Question about Exercise & Fitness
My treadmill VL0901 displays Error 3? Can you help?
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: treadmill stop then display an error speed
If the is a Next Gen unit need to enter Diagnostic menu by pressing and holding pause then press clear twice. Continue to hold pause until until read service menu. press any arrow up and select system test ,then press enter the display will begin to automatically scroll thru available options. press enter to access Main Motor Module the next window will be Speed Automatic.
Upon entering this test mode you will able to check the drive motor and motor control board. By using the the speed arrows you will be able see the actual speed if functioning if not it could possibly be the speed sensor or wire harness ( SIMPLE CONTINUITY CHECK WILL RULE IN OR OUT THE HARNESS ) and point the problem. Now if their is no belt movement then hit clear and proceed over to SPEED CONTROL ERRORS hit enter this test allows seeing the motor controller conditions that are being displayed on the motor controller display if any of these come up then the controller need s to repair or replaced:
Max Temperature, Maximum voltage, Fault Line 1 error, Static current trip and dynamic current trip ( this also can a running belt tension this can result in a cannot obtain speed error message ) hit clear to get out of diagnostic once you eliminated the problem. Good Luck!!!
Posted on May 21, 2010
SOURCE: My VL0901 treadmill displays an E4 error as soon
You must plug the safety cord in if it is in just make shore the contacts r clean
Posted on Aug 20, 2011
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Have a J620P and just received a 51 code. What is it, and how do you fix it?
Follow the next step:
Scan by 3 seconds for to clear the error the display and restart the treadmill
If the error Do not appear,continue.Electrical fluctuation can be have actuated in the system electric power, and cause the display error.
If the problem persist call:206-881-7392 tunturi treadmill
God bless you
Oct 01, 2013 | Tunturi Exercise & Fitness
I have a VL0901 treadmill that displays error 9 when I turn it on. How do you clear this as nothing works.
follow this troubleshooting and fix it. God bless you
Error 09, Lower PCA Memory Test Error
Probable Cause Most commonly indicates a problem with the lower PCA when the error consistently appears. It is rare for a failure to occur that would cause this error.
Corrective Action
  • The lower PCA should be replaced if the error consitently appears at power up.
    1. External causes may make the error appear intermittently.
      1. If the AC input of the unit dips significantly during power up test sequences, the test could fail causing the error to appear.
      2. A treadmill connected to a non-dedicated AC circuit can experience this error intermittent
    Jul 29, 2013 | Exercise & Fitness
    Error code 1 and 3 on my Precor 9.21s treadmill?
    Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
    Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
    Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
    Precor Error Code 03 E03 EEPROM Test Error
    Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
    I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
    see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
    When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    How to reset treadmill T630
    Dear Sir:
    I will try to help you.
      • 1
      • 2
      • 3
      • 4
      • 5
    If you need further assistance, please reach me, sincerely.
    God bless you.
    E.CUADRA
    MANAGUA, NICARAGUA. C.A.
    Oct 24, 2011 | Exercise & Fitness
    9.1.0 TREADMILL PRECOR PACE ERROR 3
    Dear Sir:
    Hello I hope everything is fine.
    I will give some Tips:
    Description Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and EEPROM checksum during the power up test sequence. If a fault is found during the power up test sequence, the appropriate error code will be displayed. Possible Causes 1. These errors messages almost always indicate an upper PCA problem when they are consistently displayed. Failures causing these error messages to be displayed are rare. Possible Remedies 1. If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see one of these messages displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in one of these messages being displayed. Treadmills operating on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.
    In other words, you need recalibration in your equipment, I recomend after you make a test for a RAM MEMORY.so contact your service call. I recomend Strong, INSTALL regulator Voltage is cheap about us$15,00 Radio Shak or another Electronic Place.
    Thank you in advance , sincerely. Blessing. If you need additional Help, please do not hesitate to contact me.
    E.CUADRA MANAGUA, NICARAGUA. C.A.
    Sep 25, 2011 | Precor 9.21 Treadmill
    My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
    From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
    1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    2.Press the "ENTER" button three times to access the treadmill's error log.
    3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
    5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
    I hope you find it very helpful.
    Sep 04, 2011 | Exercise & Fitness
    Exercise & Fitness Logo
    48 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
