Acoustic Research Model AW871 wireless sterio speakers
I just purcheased these Acoustic Research Model AW871 wireless sterio speakers and a ONKYO Model TX-SR504 AV receiver. The Acoustic Research transmitter has an audio level indicator light which should flicker intermittently if there is a good connection to the wireless speakers. But the light does not blink or flicker for me - nada. The speakers each show a blue light which means they are picking up a signal from the transmitter, but no sound. Everything is plugged in correctly for power. The AR transmitter comes with a "Y" adapter cable with metal connector plug-ins on the ends for an analog connection. However the ONKYO receiver accepts only bare wire connections for its speaker outputs. So I cut off the metal connector plug-ins, stripped the wire back 1/2" and inserted it the terminal posts for "Front Speakers A." My audio source is a CD player which is plugged into the receiver. The receiver setting are set for CD input and front speakers A output. I am not getting any sound from the wireless speakers and no audio level indicator light on the transmitter. What am I doing wrong
  • lmrenault Aug 31, 2007
    Thanks Dyllan. Actually I found out that the RCA plugs for speakers have two wires, not one. You can see that I am not electronically literate. So I rewired one to "+" terminal and one to "-" terminal for the right speaker and for the left speaker and it worked. Then I discovered that the original RCA plugs (I had a second set that I did not cut) actually work better in the "CD Out" on the back of the receiver. The "CD in" is for the plug coming from my separate CD player.
    All is well. Thanks.
    Sergeant:
  • 279 Answers
Your connection between the AR transmitter and the ONKYO receiver sounds solid. I'd guess it's the wireless speakers that are the wrong point, or at least that's what I'd look at first. Doing a bit of research, I noticed a couple minor points. First, these seem prone to RF interference from other RF devices. Have to tried switching channels on them? Second, someone reported theirs would not work properly unless the speakers were turned on just before the transmitter, and turned off shortly after the transmitter. Apparently you have to hold the button on the front in for 5 seconds to turn the speakers on or off. I know that's rather basic, but it's been a few days and no one else has responded, so I figured we should start somewhere.
Posted on Aug 31, 2007
SOURCE:
How do I connect my ipod classic to my onkyo tx-sr504 audio/video receiver?
Onkyo DS-A2
iPod® dock
http://www.crutchfield.com/p_580DSA2/Onkyo-DS-A2.html?tp=238
Jul 11, 2014 | Onkyo TX-SR504 Receiver
How do I connect my Ipod classic to my onkyo tx-sr504 audio video receiver ?
Perhaps you just use a cable like this:
24806182-o2xiqwfhpbqb50rejnrszwmj-1-0.png use the tulip plugs and plug them into the AUX of the amplifier. Then at least you can play the music via the receiver.
Jul 11, 2014 | Onkyo TX-SR606 Receiver
Wire Kenwood GE 7030 equilizer to onkyo tx sr504 receiver
The manuals explain it.
http://www.retrevo.com/support/Kenwood-GE-7030-manual/id/479dj189/t/2/
http://www.retrevo.com/support/Onkyo-TX-SR504-Receivers-manual/id/365ag215/t/2/
For all practical purposes an EQ or any analog audio processor connects exactly like a Tape Deck - into any RCA pairing that has both an OUT and an IN and can be selected to be in or out of the audio path.
However, on this and just about any modern digital-capable AV Receiver, activation of any external loop that would connect a processor or tape deck would automatically DISable any digital audio sources. The effects of the processor, therefore, can only be used with analog stereo sources. It WILL affect the sound going to all speakers if you use the various Digital Sound Porcessing modes as the extra channels are derived from the stereo channels anyway.
Sep 30, 2011 | Onkyo TX-SR504 Receiver
How do I adjust the balance on my onkyo receiver?
You don't. Once the speakers are adjusted relative to each other using the test tone that's it. The modern presumption is that you're sitting in the sweet spot at all times and all program material is perfectly recorded.
The manual is available at retrevo.com for free.
Mar 31, 2010 | Onkyo TX-SR504 Receiver
How do I adjust the balance of the speakers? One
press setup on front. press speaker level control. use left and rt up and down buttons to select speaker and set levels. hit return to go back of setup to get out.
Mar 17, 2010 | Onkyo TX-SR504 Receiver
TX-SR504 receiver won't turn on
Had same on an ONKYO TX-505 given to me for repair - eventually found a broken track on top circuit board that came from a transistor that control the main power on relay - looked like it was burnt off for a section of about 1.2mm
Repaired the track and has worked ever since
good luck WTech/Townsville
Mar 18, 2009 | Onkyo TX-SR505 Receiver
Two of the 5 speakers work on test but not for actual sound
you probably have to set it to multi chanal mode , while tv is most stereo the receiver has to decode that to 5ch
Apr 28, 2008 | Onkyo TX-SR504 Receiver
Sound won't play thru stereo from t.v.
take the main tv digital opti outto sterio ok on ch or from dish box to sterio on a ch
Feb 02, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR504 - Sound problem
Ooops, that did not work.  OK try  http://www.retrevo.com/s/Onkyo-TX-SR503-Receivers-review-manual/id/365ag216/t/1-2/  for download of manual in .pdf form, and English too!   Hope this helps.  Cheers,   Chris  :)
May 05, 2007 | Onkyo TX-SR503 Receiver
462 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
