Question about Car Audio & Video
So my 1997 rav 4 wont hold memory in the clock nor radio after an install of a jvc that needed to be hard wired
    New Friend:
  • 109 Answers
You have not hooked up the wireing right as clock and memory has to be hooked to live all time wire not a switched circuit
Posted on Jul 15, 2013
  • Dj creager
    Dj creager Jul 16, 2013
    I tried that
  • 8 Answers
SOURCE: need a wiring diagram for 1997 chevy s-10 tryin to install radio
bulldogsecurity.com is the place to go for all free wiring diagrams.
Posted on Dec 04, 2008
  • 4 Answers
SOURCE: setting clock on jvc radio
Hey here is an instruction page for your clock.
http://resources.jvc.com/Resources/00/01/13/LVT1775-001B.pdf
Posted on Mar 01, 2009
SOURCE: Setting the clock on JVC KD-G230
Check out this pdf http://resources.jvc.com/Resources/00/00/91/GET0408-001A.pdf
Posted on Jun 10, 2009
SOURCE: car radio - setting the clock
1. click on S (select) and choose clock and hold it (?) 2. click on bar v|<< >>|> to select H or M or Seconds 3. adjust it turning the volume button 4. repeat steps 2 and 3 for minutes 5. repeat steps 2 and 3 for seconds
Posted on Sep 09, 2009
  • 16 Answers
SOURCE: JVC stereo not working properly - 2001 Sonata
generally wiring from the car is as follows...
red = ignition controlled live
yellow = permanent live
if you want stations saved and manual switch off of uni connect radio's yelow and red wires to the cars yellow.
if you want stations saved and radiounit switch off controlled by ignition (i.e only when car is running) then yellow to yellow and red to red. anything else will cause issues...
Posted on Feb 21, 2010
Testimonial: "Thanks, I now see what I did wrong."
Hi my Honda CR-V 97 not enough power to hold memory and clock wont hold time ether and resets ever time I restart the car yours very confused
The stereo should have two 12v wires; one is switched power and the other is always on 12v power.
The memory needs always on power since there is no internal battery to remember presets.
Aug 12, 2016 | 1997 Honda CR-V
Radio wont turn on.
You have a power wire going to your on off switch you should also have a power going to a memory wire to keep your stations and clock intact.
Apr 21, 2013 | 1997 Toyota Camry
How do I remove the dash on my 1997 Rav 4 so I can get at the radio
This Toyota Rav-4 1998 to 2000 - Radio Installation / Stereo Installation coudl helped: InstallDocs/Toyota/PDF/869029.pdf
Good luck.
Jun 03, 2011 | 2003 Toyota Camry
My radio is loosing preset after turning off ignition. 2002 tundra
If you just installed the radio its possible the power wire for the radio memory and clock is not hooked up to a constant hot 12v source. Also if all wiring is correct its possible there a bad connection or contact check connecters.
I had the first problem with a JVC radio I installed once it did not have clear instructions on the always 12v hot wires.
Dec 24, 2010 | 2002 Toyota Tundra
I installed my JVC KD-SX650 and it works but it will not keep the radio station settings and the clock setting once I turn my truck off and back on again, what could be the problem?
you need to make sure the yellow wire is going to a constant power source.. the yellow wire controls the clock and preset setting memory.
Jul 13, 2010 | JVC KD-SX650 CD Player
Location of fuse box in Rav 4 1997
Yes there is also a fuse box under the hood. The schematic for fuses should be in the fuse box cover.
Dec 28, 2009 | 1997 Toyota RAV4
The audio/clock fuse blew and every time I replace the 15w fuse it blows
i would try to unplug the clock and the radio change the fuse and see if the fuse blows.
Apr 28, 2009 | Toyota RAV4 Cars & Trucks
Car radio - setting the clock
Dec 12, 2008 | JVC KD-G510 CD Player
Jvc car cd/radio
The radio was improperly installed; there are two 12V leads, one services the radio when on, the other, only the circuitry for the clock and presets.
Eventually, this shouldn't be needed if the manufacturers ever think about using a little bit of flash memory for the presets and a coin cell for the clock.
You didn't give any model number so researching the manual is impossible.
If you can find the model number, look for a user's (or installation) guide on line to find the wiring info.
Aug 25, 2008 | JVC AM FM CD DET FACE CAR STEREO
1997 toyota rav-4
Thanks for the info.
Regarding the clock: The dome light, the lighter and the clock are allon the same circuit, so, it only the clock is inoperative, looks like you need a new clock.
Regarding the AC: Does the AC light come on when you push the button? If so, the electrics are probably OK. You may be low on freon in the AC system. You will need to take your car to a guy who does automotive AC, have him evacuate the system to check for leaks. If the evac holds a vacuum for 30 minutes,he will add freon and you problem will be cured.
Jul 22, 2008 | 1997 Toyota RAV4
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
