Question about Canon imageRUNNER 400S Copier
Canon ir400 when copy text and lines comes with like waves, but print wiht board is ok.
  • 52 Answers
SOURCE: Grey Band/lines across page
your problem could be one of many things first try stoping the copy half way in the machine. to do this open the front door and cheat the door switch with some folded up paper or use a flat screw driver to bypass the switch. make a copy and watch the paper when in goes into the drum and starts to come out like 3 inches pull the screw driver or paper out of the switch. carefully pull the paper out from the machine and see if the image is ok. if the marks are there the problem is with the drum. if the image is clear and there is no marks then open the left door on the copier and inspect the rollers in the heat unit. to do this open the left door the front door has to be open to do this. there is a little green lever on the right side pull this down and look at the 2 roller if you see marks on the top roller or dirt on the lower roller this is your problem. also check the miliage reading on the drum if there is a sticker and check the meter on the machine the drum is rated for 55,000 copies.
Posted on Jan 04, 2008
SOURCE: Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
Posted on Apr 26, 2008
  • 39 Answers
SOURCE: Canon ImageClass MF 6550 prints light text
I mean can you scan a text document with the "photo" option and see if you are still encountering problem. And check this out, he tells how to reset to factory and test scanner. http://www.fixya.com/support/t342579-just_started_printing_blank_pages
Posted on Apr 27, 2009
  • 71 Answers
SOURCE: Canon Pixma iP90 - Jagged text and lines
The printer has a plastic band that runs from one side to the other. The print head has a sensor that passes over it each time it moves. The band is a little transparent and appears to have vertical lines in it. That needs to be cleaned.
  1. Remove power from the printer,
  2. Wipe it clean,
  3. Move the head manually to other side to clean the other areas.
Hope this helps.
Posted on Jun 02, 2009
jatin rattan
  • 13 Answers
SOURCE: I have a Canon MP610 printer.The Test page prints
just chk the properties or the colour cobinations if you choose text for printing out than it will only print text and if it is too dark red that means it is connected with some wrong colour wire
Posted on Jun 11, 2009
Canon IR400 print copy to black print
Most likely it's time to replace the drum unit. Mfr Part #: Canon 1342A003AA, GPR-2, F43-6701-700. Those drum units only last 55,000 copies and then the copy quality starts to degrade.
Nov 24, 2014 | Canon Office Equipment & Supplies
Canon IR400 mechine print to black copy
Sharp xerox AR-5127 printing problem
Do you get the problem on copy and print also?
Dec 25, 2013 | Office Equipment & Supplies
Sir, my canon ir400 prints phots or pink colour paper very dark, the text print is ok, what should i adjust so it prints the photos and colour papers much clearly. plz help me sir. thank u
You can adjust it thru the settings it is like the menu, all is being adjust there including the color, contrast, bright etc.
It really depends on your need so the choice is yours, adjust it the way you want.
Jun 07, 2011 | Canon imageRUNNER 400S Copier
Sir, Print coming out like a sign wave..
sir i have a canon ir3300 machine its print clarity and neetness
but the problem is coming print out is in a waves how can i solve this
Dec 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Apr 27, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Canon IR400 copier
dear sir, I have ir400 copier. please help me to solve the error no. e051. thanks,
regards
Jan 10, 2009 | HP Compaq dc5700 Microtower - Free Flat...
IR400 ERROR CODE E014,E806
E-014 - The fixing motor has a problem. This can be the fuser drive motor, DC Controller, or Image Processor circuit boards. The only time I've had this problem is with one of the fuser bearing going bad and causing excess drag to the motor, giving you the error. See if the green fuser advance knob is hard to turn. If so then check the bearings.
E806 - This is not in the book that I have. Be sure of the number.
E-805 - There is a fault with fuser cooling fans ( located on the delivery door )
Nov 20, 2008 | Canon imageRUNNER 400S Copier
Canon ir 400 copier
Check the scanner. If the lube has dried up it could be causing the scanner to vibrate slightly when reading the image.
Oct 14, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
22 people viewed this question
old marine
old marine
