Question about Dell PowerEdge R905 Server
Power I have a Dell Poweredge r905 after a power outage the following errors read on the display E1614 PS 2 Status and E1624 Power Redundancy. Three of the four lights on the power supplies are green and the other one is amber. How can i fix this problem?
JaxPlanet
  • 921 Answers
SOURCE: No power to dell poweredge 1600sc. Redundant power
Either the power supplies have both failed, which is unlikely, or they are not connected to a hot outlet. Frequently servers are connected to uninterruptible power supplies (UPS) instead of being connected directly to a wall outlet. Make sure the UPS is on and functioning.
Dell provides lifetime phone support for their servers so you should give them a call if you need more help tracking down the problem. (800) 945-3355
If this helps please vote for my solution.
Posted on Feb 16, 2010
  • 355 Answers
SOURCE: No power on my PowerEdge 1800 Server
dells power supplies must come from dell. I would call dell and give then the service tag number of your server and they will be able to tell you about how much a power supply is.
Posted on Jun 07, 2010
  • 12 Answers
SOURCE: We have a Dell Poweredge
Go into the RAID setup during bootup (not always in the BIOS), but will post somewhere on startup (should say SCSI/SAS Controller card press CTRL + M to enter setup) or similar.
When in the raid setup check to see the status of the drive(s).
Was the machine running and it's just happened etc or are these machines you have obtained and are plain not working?
Posted on Sep 09, 2010
  • 747 Answers
SOURCE: After a power outage our
bad battery in mother board it looks just like a watch battery if this isnt the case your power box is burnt you will have to replace the hole power box.
Posted on Feb 14, 2011
Testimonial: "The advice given got the server running at least long enough to get the data off it."
SOURCE: Can I use a 650W ATX power supply to replace DELL
No, you can't use a plain stock ATX PSU because you have to rewire it before install it
Posted on Sep 12, 2012
A power outage cause dell server 1600sc to shut down & no display on the monitor
Hello here is the homepage.
http://www.dell.com/support/drivers/us/en/ussoho1/Product/poweredge-1600sc
There should at least be a message on the monitor indicating there is no signal coming to the monitor. The first thought that comes to mind if all is connected would be that the power supply has failed.
And maybe the graphic card.
Call also the DELL support in your country they will be glad to help
and they probably know the fault.
Contact Us 1-877-671-3355
Good luck
Nov 16, 2012 | Dell PowerEdge 1600SC Server
Want to replace a power edge sc1420 power supply with a regular atx power supply has anybody done that. Think the ATX connector is the same but on the other connectors there are many blue wires and I don't...
1) Dell power supply is unique , you can never replace with another regular ATX power supply
2) Please get 2nd handed Dell power supply from the same model. try ebay
Mar 22, 2011 | Dell PowerEdge SC1420 (SC1420MIN) Server
Can I use a 650W ATX power supply to replace DELL powerEdge 1800 650W power supply (PS-5621-1)?
so long as it fits and the cables connect fine you should be able to use the new power supply
Nov 19, 2010 | Dell PowerEdge 1800 Server
Poweredge 600-SC RC 4Hr J3717 ASSY, Tray, (5Y002) Motherboard: what does it mean when an dell poweredge 600 sc pr...
Three sets of beeps, or three individual beeps? Does it repeat? If so, then check this for the code you are hearing:
http://support.dell.com/support/edocs/systems/pe600sc/en/it/1r237c20.htm#1046231
If it is a steady once-per-second beep - or a constant screech - and it is able to boot to the OS (or even most the way), then it is probably your RAID controller. Boot to CTRL-A or CTRL-M to check the status of your array.
May 16, 2010 | Dell Poweredge 600-SC RC 4Hr J3717 ASSY,...
I have a slider window I need to remove to bring in a pool table,can't find any screws to remove ,found only a tag with this info AAMA SPONSERED S/N720 315004
There are tension wheels on the top and bottom (2 at each end) of the slider window. You have to lift the slider window and lift the bottom wheels off the track to be able to remove the window. The reverse to reinstall.
Jul 18, 2009 | Dell PowerEdge R905 Server
Poweredge 2600/Powervault 770N does not boot
I recommend that you first try replacing the power cord, if that doesn't work try replacing the power supply.
Mar 30, 2017 | Dell PowerEdge 2600 Server
Poweredge 2600 power supplies in red
Possibly a power distribution board problem.
PDB requires replacement.
Jul 09, 2008 | Dell PowerEdge 2600 Server
Dell PowerEdge R905 Server   Logo
66 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
