Single clicks are not working properly in MG-0982 mouse.
It is a fairly new mouse. I have even tried changing batteries. Even for selecting, I have to click more than once. What could be the problem?
I have hp mg-0982 wireless mouse my click r not working properly i have to press i hard to get i work... gave some solution
Posted on May 14, 2014
    Master:
  • 966 Answers
It could be defective, take it back to the store for replacement.
Posted on Jul 15, 2013
SOURCE: It's not working right....
The BenQ M310 mouse needs to "sync" with the USB receiver. Need to push the two buttons at the same time, or maybe the one in the mouse first then push the button in the USB receive so the two can "sync" to each other. This may solve this problem. Good luck!
Posted on Aug 26, 2009
SOURCE: mouse double clicks when i single click. sometimes doesn't click.
If this is the same problem that the Microsoft IntelliMouse Explorer 3.0 is susceptible to, it can be fixed! It is a hardware issue that is caused by corrosion on the metal contacts inside the buttons. The corrosion prevents electrical signals from passing between a copper plate and terminals above and below it. You can carefully scrape the contact points with a knife to expose the clean copper.
Follow these instructions at your own risk.
To get into the mouse, peel off the pads on the bottom and unscrew the screws, then carefully pry the shell apart. Do I need to say disconnect your mouse from your computer? Attached to the circuit board inside the mouse, you will see a couple of black boxes.
Look closely at one of the boxes and see that there is a cap with ears that clip onto the bottom half. Wedge a blade into one of the seams between the ears and the bottom half and it should pop up a little. The dull side of the blade should be touching the circuit board. Be careful to not bend the ear. Pop the other ear up and the top of the box should come away.
Study the internals of the black box. At rest, the copper plate is held in place by three contact points: at one end by a pivot point; in the middle by the end of a flex-spring; and at the other end by the upper terminal. When the mouse button is clicked, the copper plate is pressed at its center until the spring gives way and the plate pops down to the lower terminal. This is called a "mousedown" event. When it pops back up to the upper terminal, this is known as a "mouseup" event. In quick succession, mousedown + mouseup = click. If the plate or one of the terminals is corroded, the mouse can become confused, and single-clicks get registered as double-clicks.
Warning: the plate is tricky to put back in! To remove the plate, pivot it to one side, away from the terminals. Be careful to maintain control of the plate. It is tiny and springy, so it likes to fly away. Unless you have very small hands, you need to use tweezers to handle the plate.
Check the contact points on the top and bottom of the plate for corrosion. You can use isopropyl alcohol and a toothpick to rub the corrosion away. Be careful to not bend the plate. If the toothpick and alcohol are not enough to expose the copper, scratch gently and evenly with the tip of a knife blade.
Do the same with the upper and lower terminal.
Now is the time for the most frustrating part. Due to its tiny size and being spring-loaded, the plate can be extremely frustrating to reposition. In my experience, it seems that the easiest way to put the plate back in place the terminal end under the top terminal, then position the spring in the middle (there is groove where the spring is supposed to rest), then use tweezers to pull the opposite end against the force of the spring and seat that end in its groove. Meanwhile, I hold a finger against the top of the plate so it does not fly away if the tweezers slip.
When the plate is successfully positioned, press on the middle of the plate to make sure it clicks up and down the way it is supposed to. Clip the cap back on the black box. You may have to turn the mouse upside-down to do this so the white piece does not fall out. Screw the shell back together and stick the pads back on.
Now, if you didn't break anything, you just saved $30.
Posted on Jun 19, 2009
  • 29 Answers
SOURCE: Logitech wireless usb mouse not working
just see the bottom side of the receiver. you will fin a hole. clean the hole by blowing in the air. if this didnt work lust open the receiver(be careful not to break it, use plastic card or credit card on the side to open the hooks) and put 2 drops of white petrol on that part and leave it for one minute,then wipe it with cotton.
cheers...
i was also having the same problem but solved it with the help of logitech tchnical department...
sagar
Posted on Jul 29, 2009
  • 497 Answers
SOURCE: double click on single clicking the left mouse
Try changing the "Double-Click speed.
2. Check for the Folder option.
Good Luck!!!!!!!!!!!!
Posted on Oct 20, 2009
SOURCE: dell latitude touchpad mouse is sticking and right
you are facing a defective mouse touchpad...have it repaired
Posted on Feb 16, 2010
Hp mg-0982 moust take apart
Hi!
If that's the case, just use fine brush in cleaning. Un-plug it and plug again. Restart your computer.
Jan 19, 2014 | HP Computers & Internet
My Logitech MX 1100 just stopped working out of the blue. The red battery light on top is blinking, so even though I've only been using this for a couple weeks (and the batteries were fairly fresh) I...
I had the same problem, brand new battery, the indicator light still blinking red. I finally got mad enough to shake the mouse kinda hard, and it worked. I then removed and replaced the old batteries in, it started blinking red again, but it worked after I gave it a couple of hard side by side shake. I do notice that there's something moving inside the mouse. It could be a connector that got loose. Hope this fixes your problem
Sep 25, 2010 | Logitech MX1100 LASER Mouse
Cannot use the double click feature on my mouse
To modify the mouse settings, open the property sheet using Start > Control Panel > Printers and Other Hardware > Mouse and select the Buttons tab as shown below. Check boxes and sliders allow the necessary modifications to be performed.
There is even a Click Lock function that is very handy for those that have trouble holding down the mouse button while using the drag and drop function.
The button configuration and Double-click speed settings must be set properly. Then it can solve your double-click problem.
Mar 25, 2010 | Logitech MX700 Cordless Optical Mouse
Fairly new mouse (new batteries also)not working. Solid blue light when plugged into USB port but cursor will not move at all when click mouse buttons or scroll bar. Rebooting system nor unplugging USB...
First make sure your mouse is installed properly. Go to Device Manager and see if it lists the mouse and has no conflicts. Also, try a different USB port, especially if it doesn't show up. If your receiver and mouse have reset or connect buttons on them you'll need to push those also. try alternate batteries. if none of these suggestions can solve your problem you may be looking at a defective mouse.
Nov 05, 2009 | GE Optical Mini Wireless Mouse 98793
Double click on single click
Did your mouse come with a CD or was it a PnP and you just plugged it in and your OS set up the drivers?........In the control panel under mouse/pointing device there are several options; some of whic have the single click = double click option check there first and let me know what you have.
Thx
Aug 01, 2009 | Wacom Intuos3 Graphic Tablet
Logitech cordless click N231 mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver burron and then press the button on the mouse. This should be fdone when ever you change batteries or glitch. Hope this helps you. Bud
Dec 30, 2008 | Logitech Cordless Mouse
Mouse will randomly double click or have to click several times to work
Please check whether there are any buttons on the side of the mouse you may be clicking these at the same time as you are single clicking.
You could also try going into Control Panel --> Mouse
Try Slowing down the double click speed
If that doesn't work try speeding it up
Another problem with a laser mouse is it jumps around the screen randomly if there is a pattern on your mouse mat or desk, or if either are too shiny or even glass as the laser reflects incorrectly on these type of surfaces.
Oct 18, 2008 | Logitech Cordless Mouse
Left click of my logitech cordless optical mouse not works properly
try to set on your MOUSE, here:
start-control-panel-mouse folder
hope this can help. :)
May 16, 2008 | Logitech Wheel Mouse Optical
Computers & Internet Logo
2,344 people viewed this question
David Payne
David Payne
