Question about SanDisk Sansa e260 MP3 Player
My sansa mp3 player 6GB
I turned my mp3 player on and it is showing the phrase "refresh database". It has displayed this phrase for the last 3 hours and even when I reset the mp3 there is no change.
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
I reformatted my unit at my pc.. then it keeps saying refresh database... what can i do??
For the Sansa Clip, first try to RESET the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
If the player still freezes with the refresh database message, after a reset:
then update the firmware. Next link shows how to update the Sansa Clip:
http://kb.sandisk.com/app/answers/detail/a_id/300
In METHOD 1 is explained how to use the sansa updater, for Windows operating system.
METHOD 2 tells where to find the online sansa forum for updating manually.
Jun 27, 2010 | SanDisk Sansa Clip MP3 Player
"Refresh Database" never ends!
If you try to load too many songs onto the player initially, it may take up to an hour to get past Refresh database. Unfortunately, if you shut the player off while it is refreshing, it will more than likely ruin your player. Run the Sansa Recovery Tool or Update the Firmware on your Player as a workaround. Make sure the hold/lock switch isn't activated, just as a safeguard.
-Tha Mp3 Doctor
Mar 17, 2009 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip 2GB stuck on refresh after charging
download the firmware update!
I had same prob- gone after update
here is link to update:
http://www.sansa.com/support/sansa_clip/faqs
good luck
Joe
Jan 26, 2009 | SanDisk Sansa Clip MP3 Player
Sansa E200R gets stuck in refresh when I turn it on
http://www.sansa.com/support/sansa_e200/faqs
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
If that does not fix it, please post a comment with an update to your problem.
Jan 05, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
"refresh database"
Get the Vista compatible version of the software from Sansa's website
May 24, 2008 | SanDisk Sansa e260 MP3 Player
"refresh database"
try formatting the hole mp4 *the musik partition only!!* or
try to use the recover mode and reinstall the hole mp4
more information u finds on google....
Jan 16, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa e250 mp3 player database refreshing problem
I cant really help you with the reboot problem, but youy should have never taken the backplate of, that voids the warranty so that you can't return it.
Dec 25, 2006 | SanDisk Sansa e250 MP3 Player
"refresh database failed" how do I do a database refresh?
i have the same problem ... refresh database fail .. i can put songs on the player but it doesn't show them or play them :-( HELP!!!!
Nov 15, 2006 | SanDisk Sansa e260 MP3 Player
Refresh database looping
This may not work for everyone - but try inserting a TransFlash (also called Micro SD)card in the microSD slot, and power on. It may then correctly refresh its database. It worked in my case, with firmware ver11.
Aug 11, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
