Question about Ricoh SFX2000TE All-In-One Laser Printer
Sfx " sound field xpander"
I bought this volume sub/treble control unit. I have no idea what the two cables on the back are for. One looks like a out audio cable from computer, I think. But there's a 5~pin din. Are these speaker line outlets? Surround sound? I guess my question is "would you be so kind and share with me and the world the (SFX) pinout". I'd be most greatful and your biggest fan. Thank you MTB
We have canon 2420 and paper jam
Posted on Jul 11, 2013
Hi I have just bought a Sony 820av amp and tannoy sfx speakers. I have got all working except my sub. Can anyone advise me on correct cabling for the sub to amp?
Sub woofers are just mono amps. They feed both the right and left output together. So all you need is a stereo to mono cable. The two jacks go in the sub and the single mono into one of the terminals on your amp. The other terminal will allow another sub to be connected I think, though please check your manual for this.
Jan 17, 2013 | Audio Players & Recorders
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
pressed:
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
fader.
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
a.
4) To.store the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
Hey there, I have JLB Creature II speakers, that have been working fine for nearly a year. Until one day, when the treble's maximum volume became a lot lower than before. The bass still rocks it up like...
Hi Nikita,
The problem may be with the internal electronics of these speakers, especially the sub-system that controls the treble. If they are still under warranty, you should talk to the dealer. If not, you should contact a technician.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | JBL CREATURE II Computer Speakers
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I need to find out what buttons control the bass and treble
Press in on the volume control repeatedly to step through the menu of audio functions. The
first option is Volume, followed by subwoofer (only if the subwoofer feature is currently
activated), Bass, Treble, Balance, Fader and back to Volume. When adjusting audio functions,
the unit will automatically exit audio control mode after five seconds of inactivity
If you need the user's guide, click her to download.
Feb 21, 2009 | Jensen MP7610 CD Player
Finding how to set the treble and bass
Under the silver volume knob is a thin silver bar. Push it and the menu will pop up on the screen. Continue to push this bar to scroll through the different options. It controls bass, treble, balance, fade, sub volume etc. Good luck, hope this helped.
Dec 19, 2008 | Alpine CDA-9833 CD Player
Any info on Altec Lansing Satellite 31 set up?
Hi, I have these. Always unplug the Sub before changing the wiring around.
You should have a dual cable. Plug one end into the Sub's Audio In and DC Out (the one that looks like a power plug goes in DC Out, the one that looks like a headphone goes in Audio In). The other end of the dual cable goes to the Satellite that has the volume control. Plug into DC and Sub. Plug a cable with headphone plugs on each end into the SPKR jack on each Satellite. Plug another cable with headphone plugs into either Input 1 or Input 2. The other end goes to your computer's audio out. I don't have the original of these two cables so I can't tell you what they look like. If one is longer or thicker it should be the one to go between the speakers. Set the level control on the Sub about 1/4 up. Plug the Sub in and play some music. You can adjust the Sub level and the Bass and Treble to your liking. I have my Bass & Treble straight up, Sub at 1/4. You can use one of the inputs for your computer and the other input for another device like an iPod without having to unplug things.
Jul 17, 2008 | Audio Players & Recorders
ALTEC LANSING MULTIMEDIA COMPUTER SPEAKER SYSTEM:
the controller chip inside your altec is possibly defective. i have the acs 45.1 and the unit wont turn on.. the culprit is the main power/volume chip.
Apr 30, 2008 | Audio Players & Recorders
One speaker not working
jjohnmith
First things first:
1) check your speaker for good connector, and all is working is playing fine.
2) check if your warranty covers one SPK. or RMS
other than that ,
Good Luck
Feb 01, 2008 | Altec Lansing VS2121 Computer Speakers
Only one speaker working
Even I have faced the same problem for the past six months.. Today i have fixed only issue with the back jack.. removed slowly and fixed it tightly.. it's works. :)
Oct 06, 2007 | Harman Kardon HK206 Computer Speakers
Ricoh SFX2000TE All-In-One Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
