How to fix
My desk top cannot recognize device, its plug in the usb pot , red light is on on the device yet computre cannot recognize it
    Brigadier General:
  • 3,400 Answers
IF THE DRIVE IS NOT VISIBLE IN COMPUTER YOU HAVE FORMAT IT.GO TO CONTROLPANEL.ADMINISTRATORS TOOL.STORAGE.DISKMANAMENT LOCAL.THEN YOU SE THE DISK RIGHTCLICK ON IT WITH THE MOUSE A WINDW OPENS CLICK FORMAT AND GIVE IT A DRIVELETTER.
Posted on Jul 11, 2013
4 Suggested Answers
SOURCE: USB device not recognized
Thank you so much USCmed2! Your solution worked and we are in the process of backing it up as we speak. You deserve some sort of reward... site reward or something. Kudos and thumbs up and worship smilies etc... :D
Posted on Jan 25, 2008
Crankstart
  • 696 Answers
SOURCE: acomdata 320GB drive is not recognized
If the light is on it only confirms that you have power, if it doesn't work on other ports or another computer then it's likely the circuitry of either the drive or shell is damaged, take it to a computer store and have the techs swap it into a new shell(about $40). Then have them test it, if it works you're done, if not then it is the circuitry in the drive itself that is damaged and you will need to send it for data recovery if you want the files back.
Send me an update once you have tried this suggestions and let me know how you made out. If you require the help of a pro for the final steps, reply with your country and region and I will locate a reputable facility to assist you further.
Chris
Posted on Jun 04, 2009
  • 71 Answers
SOURCE: computre not reconizing my my
Try an new USB cord. If nothing happens, then most like scenario is the controller card went out on the case housing the hard drive. Easy way to test is open the case, remove the hard drive and conect it to your pc or take it to a repair shop to hac=ve the hard drive tested. Usually, shops won't chare for this. If hard drive is good, pick you up a new external hard drive case.$20 or less online.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817392032
Posted on Nov 30, 2010
Canon image runner C5185 not connecting to my desk top, not saying find new hardware when i plug in my usb printer cable.
Even if the computer recognizes that some device is connected you still need instal the software that shipped with it, along with the drivers.
Dec 27, 2013 | Office Equipment & Supplies
My pc does not recognise seagate 500gb desk agent
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 03, 2012 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Seagate goflex desk 1 TB wont turn on
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Apr 27, 2012 | Seagate Freeagent Goflex Desk 1 TB Desktop...
My Pc's, one have windows xp, the other, with windows 7 Home P, not reconized the External Disk FreeAgent GoFlex Desk of 2 Tb. Please, help us. Thanks
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jul 18, 2011 | Seagate FreeAgent GoFlex Desk 2 TB USB 2.0...
USB Mini Optical Mouse - Model: M409 company Enter not recognized
go to device amanger then uninstall all usb drivers from computer then restart the computrer then it autoinstall all usb drivers.
tehn connect your usb mouse cable to computer try all usb port then if problem arise then your mouse usb chip has issue.
Thanks for using fixya.
Please rate solution if it helps.
Jul 24, 2009 | Computers & Internet
My XP system does not recognize Sandisk Sansa e260
The XP did not recognize the device because I used a after- marked USB expander board that did not provide enough power to the device. Plugging to the Motherboard - attached USB port solved the problem.
Mar 20, 2009 | SanDisk Sansa e250 MP3 Player
Usb 4ports malfunction.not recognized.
i keen to to find that wich type of device you want to connect to the usb port. i think its a usb hard drive. if other please check this first.
Jan 23, 2009 | Computers & Internet
Laptop doesn't recognize QuickCam® Deluxe for Notebooks (2)
hii john sorry about this .. ok
another solution install the driver clicke here
restarts the computre When will the solution accept my respect and greetings
sincere markknof
Aug 24, 2008 | Computers & Internet
Acer Monitor boots up w/computer then "no signal"
you must have disconnected it while the pc was running.damage can occur while doing this as can a keyboard (they are not like USB devices that can be plugged and unplugged while "hot".)
Jul 20, 2008 | Acer AL1916W 19" LCD Monitor
6-29-2008 I have a Maxtor One Touch 4 Mini that I use to back up files on my desk top and also want to use it to transfer the same files back and forth with my laptop. Both the Desk Top and the Lap...
After following the on-line instructions I replaced the USB cable that came with the Maxtor with a difrent one and now the drive works as it should. I do not know what the problem is with the original USB cable.
Thanks for the follow-up
Glenn Alford
gamafay@aol.com
Jun 29, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
