, Open the Application List and select the Settings------->Wireless Control
Step 2: Select Bluetooth to turn on the bluetooth wireless features
To connect the Other bluetooth devices and get paired with your mobile
Step 1: From Home Page,Open the Application List and Select Settings------>Wireless Control------->Bluetooth Settings------->Scan for Devices.
Step 2:It will display the List of available bluetooth devices in the range
Step 3:Select any one device and try to connect it
Step 4:It will ask for PIN Number type 1234 and Click on ok
Step 5:It will getting paired you will be able to transfer the files
If you have any Clarification please feel free to reply
Regards,
Ayyasam
Mar 18, 2010 | Samsung SGH-G600 Cellular Phone
Self Timer Activation
The instruction manual is quite poor. Once you have decided which option you would like (2 or 10 seconds) you must go back to the main menu to select which drive mode you would like. Single is default. From single, you can select self-timer, which will activate it for your next shot. The drive mode will always reset back to single after every shot so you'll need to set this up for every self-timed shot.
Happy shooting!
Jan 03, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Philips 27PT81S 27" TV Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
