Question about Electrolux UltraActive Turbo Bagless Canister Vacuum - Tangerine
Ultraactive vaccum filter keeps popping off
The rear door pops open when the vaccum is on and the filter comes out
    Novelist:
  • 171 Answers
There are two possible causes for this issue. The most likely is that your exhaust filter is blocked and so the air literally cant get out. You need to replace the exhaust Hepa Filter every six months anyway so get a new one and see if that fixes the problem. If it still is popping off after this it means the tiny lugs on the filter cover are damaged so you will need to get a new one of those.
Posted on Jul 23, 2013
Filter in the ball keeps popping out even though it is clipped in place.
Air filter is not getting air flow.air must pass thru filter or it will pop off.I placed filter against exhaust end of shop-vac ( NOT SUCTION END) untill I got air coming out.
Mar 12, 2015 | Filter Vacuums
Dc25 filter keeps popping out in ball and jamming ball can anything be done to fix
Hi, it's Ambrai from Crucial Vacuum.
There are two reasons why the post filter may pop out. One reason is that the spring on your filter may be broken. The post filter should pop in and you should hear a click to make sure it is locked in place. If you don't hear that click, the spring may be broken. Otherwise, your post filter may be dirty. Once the filter is packed with debris, air can no longer pass through it causing the ball to pop open. There are also two types of filters for your Dyson DC25. Remember for optimal performance, it is recommended to change your filters every three to six months.
You can purchase your replacement filters directly from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc25-filter-1879.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Ambrai Brown
Crucial Vacuum Customer Care
May 07, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Exhaust filter keeps popping out
If the filter is clogged or not breathing well it will pop off. These filter are only good for 6 to 12 months of normal use. You can run it without the filter . The filter only helps with allergies.
Apr 12, 2014 | Kenmore 25512/ 25513 Progressive Canister...
Heppa filter pops off when I turn the vacuum on
Did you replace the exhaust air diffuser? That's the plastic type vent housing the hepa filter was under.
Oct 12, 2013 | Electrolux UltraActive Turbo Bagless...
Filter in ball keeps popping off
Is the spring in the clip that locks the filter in place , it's not much bigger than the one found in a pen !
Feb 19, 2012 | Dyson DC25 All Floors Bagless Upright...
Dyson Animal filter in ball comes loose and pops up and catches on frame and ball will not rotate.
I'm sorry to hear you're having difficulties with your DC25's filter. I'd encourage you to contact us directly so we can resolve this for you - you can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Jan 12, 2012 | Vacuums
The chord will not retract? I can't find a way to get at it? I have the air filter part off. It is an ambassador vaccum.
hi,
for this model, there are no screws or anything to pry open.
First, remove the bag, from the unit and keep the door open. Remove the hose for easier operation here.
Next, both of the side bumpers must come off. They will actually slide out where the bag goes. Which is also why we are keeping the bag door open.
The easiest way to get the sides off is to use a flat screwdriver and insert it just a little at the back and then tap the screwdriver towards the front of the unit. you can use a hammer for the tapping, and you may want to have someone hold the machine as it will slide.
for this unit, when you have the side rails off, TURN THE VAC OVER so now you are looking at the wheels. You will want to remove the bottom of this machine. There are no wires or switches connected to the bottom panel. easiest way for this is to grab hold of the rear wheels and lift up.
your cord winder will be there at the back. Its probably just locked in an awkward position OR its actually broken.
Good luck
Nov 15, 2010 | Electrolux Lux 5500 Canister Vacuum
Pops open when bag still almost empty
try cleaning the filters if they are blocked then suction is lost and would appear like bag was full. hope this helps
May 20, 2009 | Vacuums
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Need to open motor compartment
Use a flat blade screwdriver, The dusy compartemnt door will come off by pushing it back, it just pops out. Then the rear top cover is held on by a tab, one in each corner. Put the flat blat in the slot at the bottom of the cover and work it until it pops loose. Then there are 2 screws to tak out to remove the cover over the motor and cord reel asm. But now you can get to the motor.
Jan 24, 2008 | Panasonic MC-V9620 Canister Vacuum
Electrolux UltraActive Turbo Bagless Canister Vacuum - Tangerine Logo
116 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
