Question about Microwave Ovens
Changing light bulb in MP9485S lg microwave...
How to change light globe in microwave
EVER HEARD OF GOOGLE????
LG LMVM1935 manual
Google
That gets you to the manual.
Page 3 is the table of contents that lists oven light replacement on page 29.
Just maybe, if I teach you this you'll be able to do it yourself next time!
Sep 21, 2016 | LG LMVM1935 Convection/Microwave Oven
CANT FIND LIGHT TO CHANGE IT
Changing bulbs on microwave ovens is usually from the outside of the cabinet. You will find a small door in the location of the light, with either one or two screws. They are the only two screws that aren't security screws!
Apr 06, 2016 | LG MS-0744Y Microwave Oven
How to replace the light bulb in LG microwave oven.
Free LG Electronics Microwave Oven User Manuals ...
kitchen.manualsonline.com > ... > Kitchen Appliance LG Electronics
Products 1 - 50 of 141 - LG Electronics Microwave Oven 1SS6LMV1 8. LG - Life's Good Microwave Oven User Manual. Pages: 0 Saves: 0. See Prices
Sep 24, 2015 | LG Microwave Ovens
Is there an internal reset button?
The short may have blown an internal fuse.
Jan 20, 2015 | LG LMV1630ST Microwave Oven
Lg lmh2016st microwave shorted out after changing lightbulb now doesn't work
We see and repair this a lot. The problem is on the controller assembly.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Dec 01, 2013 | LG LMH2016ST
Can't find light globe in MC924JLA LG Microwave
I think you're referring to the bulb which is not working. You have to remove the cover from the microwave to gain access to the bulb. Replacements can usually be found at appliance repair shops or stores and electrical or lighting supply stores.
Jun 21, 2010 | LG Microwave Ovens
The bulb has gone on my microwave. How do I change
take the screws out of the cover take it off can now access the light-check appliance store or hardware for the bulb.
Dec 22, 2009 | LG LRMM1430 Microwave Oven
LG MP- 1482s INTERNAL LIGHT CHANGE
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 01, 2007 | LG LRM1230W Microwave Oven
Where is the light bulb located?
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
